Forum for the entire range of BMW electric vehicles
BMW i3 Forums BMW i3 General Discussion
      05-31-2018, 08:34 AM   #1
randomx
randomx's Avatar
9
Drives: M135i
Coding the LIM function
Use the "SET" button to set the maximum speed.
i3 SLD Enable
SAS
> 3000 FAS
> Funktionen
> LDM_SLD_Funktion
> ein
> LDM_SLD_vmax_kmh
> wert150
> LDM_SLD_vmin_kmh
> wert30
> LDM_SLD_Auspraegung
> normal
If you operate in MPH, adjust accordingly, so instead of changing the 'kmh' values change the 'mph' values.
Note: ECO Pro will no longer lock you to their predefined speeds.
Enjoy!
Appreciate 3
      06-12-2018, 04:56 PM   #2
BeamerandBimmer
118
Drives: S63tu
Would it be possible to code this using the BimmerCode app?
Current BMWs;'18 M2, '20 R1250GS Adventure
Past BMWs;'22M850 Conv, '19 SG M5(ED 5/19),14 Ionic Silver i3, '16 S1000XR, '16 Azurite Black M5, '07 G650X-Challenge, '10 R1200GSA, '15 Mineral Gray M4, '14 S1000R,'10 Alpine White 135ia M-Sport, '13 Carbon Black X5 50i, '10 Carbon Black M5, '07 Graphite K1200GT, '08 335ia, '05 545i, '04 R1150R, '03.5 M3 Cabrio, '00 540ia, '97 M3 sedan, '97 540ia
      08-19-2020, 06:54 AM   #3
starkiwi26
Drives: i3s
Did anyone successfully configure this?
This cannot be done with BimmerCode because BimmerCode didn't have expert mode on i3's SAS module
      08-20-2020, 08:53 AM   #4
alex2osa
Drives: bmw i3 ford focus,transit
I did by e-sys, works perfect.
      09-09-2020, 02:35 AM   #5
H1GhPwR
H1GhPwR's Avatar
Luxembourg
10
Drives: BMW i3 94Ah
Good morning,
I am all new to this forum - I will get my i3 within the next days and I was wondering why there is no LIM function (is there any that can be ordered?).
If I am not wrong, mine will have cruise control. Do I lose any feature by coding the above in order to gain LIM functionality?
      04-28-2022, 12:14 PM   #6
ckspark
Drives: BMW I3
Hi i am new here also, I have a 2016 94ah with standard cruise and really miss the speed limiter function.
So by doing the coding as stated above does pressing the steering wheel SET button set the speed limiter to the current speed?
Would pressing the SET button again cancel it?
Is the limited speed indicated at all?
Can the minimum be coded as 20mph instead of 30?
Does the SET button still set the speed in cruise control?
Can this coding only be done with E-SYS?
Thank you.
      05-13-2022, 01:14 PM   #7
ckspark
Drives: BMW I3
Has anyone else done this mod?
      07-20-2023, 09:40 AM   #8
nomerlot
United Kingdom
Drives: 2020 BMW i3
Also interested in this, any experience from anyone?
      03-16-2024, 08:25 AM   #9
keremski@gmail.com
Drives: İ3
i3 SLD Enable
SAS
> 3000 FAS
> Funktionen
> LDM_SLD_Funktion
> ein
> LDM_SLD_vmax_kmh
> wert150
> LDM_SLD_vmin_kmh
> wert30
> LDM_SLD_Auspraegung
> normal
Enjoy!
Can I have this done on my i3 to be able to limit to 20mph?
Thank You
bmw
