03-05-2008, 03:33 PM | #23 |
1913
Rep 4,128
Drives: M235i & G30 540i
Good discussion so far.
Lack of money is not the problem. It is merely a symptom of what's going on inside of you! - T Harv Eker
Follow me on Insta https://www.instagram.com/bmwm_life_/ https://www.instagram.com/autogiftua/ https://www.instagram.com/phoenixbmwlife/ |
03-05-2008, 06:40 PM | #25 | |
99
Rep 2,000
The E46 M3 is a terrific example. One of the most aggressive aftermarket chips out there is from Jim Conforti - marketed by Turner and others as the "Shark Injector". He claims six horsepower. You should research this, of course, but there are no easy pickings out there anymore for aftermarket chip guys - except for turbo cars, naturally. Bruce EDit: PS - Advancing the timing and leaning the mixture will generally get you better efficiency, thus increasing as opposed to decreasing mileage. Of course, running on the ragged edge means you may also grenade your engine even as you're passing by all those gas pumps. |
03-06-2008, 04:41 PM | #26 | |
91
Rep 676
Your a class act Bruce! Sincerely, -Chris PS. Take a look at the new M3's dyno reports. That torque curve looks mighty flat to me. I'm almost 100% sure it's being held back. |
03-06-2008, 05:21 PM | #27 | |
Racying Dynamics
118
Rep 4,391
05-08-2009, 01:16 AM | #28 |
106
Rep 1,534
Drives: jet black 335i coupe
hahahahahaha, maybe he thinks of m3 power, with naked women modeling on it?
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(e90post.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
05-08-2009, 09:51 AM | #29 |
I can't belive this car is a 4 door family sedan.
66
Rep 385
just looking at the dyno chart tells you that the graph is inaccurate-
hp= torque*rpm/5252 there for, the torque and hp line should always cross at 5252 rpm. Does this one? Check out other dyno graphs.........
06-04-2011, 03:55 AM | #30 |
Rep 16
how does one raise the firing order?
[T even know what increasing the firingQUOTE=KonigsTiger;2261782]Racing Dynamics (http://www.racdyn.com/) have offered to do my ECU and together with the exhaust (that I already have) said they could take it up to 443 bhp!!! 485 bhp is what the M3 Race Version produces but I´m pretty certain they achieve these power levels by using higher octane race fuel, increasing the rev limiter, increasing the compression ratio and increasing firing order and increasing fuel mixture into the combustion chamber. So I think that would probably be the higher limit w/o forced induction and reworking the internals. That is also assuming that the race version engine internal have not been strengthened to withstand the higher moving mass of the piston/crank assembly.[/QUOTE]
What do you mean by raising the firing order? The firing order is what it is, based on crank and cam, i do not see how one could change the firing order, and i do not even know what increasing the firing order would mean. |
06-04-2011, 07:34 AM | #31 |
BimmerPost Supporting Vendor
92
Rep 1,064
Please see the thread it's all linked to.
That graph belongs to an m3 with primary decats and a tune from another company in germany who's claims are quite high for everything. |
06-04-2011, 07:49 AM | #32 |
1122
Rep 7,690
Way too much HP gain out of an NA car !!
What kind of Dyno was that ? Is there a baseline Dyno runs compared to the Modefied Dyno runs ? Tell then,im sorry its BS |
06-04-2011, 07:51 AM | #33 |
All I do is Win... Eat Race Sleep
152
Rep 2,184
Drives: 2018 Range 2011 M3 2019 600lt
i agree unless he is a sc i dont think its possible as well.
Rs7 : 10.4 133.50 with a 1.7 60ft Toyo R888 F10 M5: 11.308 131.96 with a 1.9 60ft Street Tires E90 M3: 11.2 126.7 with a 1.8 60ft Street Tires |
06-04-2011, 01:59 PM | #34 |
258
Rep 5,012
Let me guess what else you believe in: The vortex you install in your intake that gives you 10 MPG more. The magic marker that makes scratches down to the metal disappear. And how about a pill that makes your d*ck 6" longer, and the other that makes you loose 100 lbs and get ripped at the same time . Seriously man, that's a waste of bandwidth. And no, I didn't bother wasting my time reading that. A 15% power increase with just a tune is just ridiculous. And you'd have to be pretty darn stupid to flash such crap into your DME, even if it was free. Risk of engine damage is great, and you'd be on your own. And an S65 is not the right engine to experiment with. Good day gang.
06-04-2011, 02:04 PM | #35 |
154
Rep 2,736
idk if anyone noticed, but this thread is 3 and a half years old.
‘23 RRS First Edition
'22 X7 M50i '18 R8 V10+ http://www.bimmerpost.com/forums/attachment.php?attachmentid=133578&d=1204654487[/IMG] |
06-04-2011, 02:19 PM | #36 |
966
Rep 13,780
