KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK! |
04-01-2024, 03:20 PM | #1 |
183
Rep 482
Passenger front tire wear
Hi guys,
Put the car up for an oil change and just noticed some crazy tire wear/cords showing. Not sure if it was something I hit, but the tire did not look like this about 500 miles ago. Any thoughts? Assuming I should get an alignment when I get a new tires on the front.
2011 E92 M3 | ZCP | Active Autowerke-headers back | Brembo 380mm f/r | OSS Headlights | Full Gloss Carbon Interior | AW/FR |
IG: loganflack_e92 |
04-01-2024, 03:55 PM | #2 | |
183
Rep 482
04-04-2024, 09:58 AM | #3 |
Dont listen to me
798
Rep 562
You definitely need to visually inspect the passenger front suspension components for anything obvious (easier said than done), and then put the car on an alignment rack to see what the numbers show. I'm assuming you dont have any noticeable drivability issues like vibration or the car pulling hard to the right, otherwise you might have noticed this sooner.
Depending on what alignment machine shows is out of spec, it may be possible to adjust the steering rack tie rod to correct a toe issue. Toe is the only front adjustment you can do on a stock suspension since camber and caster are fixed settings. If you have camber plates, you can check to see if something slipped up top. While you do need to replace the tire, that should only be done after the alignment issue is fixed.
Instagram: @thatwhitem4
F1FL182.50 |
04-04-2024, 02:06 PM | #4 | |
183
Rep 482
04-04-2024, 06:11 PM | #5 |
1515
Rep 1,710
alignment is pretty dynamic, it changes often when you're driving. even more so if your bushings are going bad.
your toe probably got sent out of whack some how or you ran on low tire pressure with out realizing it.
F1FL182.50 |
04-04-2024, 06:52 PM | #6 |
YNWA
1048
Rep 815
Toe out of spec and mixed with some neg camber. Some neg camber is fine, and appropriate, but for up front, you'd want very very little or zero toe.
/// 2004 Silvergrey M3 · Coupe · 6MT · Slicktop · zero options
/// 2011 Jerez/Bamboo E90 M3 · DCT · Slicktop · IG: @na.s54 |
F1FL182.50 |
04-05-2024, 09:58 AM | #7 | |
2197
Rep 5,615
OP - get your car aligned. As previously stated, toe is the only factory adjustment you can make to the front suspension (well, there’s usually a tiny amount of camber adjustment if you wiggle things around but not enough to make a real difference). You’ll need camber plates, offset bushings and adjustable suspension arms if you need to adjust camber and caster in addition to toe. |
F1FL182.50 |
04-06-2024, 11:20 PM | #8 | |
1394
Rep 1,292
F1FL182.50 |
