05-10-2017, 12:43 PM | #67 |
Rep 27
Yeah I agree with the fitment Joe240. When I rotated the rear pipe to get the tips in the stock location, the front pipe would hit the cross member so I had to sacrifice a little bit of height on the tips.
05-10-2017, 03:37 PM | #68 |
Rep 13
Same problem - the tips centered ok but regardless of pipe positioning I was never able to get them level and still maintain 1/4 inch clearance above the cross member. I'd eyeball the downward dip at about 5 degrees. (this is with the stock muffler)
2017 M240i xDrive Coupe | Dinan Stage 1 | Dinan Mid-Pipe | 'Dr. Strangelove' Sound Upgrade | BMS Exhaust Tips | K&N Air Filter | CF Mirror Caps
05-11-2017, 08:58 AM | #69 | |
102
Rep 303
Any suggestions from Dinan_Engineering ??? |
PeterWT253.50 |
05-11-2017, 09:11 AM | #70 | |||
254
Rep 558
How bad is this issue? Anyone have pictures?
My 2017 M240i: MHD, xHP, Modded OE Intake, AA GESi 400 CPSI Cat DP, Dinan Mid-pipe, M Performance LSD & Rear Diffuser, BMS Exhaust Tips, Apex EC-7 Wheels, M-Tech Front Lip, iND Painted Mirror Caps, Smoked Reflectors
05-11-2017, 09:53 AM | #71 |
Rep 13
This is the best I could do with them. There was quite a bit more downward slant until I pulled the exhaust pipe out of the midpipe as much as possible. That action served to rotate the tips up a bit but also pushed the muffler back a little.
05-11-2017, 09:55 AM | #72 |
254
Rep 558
Thanks Jim.
Jim24015.00 |
05-11-2017, 10:32 AM | #73 |
3917
Rep 3,130
Assuming the front pipe is level the tip downward angle issue would be rectified by rotating the back pipe slightly so the resulting angle allows the the can/tips to sit level. Just some minor tweaking in rotation to fix.
05-11-2017, 10:45 AM | #74 |
102
Rep 303
Don't get me wrong. The midpipe is amazing. The car sounds great with it. But it won't fit perfect as you would expect in this kind of car. It won't fit like a german made glove.
05-11-2017, 10:53 AM | #75 |
102
Rep 303
I've done this 3 times (2 hours each time) in my exhaust shop with the same results. If you fit the midpipe not to hang loose (front midpipe) and not to touch the cross member (rear midpipe), the muffler tips won't look parallel to the rear bumper.
05-11-2017, 11:29 AM | #76 | |
254
Rep 558
AlexM240i101.50 |
05-11-2017, 11:52 AM | #77 | |
102
Rep 303
05-11-2017, 02:04 PM | #78 | |
Reverse Homer
151
Rep 1,064
Anybody here install with BMW and having the same issues? |
05-11-2017, 02:39 PM | #79 | |
Rep 13
The stock mid-pipe gets some latitude because of its oval profile. If you look behind the rear resonator, it is creased downward with the remaining section angled up slightly toward the muffler. I you were to cut forward of the dimple that may help but will change the angle at which the 2 pipes mate. I cut at the dimple and as a last step pulled the muffler out of the mid-pipe as much as I could (maybe 1/2 inch). At the end of the day I love the sound. Maybe Dinan will come up with a solution for the tips!
AlexM240i101.50 |
05-11-2017, 02:49 PM | #80 | ||
Reverse Homer
151
Rep 1,064
It's your time or money being spent trying to remedy this. Either Dinan pays up or replaces and pays for swapping out the pipes. *if* this is really a fitment issue. Trying to see if any certified Dinan BMWdealerships have done this without sagging tips |
05-11-2017, 03:31 PM | #81 | |
3917
Rep 3,130
I talked to the engineer that did the development on the midpipe and a couple helpful tips he noted would be: 1. When its cold the hangers should be angled forward, not straight up and down. If they are straight up and down the pipe is not in all the way and would effect tip angle/height. 2. Once the front pipe is in and secured. Make sure it is supported upwards and not drooping while you work on the back pipe. with those 2 clamps loosely fitted on the back pipe you can rotate it freely and can see exactly what the tips do depending on the slight rotation of the pipe. Once you get it where you like it make sure the middle clamp is then tightened fully (with the front pipe still supported). At that point you will want to push the exhaust itself up while the rear pipe and the last clamp is tightened. Ultimately, if you are still having issues please reach out to tech support / warranty (1-800-341-5480 x2101) and they can assist with any trouble you may have. Much more familiar with the tricks and much better at communicating the more technical stuff than I. |
05-11-2017, 07:07 PM | #82 |
254
Rep 558
I cancelled my install appointment for tomorrow.
I am going to see how this works out for others before having mine done. I don't want to cut my OE pipe until I'm comfortable I will get a nice, clean straight install. I bought the Dinan pipe because I thought that's what I would get. If I wanted to roll the dice, I would have went to a local exhaust shop and had them cut out the resonators and & weld in straight pipe.
05-11-2017, 08:02 PM | #83 | |
Reverse Homer
151
Rep 1,064
Wish me luck |
05-11-2017, 08:33 PM | #84 |
102
Rep 303
Looking forward for your results. The sound is great but for someone with a mild case of OCD and a German car, you want everything perfect !
05-12-2017, 04:28 PM | #85 | |
254
Rep 558
Pictures...
05-12-2017, 04:29 PM | #86 |
254
Rep 558
Me.
AlexM240i101.50 |
05-12-2017, 09:52 PM | #88 |
Mpbruin108
187
Rep 854
What's the verdict? I am debating on putting this midpipe versus waiting for another company. I do agree that having the Dinan name would make me believe the quality might be better than other aftermarket companies so I hope this is just a small issue that Dinan can fix. I got a MPE and it uses stock connections so I was gonna put this midpipe on my MPE but I'll wait until I hear what you have to say Vyruz. I am still waiting to hear your car?
So Cal Drivers: Get your Tires from us to get them QUICKLY (same or next day) and at a GREAT Deal.
2244 Tyler Avenue, South El Monte| Call: 626-443-8539 Active: 2015 BMW i8, 2024 BMW iX, 2018 Mclaren 720s |
