08-29-2021, 11:25 AM | #1 |
213
Rep 548
Do you drive in AWD or RWD daily?
Since I’ve picked up the car, I’ve had M2 set at full plus everything, traction off and RWD. Every time I start the car, I click that M2 twice. I find the car is a lot more fun ripping around the city, I’m not a huge awd guy, unless drag racing or launching it.
It really changes the dynamic of the car, these buttons, it’s like having two cars in one. I love how they set it up, that is so easy to change snd use daily if that is your preference. Wondering if there is other guys that prefer the more raw mode? |
08-29-2021, 11:34 AM | #2 |
2038
Rep 1,843
I think that it's pretty dangerous to drive in 2WD everyday, with all the safety features disconnected.
And also, I'm not sure that it's good for the car as your rear tires are going to wear out much faster than the fronts. The difference between the front and rear tires can harm the transfer box. I very rarely drive my car in 2WD, not to say never. Last edited by Alberta; 08-29-2021 at 11:41 AM.. |
FSHNGRY2339.50 FourPtDrift266.50 |
08-29-2021, 11:41 AM | #3 |
4077
Rep 5,235
I do it occasionally when I want to remember my F10 M5's ….
While they were a ton of fun, getting loose was not that fun.
FSHNGRY2339.50 |
08-29-2021, 04:11 PM | #5 |
Z
46
Rep 131
I rarely put mine in 2wd mode, there's just no room in the city to safely wring it out lol
But you probably feel right at home in 2wd and sport+ since you're coming from a stage 3 c63 😂 |
08-29-2021, 05:32 PM | #6 |
213
Rep 548
Ya I drove the c63 with esp off constantly. Used to a little tail swing, awd felt a bit boring. This car just does everything so well.
Although the c63 was a lot more predictable with the blower, it was instant power, so you could play with the throttle more. The turbo kicks in a bit randomly and can your you into an unexpected spin. |
08-29-2021, 08:34 PM | #7 | |
2340
Rep 2,029
Drives: INDIVIDUAL F90 M5C LCI
When I start the car, I drive out of my garage/neighborhood in comfort mode or the "start up mode" until the engine temps begin to warm up to operating levels. THEN, I'll click "M1" one time, which is: AWD, Sport plus on 2/3 settings, and Sport on the 3rd setting, and then "M-Mode" as I prefer the centered, singular gauge. "M2" settings are sport plus 2/3 , sport on 3rd setting, "AWD Sport" which allows for MDM feature. I would not drive in RWD and traction control completely off. Ever. Not unless I'm purposely trying to chew threw $1000 in rear tires in an empty parking lot for no reason, only to discover a couple dozen rock chips unnecessarily on my car. I'm certain that there are a limited number of drivers out there who can can control the HP and TQ this car pumps out, especially in RWD mode, traction OFF. There is a reason why BMW disabled some of the features in this car when you choose to operate in RWD. City driving especially. the margin of error, and any moment possible is significantly higher. I, for one, can feel that this car is not as planted to the road at high speeds as my M4 was. And I can surely feel the violent momentum the added weight brings to the table. I'm not trying to push the limits and end up on youtube, instagram for being the ass**** who totaled his M5 or worst case scenario, injuring someone or myself. I have a family, who needs me, and the work I put in to afford a toy like this doesn't allow me to beat it up. Sorry OP, just my .02
CURRENT: '21 M5| FSHNGRY | TARTUFO | CCB | MPE | KW | IND | EVENTURI | EISENMANN | DINAN | LOADED |
GONE: '15 F82 M4 | YMB | IND | MPERF | KW | BM3 | LOADED GONE: '11 E92 335IS | BLKSPHR | OYSTER | LOADED GONE: '05 E46 ZHP | LOADED | DINAN STG3 PKG | IG: @FSHNGRY |
08-29-2021, 09:03 PM | #9 |
5257
Rep 10,628
Probably 95% of owners don’t explore the limits. I am a lazy driver most of the time, but play occasionally. I only have a JB4 and meth at present but will add downpipes and trans tube and probably a flash tune eventually. The M5 is my comfy cruiser, winter beater, trash hauler, tool and lumber mover, grocery getter, etc.
I have a 700 rwhp turbo E36 M3 for a toy — 3200 lbs, RWD, and no traction control until I added a Racelogic last year. I have to use R compounds (Toyo RA1) to get traction. It’s fun, but I have had that car supercharged or turbocharged for over 15 years and I wanted an easy to drive automatic with big power and AWD so it hooks without me having to exert much thought and effort. |
ToddinTN504.00 |
08-30-2021, 01:49 AM | #11 |
2511
Rep 4,381
Not forgetting that the front wheels are only ever driven when the stability system detects slip at the rear wheels.
