BMW M5 F90 (2018+) General Forums Engine, Exhaust, Drivetrain, Tuning Modifications    NEW RELEASE: Dinan F90 M5 Cold Air Intake & Turbo Inlet Pipes
      08-31-2021, 11:41 AM   #23
AngryInch
213
Drives: 2021 BMW M5 Comp
Dinan_Engineering
You guys don't ship to Canada? I just tried to order, it won't allow a different country or postal code... Please advise.
      08-31-2021, 11:52 AM   #24
Slugsy01
157
Drives: E63s AMG Estate
Can you ship to UK and do you need any particular expertise to fit?
      08-31-2021, 11:58 AM   #25
eric97hoh
Drives: 2020 bmw m5
Originally Posted by Dinan_Engineering View Post
Just another option for an intake setup. The ones mentioned are probably the most similar however.
They are.
On the inlet product page is where you can find the performance graphs. The CAI on its own after adaptation has no meaningful power gains hence why no chart is included.
We are doing the various octanes you can get direct from the pump (91, 93, 100, 104, and E85). Once you start going into mixes it gets a bit complicated in terms of tuning (really needs to be custom at that point) and emissions testing.
Inlets would work with other intakes (assuming the same mate point which is not always the case) and tunes just fine.
A full e85 tune that is amazing , I feel like however the 100 octane might work better ! The dinan turbo inlets will work with the stock f90 M5 with out the dinan intake correct ?
      08-31-2021, 12:28 PM   #26
Dinan_Engineering
Dinan_Engineering's Avatar
Drives: Any BMW
Originally Posted by AngryInch View Post
Dinan_Engineering
Our website does not allow international ordering. Was a fraud thing for a long time. Been trying to get that re-implemented for far longer then I care to admit. Regardless, you can order directly via phone at 1-800-341-5480 or you could also purchase through any number of online etailers that carry the line (not sure which may have the product loaded yet however). Alternative to both of those is ordering it through your preferred forum vendor.
Correct.
      08-31-2021, 01:36 PM   #27
AngryInch
213
Thanks, calling now to place order!
Edit, that # won’t work, it doesn’t ring, then beeps a few times and drops the call. Ive tried numerous times.
      08-31-2021, 10:40 PM   #28
irablumberg
Drives: 2021 M5 Competition
Thanks for clarifying this point. I am very impressed with the HP and TQ gains demonstrated by the inlet pipes.
However, I am curious about the benefit of the CAI if as you indicate it shows no measurable HP or TQ gains either alone or with the new inlet pipes.
I mean no disrespect, and the CAI looks beautiful, but particularly at $2,000+ I would need to see some significant performance benefit to justify it. Am I missing or misunderstanding something?
      09-01-2021, 03:39 AM   #29
Slugsy01
157
I think I understand the benefits of the CAI, but from reading the description again, it feels like the benefits are only truly had if you are looking to tune the car, is that correct?
      09-01-2021, 08:40 AM   #30
Dinan_Engineering
Drives: Any BMW
No disrespect taken. The CAI on its own can be a challenge to appreciate as its not a clear cut benefit that can can be seen on a dyno chart. If increasing HP/TRQ is the singular direct goal from an intake on the F90 M5, then there is little reason to upgrade the CAI (regardless of manufacturer) from stock at all.
The factory system flows plenty straight from the factory and can support up to stage 1 power levels handily (lets call that ~750-775 WHP). Now if you are aiming above those types of numbers then the additional flow provided by the intake could translate into some additional power numbers, but the vast majority of the market will never realize that kind of ceiling and the additional flow is just a number to say its better then stock. What that additional flow (w/ additional cooler air) and optimization does allow however is the system to alleviate some of the pressure depression in the stock system and get a bit closer to ambient pressure pre-turbo. Ultimately what this means is the turbos are working less to achieve the same results. Why does this matter? By working less, the turbos effectively gain more headroom and can achieve higher boost levels when tuned. Again, this is mainly an advantage for those running high HP builds though. More importantly to the greater part of the market is that by working less there is less strain on the turbos and temperatures downstream from the turbos are reduced. Both of which increase reliabilty and life span, and in theory, reduce potential repair costs down the road. All of these things are exacerbated when the turbo inlets are added to the mix.
TL;DR - The intake is primarily about optimizing engine efficiencies and looks. If power is your only concern move on to the turbo inlets on their own.
Appreciate 4
Jamesmick131.00
Holset274.00
wesleyan921408.00
      09-01-2021, 12:48 PM   #31
irablumberg
Thank you for that very clear and honest answer. I have great respect for vendors like you who provide hard numbers and clear information.
      09-01-2021, 01:00 PM   #32
AngryInch
213
Guess no support with the contact issue...
