BMW M5 F90 (2018+) General Forums Engine, Exhaust, Drivetrain, Tuning Modifications    Which downpipes?
      05-01-2020, 11:42 PM   #67
r33_RGSport
r33_RGSport's Avatar
Drives: G09 XM, G05 X5 40, 991.2 T
Originally Posted by JBA87 View Post
Does anyone know what the performance difference, if any, is between a 3" s. 3.5" inch pipe?
I have ER but it's a 3.0". I'm curious if the extra 0.5" makes a difference on a tuned car
Ja
You won't get any performance difference under stock or mild tune.
You will need aggressive tune to take advantage of bigger diameter.
But then, you will be stuck with a bottle next in the mid-pipe and muffler.
Proper way is to go big all the way from Turbo to tailpipe.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com
PM for Everyday DEALS!!
MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri
Active Autowerke • KW • H&R • Ohlins • Remus • and more...
ss_m572.50
      05-02-2020, 05:34 AM   #68
JBA87
107
Drives: 2019 BMW M5
Well I have the aggressive tune
What's the performance difference you think?
What's a good big/wide turbo back system?
      05-03-2020, 04:43 PM   #69
r33_RGSport
Unfortunately I don't know the gain and no sure there is any exhaust company made bigger diameter all the way to the back.
Most guys goes with catless downpipe mainly for the sound increase.
      05-05-2020, 03:23 PM   #70
KellerPerformance
111
Drives: M5
Be careful a lot of brands out there taper to under 3 inches in certain spots on their pipes. Ours are 3.5 at the turbos with a smooth step design transition to avoid any turbulence going into 3 inch all the way to the exhaust
r33_RGSport12971.00
      05-05-2020, 04:43 PM   #71
r33_RGSport
Good info.
      05-05-2020, 04:53 PM   #72
KellerPerformance
111
Drives: M5
Good info.
You can buy our products from your trusted vendor RgSport
r33_RGSport12971.00
      05-05-2020, 05:51 PM   #73
JBA87
107
Drives: 2019 BMW M5
So how are he Keller's difference Trojan the ERs
I thought Keller was a 3.5" pipe
But sounds like it starts at 3.5" and transitions to 3.0"?
Is that different than ER? Is that just a straight a 3.0"
      05-05-2020, 06:14 PM   #74
KellerPerformance
111
Drives: M5
Only ours are from 3.5 going into 3 because the stock exhaust is 3 inches, and most after market exhausts are 3 inches so it has to taper regardless, so instead of tapering all the way at the exhaust and creating back pressure we did a smooth transition with our step design, our flow pattern is flawless, I don't know much of their product but from pictures it looks like their start at 3 and taper under 3 inches at the primary pipe before connecting to secondary, and yes we believe it is way healthier for turbos to have a larger diameter at the turbos when cars are tuned with extra boost.
      05-06-2020, 11:05 AM   #75
mike@x-ph.com
Joint Chiefs of Staff
mike@x-ph.com's Avatar
Drives: 07-335/12-328/18-M4/21-M4CP
All downpipe have to taper to 3.0" at the connection or else it will not fit.
https://x-ph.com/sale/
Phone number 702-494-9435
jm490519.00
      05-06-2020, 04:41 PM   #76
JBA87
107
Drives: 2019 BMW M5
Do you know how they compare to MSR ?
      05-07-2020, 09:10 AM   #77
KellerPerformance
111
Drives: M5
They all taper at the exhaust connection
      05-07-2020, 11:06 AM   #78
mike@x-ph.com
In what way?
      05-07-2020, 11:21 AM   #79
JBA87
107
Drives: 2019 BMW M5
Size
Sound
MSR claims they are true catless 3.5"
Is that different from Keller
Or is Keller also true 3.5 catless
      05-07-2020, 05:46 PM   #80
r33_RGSport
Size
Sound
Does MSR full turbo-back?
If it is not, I bet you it tapered down to 3" to meet factory piping.
      05-07-2020, 07:11 PM   #81
r33_RGSport
Size
Sound
      05-09-2020, 11:30 AM   #82
mike@x-ph.com
Size
Sound
As mentioned above, unless you are getting a custom exhaust you cannot have a true 3.5" downpipe. It needs to taper down to 3.0" to fit.
You will need a custom exhaust that comes with its own downpipe for that 3.5" setup you are looking for.
That being said, I have not seen any dynos showing power increase from 3.0" to 3.5"
ss_m572.50
      12-14-2022, 02:16 AM   #83
Mrjetsetlife
12
Drives: BMW M5, McLaren GT
Originally Posted by ///M ARMY View Post
SSR performance has F90 downpipes, as well as Evolution Racewerks and GT Haus. In the $1400-$2500 range. $3k for downpipes is just nuts
Gt haus is a win! 👌🏻
      12-14-2022, 06:31 AM   #84
pbonsalb
5234
MAD USA at about $600 for a set is the biggest win.
      12-14-2022, 08:53 AM   #85
mike@x-ph.com
We offer their secondary pipes, best value on the market
      12-14-2022, 10:15 PM   #86
x622
Forced Induction Connoisseur
x622's Avatar
962
Drives: 23 X5MC / 23 720s
2024 G87 M2  [0.00]
2023 Mclaren 720s  [0.00]
2005 Honda S2000  [0.00]
2008 BMW M3  [0.00]
2023 BMW X5MC  [0.00]
1964 Ford Mustang  [0.00]
1968 Pontiac GTO  [0.00]
I have ER pipes for sale in the classifieds. They worked fine. Like others said unless you're doing custom they all neck down. Dual 3.5" is dumb for these power outputs...
Oy vey, look at all these shekels