You can often feel the drive being sent to the front with a slight tightening of the steering wheel especially if its off centre. I tried RWD only for a short while..no doubt its fun for hooning around but I like the confidence the xdrive gives for spirited driving especially on UK roads. |
JOHNBMWM51989.00 |
08-30-2021, 03:07 AM | #12 | |||||
This is my unique custom title
267
Rep 698
Right? (Thinking Star Wars Meme here...) Quote:
You've been warned. Don't do it. You've been doing it, it's your right to do it. It is extremely ill advised and irresponsible. Public roads - leave in in MDM, you'll get all the slipping' and sliding' you want, but with the power distribution you need between the front and rear diffs. And, you DO need it. Quote:
You may have noticed that your car has very un-dragster like 275/35 fronts. Quote:
How much track experience do you have with your M5? How many times have you had experience on wet and dry skid pads? Do you know the delta in radial distance from your average city intersections left and right hand turns relative what is recovered to manage throttle oversteer on your car on a track surface? Do you know the delta between road crown variance, on-camber to off-camber when comparing left hand sweepers to right hand sweepers and the maximum negative camber your M5's suspension can correct for under load? Quote:
Your raw mode may result in raw metal exposed.
2021 F90 Comp LCI Frozen Marina Bay Blue/Aragon Brown Full Merino 2020 F83 Comp LCI Porsche Chalk/Black Full Merino 2018 F82 Comp LCI Mineral White/Sakhir Orange (Sold) 2017 F83 Comp Black Saphhire/Sakhir Orange (Sold) |
08-30-2021, 03:10 AM | #13 | |
267
Rep 698
Do you honestly think BMW produced a car at this price point, with this performance level, that has "random turbo activation." You've described driver error. Don't turn driver error into driver injury. For your sake, and for those around you.
08-30-2021, 03:11 AM | #14 |
267
Rep 698
Who does this on a public road?? Get yourself to an HPDS (High Performance Driving School) and then do it again. And again. And again.
FSHNGRY2339.50 |
08-30-2021, 05:25 AM | #15 |
5257
Rep 10,628
Too many of you guys sound like old ladies. You can drive 700 hp on public roads. You just can’t put all the power down all the time. Been doing it for years. You learn how the car responds as have many others.
But as a lazy driver most of the time, I actually like AWD and the sophisticated traction control you can have today that still allows a little fun. I like AWD because you can put more power down more if the time than in a big power RWD car. |
08-30-2021, 06:22 AM | #17 | |
267
Rep 698
And exactly where should "learn how the car responds" courses take place? Which public roads are appropriate for this activity? I can always spot the ones who end up ass-end first off track. They usually profess their great driving talent cultivated on the street.
08-30-2021, 06:41 AM | #18 |
337
Rep 578
I don't get it, if you want to drive RWD daily, why did you get an AWD car?
2019 M5 - Marina Bay Blue/Silverstone
FourPtDrift266.50 |
08-30-2021, 06:46 AM | #19 |
5257
Rep 10,628
I wrote that I have a turbo E36 M3 above. I even drive it with snow tires in winter. Many people mod their cars. I bought a JB4 and meth kit the first month I had my M5. Plenty of people are modders. You can supercharge a Mustang to make 700 hp. It’s not that hard or expensive these days.
You can absolutely use 700 hp on public roads. Have you ever been on a deserted stretch of highway? I certainly would be against doing stuff that puts others at risk, but unless you live in a city, you should be able to find open road. Some are lucky and live near mountains or canyons with great roads. 99% of drivers don’t live on a race track. Probably just a few percent of owners of high performance cars ever track their cars. It’s on public roads that they explore the performance potential of their cars. Typically can’t do it for long due to traffic and there is a risk to the license. |
Drtjxtz161.00 |
08-30-2021, 08:35 AM | #20 |
213
Rep 548
Wowzers, pbonsalb, you’re right, they do sound like a bunch of old ladies.
I guess they didn’t read all of our posts… you guys act like this car is so powerful that to turn off esp should be illegal. It’s actually quite tame in stock form. I have a tune on mine so yes, the boost kicks in way harder around 3500rpm, I should have mentioned that. Downpipes, light wheel wheels and race gas tune going in next week I guess our ‘69 Firebird with 800hp shouldn’t be allowed on the street, it’s too wild lol. In reality my 62 year old mother drives it on the street during the weekend and drag races it. Low 10s car with 9s in it with good DA. I come from a w204 C63 with 750hp or around 900+ with race gas and smaller pulley. 10 years I had that car with not a single day driven with esp on. Responsibility starts with the driver, not the traction control. If you can’t handle your car without the nanny features, not sure what to say. To be clear I am not suggesting driving like this in an epic rain storm or middle of winter… Back on topic, the car actually drives nicer in rwd, the steering wheel has a smoother feel to it. Does the awd system send power to the front axle continuously or is it clutched snd only when it sense slip?? |
Drtjxtz161.00 |
08-30-2021, 09:07 AM | #21 | |
3323
Rep 8,083
the w204 c63 was such a beast, even in stock form. loved that car. |
