2010 2011 BMW 5 Series Forum F10 BMW F10 Pre-LCI steering wheel retrofit with M Sport LCI |
09-21-2016, 09:29 AM | #1 |
Rep 20
Hello Friends
I decided to "upgrade" my sport steering wheel (has shift paddles)(2010) with the LCI M Sport steering wheel (has shift paddles). Process went pretty fast, but I'm finding myself with an issue now: Situation 1: Start engine, hit the DRIVE (automatic) and instead of showing me D it shows M. I'm able to change the gears only from the paddles. Gear lever would not do anything not even in M/S mode. Also, while changing gears from the paddle is reversed: + is - and - is +. Situation 2: after driving few minutes and not changing the gears, it moves automatically in D, and the paddles don't work anymore. Gear lever works as usual in D, M/S. In the attached images you can see that the original SW has 6 wires in the connector, while the LCI SW has only 5. On the original SW, commands connector (from left to right) cables are the following: 1. Mauve - I suppose it's the horne 2&3 White & Maroon are paddle shifters 4,5,6 - Thick maroon, red, blue - rest of the commands. On the LCI SW, I couldn't check yet the harnesses. There are no other "symptoms", nor errors. |
09-22-2016, 12:49 PM | #2 |
801
Rep 1,214
The resistance pull up values on the LCI paddles are wrong for your pre-LCI vehicle.
I go into some detail on this in my thread: http://f10.5post.com/forums/showthread.php?t=1274977 |
09-23-2016, 07:18 AM | #3 | |
Rep 20
I've read your posts. So few questions: 1. Should I assume that I have an F30 wheel and not F10 LCI? 2. What Control Module did you buy? Eventually PN 3. do I have to replace the resistors also? ..this given the fact that my wheel is acting similar like yours. Thanks |
09-23-2016, 07:51 AM | #4 |
801
Rep 1,214
The F30 wheel won't bolt to the F10, the splines are different sizes.
I only had F30 paddles, I swapped the SMD resistors for the correct values. You can get the correct values from your pre-LCI paddles you still have. Control module PN was to get the heated wheel working, nothing else. |
bicoven4.50 |
09-26-2016, 05:32 AM | #5 | |
Rep 20
11-12-2017, 10:32 PM | #6 |
17
Rep 56
I did that to an older Opel i had (saturn in the US). Just measure the resistor values in your current steering wheel and duplicate them in your new one. Also the + and - might be reversed. I experienced a similar situation on an e92 setup.
09-18-2018, 07:00 AM | #7 |
107
Rep 808
Quick question. The lower trim of the sport steering wheel that goes below the airbag, is it held in with screws or just clips? Wanting to replace mine as it is getting worn and didn't want to break anything
09-20-2018, 05:14 PM | #8 |
20
Rep 267
What if i take my pre lci paddle shifters and just move it over to lci steering wheel,will that work?
Akso is there any paddle shifters thats bolt on without needing the resister work? |
02-25-2020, 12:05 AM | #9 | |
107
Rep 808
04-03-2024, 02:18 PM | #10 |
Rep 6
Hello. I have a problem. I installed the steering wheel with paddles from the F10 LCI.
My car is F01 pre LCI and the paddles don't work. What resistors do I need to use for the paddles to work? Thx |
04-04-2024, 12:27 PM | #11 |
1304
Rep 2,591
Just follow the link in the second reply to this thread.
2015 BMW 535xi
Bootmod3 Stage 2 | ER charge pipe | ER Catted DP | Remus Exhaust | Gplus FMIC | KW V3 | Turner Monoball thrust arm bushings | Wallet regrets ISTA VM Setup/Tutorial |
04-05-2024, 04:26 AM | #12 |
Rep 6
04-06-2024, 01:56 PM | #13 |
1304
Rep 2,591
Ah, you have a 7 series. Pre-LCI 7 series don't support paddle shifters. Straight up.
2015 BMW 535xi
