11-23-2022, 02:28 PM | #23 | |
4140
Rep 7,160
Drives: F90 M5 / F15 50i
'07 Yamaha R1 (sold)
11-23-2022, 02:48 PM | #24 | |
369
Rep 1,887
Drives: '20 M5C, '09 M3 DCT Coupe
M5C 20% tint, Xpel full front, partial sides and rear. Spacers, 15mm front, 12mm rear. Turner Motorsport Oil Cooler Guard.
M3: Active Autowerke filter, Dinan underdrive pulley, Dinan full exhaust and software, 3.45 Differential, Springs, Brakes, Dinan/HRE wheels, 275/30-19 w/10mm spacer, 295/30-19 w/3mm spacer, painted front reflectors, 30% tint, Escort 8500i & Lidar Jammer, LUX H8 V5 halos, Euro rear foglights, 3M ClearBra. |
11-23-2022, 03:05 PM | #25 | ||
4061
Rep 4,983
<b>2023 M5C SRG|Aragon || 2018 Macan GTS</b>
2019 F90 Comp MBB|Black (sold) 2018 F80 ZCP TB|SS (sold) 2015 F30 335 AW|CR (sold) 2015 F31 MG|CR (sold) 2011 E90 JB|Oyster (sold) |
FSHNGRY2336.50 |
11-24-2022, 01:20 AM | #26 | ||
398
Rep 462
11-24-2022, 08:44 AM | #27 | |
2337
Rep 2,029
Drives: INDIVIDUAL F90 M5C LCI
How are you liking the Dinan X-pipe?
CURRENT: '21 M5| FSHNGRY | TARTUFO | CCB | MPE | KW | IND | EVENTURI | EISENMANN | DINAN | LOADED |
GONE: '15 F82 M4 | YMB | IND | MPERF | KW | BM3 | LOADED GONE: '11 E92 335IS | BLKSPHR | OYSTER | LOADED GONE: '05 E46 ZHP | LOADED | DINAN STG3 PKG | IG: @FSHNGRY |
spuntyb4060.50 |
11-24-2022, 08:48 AM | #28 | |
2337
Rep 2,029
I found them here from another member. He posted a picture of his engine bay, I asked the same question, a week later they were in the mail. Easy to install, and a nice finishing touch to the engine bay as a whole. I do wish the weave was in the same direction as the rest of the CF in there, but i'll take what I can get to separate it from the rest!
11-24-2022, 08:51 AM | #29 |
2337
Rep 2,029
Man - talk about 'right place at the right time'
spuntyb4060.50 |
11-24-2022, 09:20 AM | #30 | |||
1472
Rep 1,308
Current: 2022 M5 CS
Past: 2021 M550i (BSM) Past: 2010 535 xDrive (Alpine White) |
Justao397.50 |
11-24-2022, 11:40 AM | #31 | ||
4061
Rep 4,983
I had no plans for mods beyond dash cams, the X pipe, and a bunch of iND cosmetic stuff, since I plan to get out of it early if/when the G90 wagon comes to the States. I got the X pipe right when it was announced, and had it delivered in under a week, which was not the case shortly thereafter. For $450 it's a solid mod, although it won't scratch any serious exhaust itch lol. It was on my previous F90 for about 20k miles, and it was perfect for something subtle but noticeable. I love that you went nuts with the mods, now we can all live vicariously through you!
FSHNGRY2336.50 |
11-25-2022, 01:39 PM | #32 | ||||
2337
Rep 2,029
12-31-2022, 06:25 PM | #33 |
4140
Rep 7,160
Just installed. Not a huge fan of thr tolerance in the turbo connection point. Much more wobbly than I would prefer. Can definitely understand those that end of with a intake CEL.
Push the suckers all the way down until they “pop” on. Put the tension rings on and just not doing well for my perfectionist mindset. I do appreciate they’re aluminum vice the plastic Dinan uses.
01-16-2023, 10:56 AM | #34 |
178
Rep 176
The passenger side does wobble a bit on my M8 as well, but if you look where the ends meet it actually pretty secure since the inlet goes pretty deep into the turbo.
That being said I did get a check engine light, it was caused by the gaskets in the breather case. Reached out to Eventuri, they sent new gaskets, replaced them and the CEL is gone. |
01-16-2023, 02:38 PM | #35 | |
1472
Rep 1,308
Also -- reading the instructions from Eventuri (https://www.eventuri.net/wp-content/...tion-Guide.pdf), it looks like they use gasket and O-ring interchangeably? Is that right? It looks like there's just one gasket per inlet that comes from the stock BMW inlets. When they sent you a new one -- did it look like they had their own they made/sourced or is it just a new BMW stock part?
Current: 2022 M5 CS
ResIpsaLoquitur4093.50 |
01-16-2023, 02:45 PM | #36 | ||
4094
Rep 3,675
Drives: 2022 M5C
Not a BMW guy...but certainly an M5 guy.
01-17-2023, 10:20 AM | #37 | |
178
Rep 176
Yea you have to remove the intakes |
01-22-2023, 12:34 AM | #38 |
246
Rep 139
They look perfect. No CEL, all good
TFERG30.50 DarkishM5C308.50 |
01-29-2023, 05:14 PM | #39 | |
4140
Rep 7,160
I removed the 3x tiny t-8s and have pulled pretty good but they’re not budging. I even tried slipping in a small pry tool but it’s marking the aluminum so I stopped.
01-29-2023, 09:28 PM | #40 | |
178
Rep 176
01-30-2023, 10:20 AM | #41 | |
4140
Rep 7,160
haha figured if i can force it off, then they wont come off on their own so no issue driving to work. hell ive already got the CEL.
01-30-2023, 11:49 PM | #42 | |
178
Rep 176
02-01-2023, 04:32 PM | #43 | |
4140
Rep 7,160
Bad news is I still have a CEL. Plan is to connect my phone tonight and see if I can clear the code. I was hoping it was a sensor and it was constantly reading the values and thus would see if they changed. Not that lucky. If this doesn’t work. Well then I’m SOL.
02-07-2023, 03:36 PM | #44 | |
178
Rep 176
If you make an menial change on bimmercode and save it, it will clear all codes during the process. That's what I did. |
