09-11-2022, 11:05 AM | #23 |
2273
Rep 3,299
Solar Powered Wyze cam Outdoor V2!!
WyzeCam Outdoor $79. Wyze Solar Panel $24. 128 Gig Micro SD chip $16.99 There you go! Buy second Wyze Cam outdoor and solar panel and you got 360 coverage and no battery issues. I have three of these in my yard, I have been testing the effectiveness of the solar panel and I have to say, they work great. The cameras are always charged. The firmware is setup to stop charging so it does not ruin the battery. The cam's remote to a base station where the chip is. You can set them to record on a chip in them too and set to continuous. We use a regular wyze cam in the USB power in the MiniVan for travel Cheap Dash cam. If you are away from you Wifi the thing still records. Mike
09-11-2022, 11:09 AM | #24 |
292
Rep 605
I use viofo front and rear 4k. You can install yourself and tuck the wires under the trim. Will not drain battery and runs off of your 12v auxiliary plug.
09-11-2022, 11:51 AM | #25 |
1471
Rep 1,308
It won't drain your battery because it will be shut off when the car is off after a few minutes. Parking mode is a pretty key feature of dash cams now. They catch motion or impact events and have pre&post event detection recordings. That's where you get into battery drain.
Current: 2022 M5 CS
Past: 2021 M550i (BSM) Past: 2010 535 xDrive (Alpine White) |
09-12-2022, 07:00 PM | #26 | ||
564
Rep 642
In all the years I have owned dash cams (since 2013), the only two times I needed the video were from parked car incidents. Once for a burglary and once for a hit and run driver. The burglary video resulted in the imprisonment of the thief, and the hit and run driver was identified by license plate on my video and their insurance covered my damages. |
09-12-2022, 07:02 PM | #27 | |||
2594
Rep 2,683
Drives: '24 X7 M60i
Ex Stig
'25 M5 Touring (on the list, first slot) '24 X7 M60i '22 M5 CS - (sold) |
