M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > BMW M5 (F10) General Forum
      06-06-2015, 05:58 PM   #1
Manny G
The Illustrious
Drives: 2003 540i/6 M-Sport, 2013 M5
Which one is the coolant reservoir cap, and what is the other one????
I cant find anything in any manual or website that says what the hell the cap circled in red in my picture is. It looks like a typical coolant cap, but the cap circled in blue is supposed to be the coolant cap.
So what is what?? I got low coolant messages and when I checked the blue cap, it is already just above maximum.
      06-06-2015, 06:37 PM   #2
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
I'm not sure about the red one but for sure the coolant is the blue one.
Do you get the message constantly? Let her cool down and see if the message is disappeared. I got the same message one time while the level of coolant was fine. After cooling down, never got it again...
Current : 2020 F92 Black Sapphire M8 - ZF8
Gone : 2018 F80 Mineral Gray M3 - 6MT
Gone : 2016 F82 Austin Yellow M4 - 6MT
Gone : 2013 F13 Sakhir Orange M6 -7DCT
Gone: 2013 F13 Alpine White 650i -ZF8
      06-06-2015, 07:05 PM   #3
Manny G
The Illustrious
Message is constant. I cant find info anywhere on what the hell the cap in the red circle is. I may or may not have added some coolant to it before I realize the blue cap was the coolant cap... LOL. The one in red looks exactly like every other BMW coolant cap I've ever worked with in the last 20 years.
      06-06-2015, 07:29 PM   #4
Manny G
The Illustrious
Just took it on a ~20mile ride up and down the highway, and the coolant temp error is gone. That other reservoir must have done the trick?
      06-06-2015, 07:38 PM   #5
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
I don't think so. Must have been a glitch.... As I said I got the message one time ...
      06-06-2015, 07:47 PM   #6
Manny G
The Illustrious
The glitch tuned on after a 'sprited' run yesterday, and lingered through the evening. Came on again this morning when my wife drove the car after it cooled down overnight, and even for me when i went to check it out after letting it sit for a few hours to cool. I added about just under a half a liter of bmw coolant to the red circled cap
      06-07-2015, 07:39 AM   #7
Bönz
Bönz's Avatar
Drives: 2018 M5
Engine cooling on the right (red circle), intercooler/DME cooling circuit on the left.
      06-07-2015, 09:25 AM   #8
Used2be
Perennial PFC
Used2be's Avatar
Drives: F90 M5 DG/Aragon
I hadn't known there was a separate cooling circuit for the DME so I looked in the owner's manual to see if they specify that system. It certainly makes sense that there is one, but the engine cooling is definitely the blue circle, at least according to page 179 in the manual. I'd guess the DME cooling is handled by the cap in the red circle. At least it would take the same fluid (again, I guess) and isn't power steering or something else! Half a liter is a fair amount to add, have you noticed any fluid on the ground? Maybe a leak?
      06-07-2015, 10:03 AM   #9
Bönz
Bönz's Avatar
Drives: 2018 M5
See attached.
      06-07-2015, 10:19 AM   #10
Used2be
Perennial PFC
Used2be's Avatar
See attached.
I don't know where your diagram was sourced, but turn to page 179 in the owner's manual that came with the car. It has the coolant level min/max indicator for the engine coolant in the left, blue circled reservoir.
      06-07-2015, 01:48 PM   #11
Bönz
Bönz's Avatar
Drives: 2018 M5
That would be page 195 of my owner's manual.
      06-07-2015, 02:15 PM   #12
E90Fleet
South Africa
1312
Drives: BMW
Most of the new models now have 2 separate cooling systems.
Even 3 series will have this with the new facelift B48/B58 engines from July
BMW if you are reading, I need a job, Please.
      06-07-2015, 02:20 PM   #13
Used2be
Perennial PFC
Used2be's Avatar
Sorry, I didn't think of the page changes that might happen over the different years. I have a 2013. I'd assume whoever labeled the diagram you posted just reversed the two labels and we can hope the red circle identifies the DME cooling system that you mentioned. Is there anything in your owner's manual that mentions the separate DME/intercooler cooling system? I haven't found anything in my 2013 manual.
      06-07-2015, 03:26 PM   #14
E90Fleet
South Africa
1312
Drives: BMW
The Blue circled one with its little attached expansion tank (E in picture) is for the charge air coolers and DME cooling
      06-07-2015, 03:27 PM   #15
E90Fleet
South Africa
1312
Drives: BMW
The red circled one ( 2 in picture) with a separately located expansion tank (1 in picture) is for engine and turbo cooling.
      06-07-2015, 04:16 PM   #16
Bönz
Bönz's Avatar
Drives: 2018 M5
Your older manual simply isn't clear. Read it again. It doesn't say engine coolant. It just says "coolant". I'm right. You're wrong. E90Fleet posted pics from the engine technical manual that proves it. I have this too. Thanks E90, I just didn't feel like taking the time to do this.
      06-07-2015, 04:24 PM   #17
Ian335xd
United Kingdom
35
Drives: BMW F90 M5 2019
The engine coolant is on the left and the air charge coolant on the right.As you can see it has warning symbol on the cap on the left as this is engine coolant and gets very hot the other coolant runs relatively cool.
      06-07-2015, 05:01 PM   #18
Bönz
Bönz's Avatar
Drives: 2018 M5
Wrong again, but nice guess. You think both the owner's manual and tech manual are wrong? Here are pics from under my hood. BOTH have warning symbols. Clearly the one on the left is a low pressure reservoir cap (DME/intercoolers) while the one on the right is a high pressure engine coolant cap.
      06-07-2015, 05:07 PM   #19
E90Fleet
South Africa
1312
Drives: BMW
Relatively cooler, but not cool. So they have to warn you it can burn
Charge air and DME cooler is on the left of the picture with the small coolant tank.
Engine and turbo coolant fill cap is on the right with hidden large expansion tank
      06-07-2015, 05:37 PM   #20
Used2be
Perennial PFC
Used2be's Avatar
From the diagrams that E90 posted I believe I am wrong. I don't understand why BMW uses the coolant section in the 2013 owner's manual to reference the DME cooling circuit though. If the warning light lit up on the dash to tell me the engine was over heating, I would do as the OP did and go straight to the reservoir that is pictured in the manual to check for fluid level. There is no mention of the other water cap to add water, and of course no way to visually determine its water level. The engine coolant cap in the 2013 model has no yellow warning label, just small black lettering molded into the cap cautioning not to open while hot. I'm glad this came up, now I know. Curious, does the later manual mention both locations for checking cooling water levels?
      06-07-2015, 05:45 PM   #21
E90Fleet
South Africa
1312
Drives: BMW
2013 USA M5 manual
      06-07-2015, 05:49 PM   #22
E90Fleet
South Africa
1312
Drives: BMW
Revised 2015 USA M5 Manual
