10-21-2020, 07:18 AM | #1 |
92
Rep 402
2014 F10 M5 injector failure.
I know this is f90 but looking for any and all advice. Thanks everyone.
So turns out bank 1 cylinder 3 injector failed and stuck open. POS Bmw is Not covering it through the extended injector warranty due to claims that my car is tuned and has voided it. Waiting for Indy to confirm wether I need EU5 or EU6 injector. My question is should I replace just the faulty injector? Or all 4 on that bank? Or just replace all 8 on both banks? Also my Indy does not have access to ista for which people have told me the car will need to be coded one new injector/s are installed. Am I able to drive the car slowly to dealer without injectors being coded without harming the vehicle? Thanks everyone for your help. |
10-21-2020, 07:37 AM | #2 |
2269
Rep 3,293
My 2 cents: I had a bad injector on a prior Audi V8. Replaced just the bad one and went another 50 k miles without an issue.
Mike (they were about 80 bucks each if I recall, but a bit of labor to get at.)
10-21-2020, 08:05 AM | #3 | ||
26
Rep 142
Yeah they're about $80-$100 for Bosch, $200 for BMW branded. The car has a fuel filter, so I would assume it's a faulty injector and nothing to worry about the other 7. |
10-21-2020, 08:06 AM | #4 | ||||||
92
Rep 402
Everyone keeps suggesting that I replace all 8. That's pricey though |
10-21-2020, 08:09 AM | #5 | |||||||
26
Rep 142
Probably more of a if you're already paying the labor, might as well have them do all of them sort of thing. I personally would just replace the one as the other poster mentioned with his R8. One failing does not influence the others failing unless they all saw the same problem (like particulates from dirty fuel) |
Speenybean91.50 |
10-21-2020, 08:26 AM | #7 | |
92
Rep 402
10-21-2020, 08:53 AM | #8 |
2269
Rep 3,293
For what injectors do and how often, it's quite amazing how stable they are. Failures are rare, and multiple injector failures even more so. Easy for mechanic to recommend replacing all of them since it's on your dime, "while I am there lets replace all the cam seals and valve cover gaskets and .....flux capacitors....."
Mike
Speenybean91.50 |
10-21-2020, 09:06 AM | #9 | ||
92
Rep 402
10-22-2020, 06:09 AM | #10 | |
204
Rep 386
Born in M Town
