07-14-2023, 02:37 PM | #749 | |
4148
Rep 3,700
Drives: 2022 M5C
Not a BMW guy...but certainly an M5 guy.
07-16-2023, 11:40 AM | #751 |
7472
Rep 6,845
Drives: '18 M550i|'21 X5|'03 540i
Garage List 2013 VW Tiguan [0.00]
2015 Infiniti QX60 [0.00] 2021 BMW X5 [0.00] 2003 BMW 540i [0.00] 2018 BMW M550 [10.00] |
I think any pre LCI retrofit requires an extra wire from the BDC or a jump wire, no matter what country. LCI’s have one more independent light than pre LCI. Same for coding to make that wire active and probably rearranging on the inner plug.
2018 M550ix|Carbon Black|Dinan Modifications|2003 540i|Jet Black|M-Sport|2021 X5 Mineral White
Prior BMW's: 1987 325e|1993 740i|1998 740il|2001 530i|2002 745li|2007 750li|2006 750li|2001 530i|2012 535xi| |
Thresherinc57.00 SeatownF9047.00 |
07-27-2023, 10:00 PM | #752 | |
47
Rep 125
I got the plug and plays and only the outer lamps is on when braking. I'd love to have the whole lamp on when braking for a more OEM look. |
07-28-2023, 12:59 AM | #753 |
7472
Rep 6,845
It’s all in this thread but I’m not sure it will apply to the Chinese knock offs.
07-31-2023, 08:34 AM | #754 |
Rep 3
Performed a lci retrofit on a UK spec f90 competition using the jumper method for indicators described in this thread. After installation, all rear lights were working however a light pulse from reverse lights and several lighting errors, which were likely due to lack of coding performed.
Following this however, the instrument cluster has intermittently been completely blank and front right headlight including turn signal has gone out. Have reverted vehicle back to stock however there is still an issue with the front right headlight. Cluster seems fine for now. Just probing to see if anyone else in this thread has come across similar issues. Thank you. |
07-31-2023, 09:22 AM | #755 | |
7472
Rep 6,845
The blank display is a common issue and can be resolved with a dealer software update (or a pull of the battery negative or just waiting for the car to go to sleep fully). The headlight issue has nothing to do with the LCI install confirmed by the fact you are still getting it after reverting back. Taillight errors with the LCI's in are definitely due to lack of coding.
07-31-2023, 11:45 AM | #756 |
Rep 3
Thank you for the response!
Heard a lot about the instrument cluster fault but what are the odds! When it goes blank, only the side light led is illuminated on it seeming like it is linked somehow. Fingers crossed it doesn't come back. The way I see it is that all tail light wires are simply analog outputs from the BDC mosfets and whether open or shorted, can't do any harm other than produce a fault code for overcurrent/lack of. And based on the tail lights completely working both with the LCI, and reverted to normal tails, shows they haven't taken any damage. So now I have a faulty headlight module or BDC as the linbus line between the pair doesn't seem to activate anything does make a turn signal fault code too for implausible signal. The canbus to the headlight does work as I can communicate with it, proving it has power n earth. Drl does work but I believe it's separate? |
07-31-2023, 11:57 AM | #757 | |
7472
Rep 6,845
I bet your display will be fine. BMW and Gremlins have been part of the brand for 50 years. Kind of like a Windows machine - reboot and problem solved.
09-18-2023, 12:19 AM | #758 | |
12
Rep 36
How much and through who? |
10-07-2023, 07:10 PM | #760 |
47
Rep 125
The OLED ones I got from Bimmerplug (shipped from Aliexpress) when you brake only the outer lamp lights up. The inner lamp lights up only when DRL is switched on or highlight is on. Turn signal is a sequenced yellow bar.
10-25-2023, 08:13 AM | #761 |
Rep 3
I have read through all the pages in this thread....learned a ton! Thank you!
