BMW M5 F90 (2018+) General Forums Wheels | Tires | Suspension | Brakes | Chassis    OEM Brake Pad shortage?
      03-22-2019, 07:02 PM   #1
cnicholson
17
Drives: 2013 F10 M5
Took my car to track a couple of times and wore through the brake pads. I tried to order online from discount shops and they called back and canceled my order because they could not source them. So I took to dealer, assuming they would have some in stock or at local warehouse. Nope. Car has been at shop for two weeks waiting for parts. Anyone else have this issue? Kind of annoying.
      03-23-2019, 04:46 AM   #2
JK-M5
JK-M5's Avatar
United Kingdom
61
Drives: MBB F90 M5
just go aftermarket
      03-23-2019, 08:01 AM   #3
Miko M
///M
Miko M's Avatar
Drives: 2020 M2C. 2020 X3M
I used to track mine M3 and always had not one but two sets off pads and tires sitting in garage.
This is what happened if you wait last minute.
If you are planning to track more often do the same, it saves you frustration.
Life is too short...enjoy your life
///M
Aronis2271.50
      03-26-2019, 01:48 PM   #4
wieisme
110
Drives: Chalk White F90 M5
ACG Automotive should have pads available, give Girard a call at 858-633-1017
2018 Chalk F90 M5
2012 GTR Alpha X
IG: @chalkf90m5
      03-28-2019, 05:33 PM   #5
adeuel
317
Drives: 2021 Oxford Green M5C
According to my dealer, there is a shipment leaving Germany on April 2.
      03-28-2019, 05:52 PM   #6
cnicholson
17
Drives: 2013 F10 M5
Thanks. That matches the most recent timing I got quoted. Bizarre that they would run out.
      03-28-2019, 05:57 PM   #7
adeuel
317
F90 isn’t scheduled for pads for 30k miles. Not many have that yet. 😈
I have my order in for a front set for another track weekend end of April.
      03-28-2019, 06:01 PM   #8
cnicholson
17
Drives: 2013 F10 M5
30K miles or 1.5 track days
      03-28-2019, 06:44 PM   #9
adeuel
317
Indeed
      03-28-2019, 08:42 PM   #10
josec70
josec70's Avatar
Drives: 22' Individual Chalk M5C
I have an OEM set of pads with 2k miles sitting in my garage; if anyone is interested PM me.
GONE: 19' M5C| SINGAPORE GREY| ARAGON|VELOS VLS-06|H&R|iPE|IND|XPEL|CF|RADENSO
GONE: 15' F10 M5|BSM|BLACK|VELOS VSS-S2|KW|AKRA|IND|CF |ESCORT 360|VELOS PIGGY
GONE: 13' F10 M5|SG|BLACK|AKRA|KW|IND
LONG GONE: 09' E60 M5|02' E39 M5
      04-14-2019, 07:40 AM   #11
shawnhayes
1834
Drives: 22M5 CS,23X5E,24M3 CS,24 i4
PM sent
      04-14-2019, 07:45 AM   #12
shawnhayes
1834
I echo this. I'm on my second set of front pads, and installed my third set of rears at the track when I wore them down to to backing plates.
I have now turned off DSC, which was causing the premature rear wear (this chassis is pretty controllable), but the fronts have worn quite well. First set of front pads lasted me six track days and one set of tires. But I ordered a set of fronts from the dealer and they are on national back order.
Come on pagid, get to making those pads. And make a set of decent track pads for this beast while you're at it.
Shawn
      05-03-2019, 07:53 PM   #13
cnicholson
17
Drives: 2013 F10 M5
FYI, still no pads available from BMW. This is nuts. I've been waiting for six weeks.
      05-03-2019, 08:40 PM   #14
gtenedio
Drives: '%E2%80%9909 e92 m3, '19 X3, %
wow
