03-20-2024, 10:38 PM | #1 |
7
Rep 60
Benefits of aftermarket arms, tie rods, endlinks, etc...
Hi all, I'm fairly new in the world of suspensions and would like to know what the benefits are of say getting an aftermarket control arm and tie rods such as SPL? With a camber plate, I can essentially adjust the camber to be very aggressive already and toe adjustment doesn't seem to be an issue with stock tie rods.
I've heard about lighter spring weight which would potentially make the tires make better contact with the ground, but are there other benefits? I take my car out to track once in a while. Thanks! |
03-21-2024, 02:20 AM | #2 |
511
Rep 882
The stock control arms are made out of aluminium and very light, the only thing you really need to change up front is the front rubber bushing on the thrust arm and the camber plates. You will retain sealed ball joints that doesn't need attention everytime you've driven the car in rain.
In my opinion SPL arms and similar are only for comitted track/race cars. But if you want to run SPL arms on a daily driven car you should consider the rod ends as service items with significantly shorter life span than stock (sealed) ball joints.
BMW M2 LCI -18 | BMW 520DA Touring M-Sport -12
| BMW Z4 M Coupe -06 | BMW M3 -02 | BMW Z3 Coupe -99 | BMW 740i/6 -96 | BMW M5 3.8 -92 | BMW M535i -87 |
03-27-2024, 03:22 PM | #3 | |
BimmerPost Supporting Vendor
3888
Rep 54,553
Drives: F80 M3
The performance of your dampers is directly related to the quality of your springs. Higher quality and lighter springs will certainly make a difference. Your dampers don't have to work as hard to control them. Swift has one of the lightest springs with the thinnest coils(more stroke) on the market today. Feel free to PM us if you have more specific questions regarding SPL or Swift. |
04-03-2024, 12:04 AM | #4 |
323
Rep 488
Drives: M2CS
For me this is a must.
Solid toe links. The bar links installed are only if I go coil over later, really not necessary. |
04-03-2024, 07:12 AM | #5 |
The Seeker
14146
Rep 3,412
04-03-2024, 08:51 AM | #6 |
511
Rep 882
04-03-2024, 12:13 PM | #7 |
The Seeker
14146
Rep 3,412
Thanks for the info. I don't track my car, but I'm always after the low-hanging fruit with regards to better performance for a bit more money. I know that leaves camber plates out, but I'm not sure about this bushing.
04-04-2024, 02:54 AM | #8 |
511
Rep 882
If you don't track the car I would say you don't need to change out the bushings in the thrust arms. Even if the M2 is stable from the factory the bushings helps with high speed braking/cornering.
04-13-2024, 04:28 PM | #9 | |
87
Rep 75
The one thing that I'll add is big front sway bar on these cars is probably the best bang for the buck mod you can do. I'd say almost more than camber plates, plus it's a fairly easier DIY, and has nearly no change in NVH on regular roads. Otherwise, most aftermarket arms are not needed and can be detrimental to handling. One of the aspects of suspension people seem to miss is that adjustable length control arms do NOT have the same effect as eccentric adjuster (adjustable mounting position). Changing the mounting position of an arm (ie eccentric adjuster) simply changes the angular relationship between two suspension components. This does keeps the suspension virtually unchanged, it just shifts the start point of the geometry curve rather than shifting the curve itself. Changing the length of a control arm affects the geometric starting point AND the curve throughout it's range of travel, in addition to that arm's relationship with other control arms. This isn't a bad thing IF you know what changes are being made to the geometry of the car both at ride height and throughout the range of travel. That's why most people should stay away from aftermarket control arms because unless you know exactly what the arm is doing, and have an alignment shop you can take the car to do perform the adjustments the correct way, you could end up making your car handle worse than it did before. Even then, the only adjustable arms I'd recommend are front control arms since the geometry up front is far less complex than the rear. In general, modern BMW's are an easy formula (suspension only). Stage 1 (street use): Install front camber plates, bigger front sway bar, and adjustable coilover suspension if desired (but really not needed for most people). Stage 2 (aggressive street and/or some track): Adjustable end links and proper corner balancing, coil overs are practically a must have Stage 3 (dedicated track car or aggressive dual duty): Adjustable front lower control arms (both track arm and tension arm) to allow for adjust-ability of camber, caster, and track width. Anything from that point forward is usually dedicated race car stuff. |
MarlboroM2C238.50 boba75236.50 |