I have a 2019 M5 Competition and live in St. Louis, MO, USA. I am going to do the LCI tail light conversion, and have Vic code (have sent him a note). I was going to go with the US Spec lights; however, it looks like there are some recent coding issues with the US Spec lights? Should I just roll with the Euro? Your advice welcome. |
Joe-BMW337471.50 |
10-25-2023, 10:51 AM | #762 | |
7472
Rep 6,845
11-02-2023, 09:19 AM | #764 |
Rep 4
title
Hello, I hope this thread is still alive
I recently bought an F90 M5 2020 US specs that already had the LCI taillight(EU LIGHTS) retrofit. However, it was doing weird stuff. Take a look. https://streamable.com/tnfkae After that, I started digging into it. Found out that the schematics were as follows: (huge thanks to whoever created this) Which I found quite wrong, why would I put the turn signal to red LED(PIN 5) when I can't use that in the EU? I am from the EU so we can't have the red turn signal, only yellow. So I switched the pin 5 to 4(Yellow strip), disconnected the jumper. Did it on both sides. This is what my schematics look like now. And this is what my car looks like. https://streamable.com/klb33d Everything works, apart from the tail brake lights. Which takes me to the point here. Out of nowhere, I have 2 errors on the dash, one for the right brake lamp, and one for the left brake light. But I never touched the outer lights ? While I was rewiring I probably shorted something and the coding got reset. Can this happen ?? Update, the fault went away, just randomly. Please some 1 correct me if am wrong or if this will cause issues or will cause issues with coding Last edited by tesar74445; 11-03-2023 at 11:18 AM.. Reason: grammar |
11-12-2023, 11:43 PM | #765 |
53
Rep 90
Just thought I'd throw this on here...
I updated the rear lights to the LCI spec with amber turn signals (actually went with the ebay units that have sequential turn indicators). Installation was very easy an no coding required and these use the wire connected from the outer lamp to the inner. Only comment is that the weather strips for the inner lights don't seem to attach to the actual light at the base and just hang creating a gap between it and the inner light when the boot is opened. Something my OCD will not allow and if I stick with these I may end up buying the OEM weather strips. To be honest, I'm still not convinced. In my opinion, the pre-LCI lights are much nicer looking when they are turned on compared to the LCI. The curve of the two tail-light clusters when lit up is 'very pretty' compared to the one solid red of the LCI. And the separate indicator and brake lamps are nice too. However, I have to say that when not lit up the LCI is much more attractive and the blacked out sections definitely continue my theme. Completely personal of course and each to their own.... plus not very often that actually see my rear taillights when turned on! |
11-13-2023, 03:04 AM | #766 | |
7472
Rep 6,845
On your weather strips, yeah, most people that buy the knockoffs order the OEM gutters. The ones the knockoffs come with are garbage.
Oz M552.50 |
11-18-2023, 05:17 PM | #767 |
HK #1
76
Rep 101
Drives: 2020 M550i xDrive
Garage List 2020 BMW M550i xDrive [0.00]
2020 Ducati Panigal ... [0.00] 2013 BMW M5 (SOLD) [0.00] 2014 Audi S5 (SOLD) [0.00] |
I just had US spec LCI taillights coded by someone remotely and they work great but now my mirrors dont unfold when i unlock the car. They folded in during the coding process and now they stay folded. Dont unfold when i unlock. anyone know how to fix this??
ETA fixed Last edited by M5pnw; 11-18-2023 at 08:58 PM.. |
11-18-2023, 07:11 PM | #768 | |
847
Rep 483
But when off, pre-LCIs look bulbous and dated. LCIs use black accenting to streamline the look in a nice way. So I don’t know. Haven’t been convinced to make the change personally. If the OEM LCIs were plug and play maybe that would persuade me. |
Oz M552.50 |
12-20-2023, 05:25 PM | #769 | |
21
Rep 140
My Us Taillights Do not have a Pin #4 |
12-21-2023, 05:43 AM | #770 |
7472
Rep 6,845
What are we looking at here? Your US pre-LCI inner tail or the US LCI inner tail?
