01-26-2023, 10:42 PM | #1 |
88
Rep 164
Roof rack molding
The roof rack molding has been known to come up on the CF roofs
The anchors that the molding clips into is just a bracket that is fastened to the body with 3M molding tape, but they must have had a bad batch of molding tape because it simply comes loose. Easy fix. Pull the molding up pull the loose anchor bracket off pull the molding tape off the bracket replace with nice new strong molding tape, clean spot with rubbing alcohol let dry a min. and replace problem solved Last edited by bimmerbeast9; 01-26-2023 at 11:26 PM.. |
02-12-2023, 06:45 AM | #3 |
88
Rep 164
02-12-2023, 09:34 AM | #4 |
2281
Rep 3,305
three inch sheet rock screws should do the trick.
Mike
03-08-2023, 07:52 AM | #5 | |
230
Rep 299
did you just pull it up ? and or lift out the entire molding ? |
03-08-2023, 08:54 AM | #6 |
782
Rep 443
This happened on my 22 and 2 trips to the dealer under my ownership and I think 3 more under her new owner. Passenger side.
Now it’s happened on my 23. Drivers side. Have to say this steams me more than it should. Six figure car and bmw can’t even keep the godd@mn parts from flapping in the wind. I’ll fix it myself this time so I know it’s right but sheesh.
2023 M5C (MBB, Tartufo, CCB, MPE, splitter, skirts, diffuser and pro spoiler), 2022 X3MC (gone), 2022 M5C (gone, not forgotten), 2020 992S (gone), 2018 M3C (should have never let it be gone), 2015 550i (gone), 2013 550i M-Sport (gone), 2010 Panamera (good riddance) (this list is getting entirely too long).
03-08-2023, 11:08 AM | #7 |
256
Rep 193
The adhesive on the RR molding is a definite weak spot. Mine came from the factory with the passenger side rear not staying adhered. Had it in for repair 3X before they finally replaced the whole trim piece and now it sticks!
2023 F90
03-08-2023, 03:50 PM | #9 |
230
Rep 299
Well since I am out of warranty.
I suppose I will just lift it up and pile on some nice PL Premium construction glue under it and put some dumbbell weights on top till it cures . |
05-03-2023, 07:50 PM | #11 |
782
Rep 443
So last time I repaired it. Wait for it.
I took some sandpaper to the roof where the tape goes thinking the tape needed better bite. That lasted a whole 45 days. Had to repair again last night for I think the third time. I’d just duct tape the damn thing down but my paint is so slick from my ceramic that even tape won’t stick to the car. Looks like a three inch lag bolt should do the trick.
