01-24-2022, 04:05 PM | #1 |
26
Rep 80
Upgrading Tires on OEM 20" 789M Wheels
I have a '19 M5C and want to upgrade the OEM tire sizes (front: 275/35R20; rear: 285/35R20). I'm currently running 15mm front spacers and 12mm rear spacers.
What is the widest size setup I can safely run on the 20" 789M wheels? [Option 1]: front (285/35R20); rear (305/35R20) [Option 2]: front (285/35R20); rear (295/35R20) I'll be going Michelin PS4S tires. Thanks in advance!
2019 ///M5 Comp | Exec Package | Driver Assistance Package | AWE Track Edition Exhaust | Michelin PS4S (285/305)
02-04-2022, 03:10 PM | #4 | |
26
Rep 80
I was told you can safely run 285/35R20 front and 305/35R20 rear, so that is what I ordered (Michelin PS4S) and will be getting them installed shortly along with powdercoating the OEM 20s. I'm currently running 15 mm spacers front and 12 mm spacers rear (on the stock setup) and will likely remove them with the new tires.
02-04-2022, 03:44 PM | #5 |
1568
Rep 29,202
Look in this thread.
FSHNGRY's 2021 F90M5 Comp Fashion Grey Build Journal https://f90.bimmerpost.com/forums/sh....php?t=1884760
02-05-2022, 07:14 AM | #6 | |
1834
Rep 1,320
People here are a little reticent to give you advice that might kill you. Not so much there. That being said, the advice you got appears to be relatively conservative, and may be right. But a few caveats. 1. Every tire manufacturer specifies maximum width of rim in their published information. For the F90, that's 9.5 front and 10.5 (inches) rear. The sizes you quote I THINK are okay for Michelins (but they might not be for others - depends on sidewall, construction, etc.) 2. The front/rear diameter difference needs to be within tolerance for the drive system. I'm not sure the maximum difference is known before a center diff/transmission shits itself. For some drive systems, it's 10% revolutions/mile difference. For some, they quote 0% (but it has to be something other than that, because of tire wear being uneven). So, sorry nobody answered the original question. Nobody willing to stick their neck out to be an "expert" on potentially bad information, including me. Shawn |
afo818254.50 |
05-04-2022, 09:28 AM | #7 | |
4140
Rep 7,160
Drives: F90 M5 / F15 50i
'07 Yamaha R1 (sold)
05-04-2022, 09:41 AM | #8 |
26
Rep 80
Turned out great! Have about 1K miles since new tire setup and couldn't be happier. I'd definitely recommend this setup.
