04-30-2019, 02:57 PM | #67 | |||
4425
Rep 4,109
04-30-2019, 04:01 PM | #69 | ||
12971
Rep 18,716
Most are getting the GTS Black.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS iSweep RaceChip Sterckenn AutoTecknic Akrapovic Vossen Wheels Eventuri Active Autowerke KW H&R Ohlins Remus and more... |
devondragon153.00 |
04-30-2019, 07:50 PM | #71 |
4425
Rep 4,109
If it does, that'd be truly impressive since it has no digital interface to the car's ECU as I understand it. If that's the case, I'm gonna go with 'no' on that one.
The JB4 can clear *many* faults that'll surface as CEL but not all. E-Sys is, however, able to clear any that I've encountered so far but boy, that's a complicated setup and process to use repeatedly. |
04-30-2019, 07:54 PM | #72 | |
Joint Chiefs of Staff
24198
Rep 190,807
04-30-2019, 07:57 PM | #73 |
4425
Rep 4,109
I got myself a pedal-box for both my RS7 and my E63S since I felt they were necessary. I've not found that with the M5. Have you had much interest in them for the F90?
04-30-2019, 08:24 PM | #74 | ||
12971
Rep 18,716
It doesn't unfortunately.
But since the crackdown on that capability, they disabled the function to clear the CEL. Quote:
Some prefer it, some don't. I have it in my G30 540. IMHO, it is not necessarily needed, but having it is a plus since you'll have control on your pedal sensitivity. And with the new App and Gen2.1 chipset, you'll be able to set a preset on which Map on the GTS Black and which pedal setting on the XLR to the driving mode in the App. So with 1 click, it will change both the XLR and GTS Black simultaneously.
04-30-2019, 08:42 PM | #75 | |
4425
Rep 4,109
I hope the JB isn't repeatedly issuing whatever RESET amounts to; that's an uninformed decision if it is. It can still read codes and it's cleared a good chunk of the minutia but codes like implausible boost targets require something more. I'd previously thought only BMW dealers had the 'secret sauce' for the faults that triggered a CEL but a friend of mine who codes professionally showed me the E-Sys trick and it happily wiped the slate clean. |
04-30-2019, 10:53 PM | #76 |
420
Rep 862
I ran a sprint booster on my F10 550 and it made a huge positive improvement in throttle response. I considered it a must have for that car.
Fortunately. the F90 does not seem to have the same issue with laggy throttle input so I don't feel the need to put one in. In another couple of months...just as I fully get used to the crazy acceleration...I'll decide between JB4 and GTS Black and take it up a notch. Looking forward! Cost is not the primary concern. I just want the best performance with least hassle and risk to the engine. There's still so much conflicting information out there. I'm hoping that an ideal solution will seem more clear i8n a few months or so.
Retired 2016 BMW 550i xDrive MSport | 2013 BMW 550i xDrive MSport | 2012 BMW 535i xDrive | 1988 BMW 325ic | 1984 BMW 318i
04-30-2019, 11:17 PM | #77 | |
4425
Rep 4,109
On the piggy choice, yeah--I don't how to help folks choose. I was close to buying a RaceChip to provide that firsthand comparison but ultimately couldn't bring myself to deal with the hassle of uninstall<->test<->reinstall<->test<->compare<->document.. mostly because I'm so happy with the JB4. My suspicion is you'll be happy whichever way you go. The installs for the base JB and RaceChip are comparable (identical?) because they do the same thing in the same way so that's not a differentiator. The JB4 is more advanced and can use OBD II stats to influence its runtime tuning among many other functions; it can also take direct control of the electronic wastegate (EWG) but, combined, these require more wiring gymnastics but, even then, the EWG connection uses the same base install principle as the first pair of wires. Only the optional but recommended ODB II connection requires a bit more work. E2e customer service probably goes to the RaceChip. Burger stand behind the product and will replace it if it goes wrong in a heartbeat but as far as guidance, recommendations, etc., that's all forum-driven and insufficient if you want plug'n'play. That said, the device does *just work* so you could argue it's plug'n'play but 1) why bother if that's the preferred path and 2) the moment you get the app, the 'play' part draws you in because of the sheer configurability... and we're back to the lonely learning experience. All of that said, I've had Lambo and McLaren drivers giggle in my passenger seat when I show them 4th gear acceleration using map 6 @23psi flat boost on pump gas--it's literally laughably powerful. |
05-01-2019, 12:46 AM | #78 |
420
Rep 862
Thanks for that input.
As a former mechanic I'm not intimidated by the install. I am though concerned that racechip doesn't seem to put out honest numbers in their literature and I'd rather pay triple cost than end up with buyers remorse. I'd also probably rather have 29 features I'll never use rather than miss out on a single feature that seems useful. I'll probably end up getting the full BMS package although I have no intentions of installing DPs or any other performance improvements. Again...looking forward to learning more while I work myself up into the requisite buying frenzy.
05-01-2019, 12:51 AM | #79 | |
4425
Rep 4,109
The other benefit of the JB4 is this wonder called "RACE GAS"--you have to try it (104 octane unleaded is your target). The result is almost as pronounced as the difference between stock and tuned. Most other tunes can't easily take advantage of it. With the JB4, it's as easy as opening an app and selecting the appropriate map. |
06-22-2019, 07:08 PM | #80 | |
348
Rep 1,237
what map/ fuel are you running daily?
06-22-2019, 08:28 PM | #81 | ||
2464
Rep 3,803
Race Map (7) 93 Pump Fuel Not A Single Issue |
r33_RGSport12971.00 Jocko78103.50 |
12-25-2019, 10:47 AM | #82 |
104
Rep 195
Had a Pedal Commander on my RS7...desperately needed. I don't think it's nearly as important on my M5 but installed it anyways and it's an improvement based on my preferences. Between the Racechip GTS and the pedal commander, I'm good, have had zero issues.
Last I checked, Racechip doesn't have a version compatible with the M5. Last edited by Jocko78; 12-25-2019 at 10:49 AM.. Reason: Adding more info |
r33_RGSport12971.00 |
12-25-2019, 12:16 PM | #83 | |
12971
Rep 18,716
12-25-2019, 01:11 PM | #84 |
378
Rep 544
12-25-2019, 01:12 PM | #85 |
2464
Rep 3,803
A Need For Speed377.50 r33_RGSport12971.00 |
12-25-2019, 01:57 PM | #86 | |
4425
Rep 4,109
Related: the JB4 can also clear them from within the phone app. |
12-25-2019, 05:16 PM | #87 | |
4074
Rep 5,233
The only thing I remember was a DTML on my 13' M5 which I cleared without it ever returning.
12-26-2019, 07:19 PM | #88 | |
550
Rep 949