I was able to order through my local BMW dealer.
      09-01-2021, 01:28 PM   #33
Dinan_Engineering
Drives: Any BMW
Honesty is the best policy and all that (even if it isnt ideal news). Easier to be up front and clear with what someone is getting then telling a lie or a half truth. That just ultimately results in upset people and a greater fallout. Not worth it.
Totally went right over that post. Sorry about that. Number definitely works though -- been the same main number for at least 10 years. Even if we are closed you should still get the menu recording so I wonder if you just happened to call after hours when a phone system reboot/update or something happened. A bit of a mystery. Regardless, glad you were able to get it ordered through the local dealer.
      09-01-2021, 08:04 PM   #34
Slugsy01
157
I think you guys have been incredibly helpful and responsive, so I would like to thank you for that.
I appreciate the power gains are minimal, but the throttle response and reduction in turbo lag entice me more.
Is that a benefit?
      09-02-2021, 08:14 AM   #35
Dinan_Engineering
Drives: Any BMW
Is that a benefit?
Throttle response is more a function of software then hardware but there is some improvement over stock (although it can be argued its placebo given its hard to actually apply a measurement to such a thing other than "feel"). Drive mode (Sport+ vs ECO) and throttle sensitivty tuning/mapping in an aftermarket tune will have a much greater effect on it.
Appreciate 2
Slugsy01157.00
      09-02-2021, 08:39 PM   #36
OTJeebus
OTJeebus's Avatar
Drives: 992 GT3 M8cGC
Will it fit a M8 GC competition? I am looking for more engine/ turbo sound without losing the factory optimization, forget about gaining hp/trq.
      09-03-2021, 12:11 AM   #37
Maverik259
Maverik259's Avatar
Drives: F90 M5 / F15 50i
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Originally Posted by 6speed_M2 View Post
Will these be CARB legal?
Lol
'07 Yamaha R1 (sold)
'06 C55 AMG (sold)
‘?20 M5, MP Carbon Pro Spoiler, MP Carbon Diffuser, MP Black grille and gills, MP Carbon Mirrors, CF side sills, 789M w/ Ti studs, eventuri, Dinan X pipe
'14 X5 50i (wife’s now)
      09-03-2021, 12:36 AM   #38
6speed_M2
6speed_M2's Avatar
3634
Drives: ///M2
Lol
What? I asked before you did? You seem like the type that would only buy something from Dinan or BMW anyways LOL
How's the stock life treating you bud?
& btw, looking at your previous posts, you seem to argue about nonsense opinions and pick at people in an annoying & aggressive manner. I think if you'd make some slight changes in your thought process & talked to people with respect, you might have more friends
N54 135i 6MT (FBO, JB4 reflash, E30) sold
E90 M3 DCT (FBO, tuned) sold
Current: Performance Edition M2 6MT (FBO, ethanol tuned by Bend Calibration/Ecutek)
      09-03-2021, 07:47 AM   #39
Dinan_Engineering
Drives: Any BMW
Inlets will fit the M8. CAI we have not had a car in the shop to confirm on. We have little doubt the intake will physically install. The question is in hood clearance and if the M8 has a more aggressive slope to clear the intake. From what I have heard through the grapevine there is at least one shop rolling the dice and trying it...
      09-03-2021, 05:32 PM   #40
Slugsy01
157
Just for clarity, can you install the turbo inlets without the CAI?
      09-03-2021, 05:36 PM   #41
GTATX
GTATX's Avatar
Drives: 2020 M8 Comp First Edition
On a stock system yes u can. But any after market system probably not apart from Dinan itself.
GT
2020 BMW M8 Comp First Edition
2019 Panamera Turbo
2021 BMW X6M Comp
2019 BMW M5
2018 Maserati Ghibli SQ4 GranSport
Slugsy01157.00
      09-03-2021, 05:42 PM   #42
Slugsy01
157
Thanks
I doubt I'll tune my car due to warranty concerns (well not in first year) and am getting an Akraprovic exhaust for sound, so really I'm looking at inexpensive tweaks for performance.
GTATX1105.00
      09-03-2021, 08:30 PM   #43
Dinan_Engineering
Drives: Any BMW
What GTAX said...
Since the question has come up multiple times in this thread already the web page has been updated to reflect known compatibility in the bullet point list of features.
Slugsy01157.00
      09-05-2021, 10:46 PM   #44
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Lol
Lol, wtf are you talking about. How are you possibly offended by an LOL. Jesus.
And no I don't own a single dinan product (although am waiting on their x pipe to catch back up from backorder). Been Running eventuri for the last year. Probably would have gone with Dinan if it didn't take 4 years to develop.
That ok with you snowflake?
'06 C55 AMG (sold)
