BMW M5 F90 (2018+) General Forums iDrive, Nav, Stereo, Bluetooth, Electronics    Gesture control coding
      04-27-2024, 10:25 AM   #1
mm5300
26
Drives: M5C
Does anyone know if there is specific coding in iDrive for gesture control? And if so, is it an all or none setting, or something that can be changed to turn off one of the gestures? I'm trying to figure out an issue.
It was working and I took the car into the dealership. Even though I told them not to, they reset the iDrive and cleared the changes that had been done. It also upgraded it to a newer software version. I had someone code the changes back and it seems like it was tougher to do with the new software. But now the gesture control is hit or miss (mostly miss) and the only one that seems to work at all is using the two finger gesture. I appreciate any info that can be provided.
      04-27-2024, 09:01 PM   #2
LouK
LouK's Avatar
Drives: Ram TRX F90 M5
FWIW, I have been wondering if something is wrong with my gesture control.
I only have two settings
The volume twirl finger, and the point thing that can be set to do one function and that’s it.
I keep seeing people say you can program to answer calls by swiping, and do other things. I only can find the option for those two though.
      04-28-2024, 01:32 AM   #3
ResIpsaLoquitur
ResIpsaLoquitur's Avatar
4143
Drives: 2022 M5C
Gesture control “worked” so much more often when I didn’t want it to than when I did, that I just turned it off completely. And I’m the guy that swears by the “trunk kick,” despite so many people expressing the same sentiment about that.
Sorry, OP. I know this doesn’t answer your question at all.
Not a BMW guy...but certainly an M5 guy.
      04-28-2024, 12:49 PM   #4
pmsteinm
pmsteinm's Avatar
323
Drives: 23 M5C, 19 X5
I accidentally activate it on my wife's car all the time when she's driving. I don't see the use case for my car since the steering wheel controls are more accessible than moving my hand to where the gesture control is. Now if there was a certain "gesture" when on cruise control that would automatically engage Sport+ and D3 and execute a rapid lane change around the car in front of you that would a feature I could understand
Appreciate 2
      04-30-2024, 08:50 AM   #5
pbonsalb
5267
I have a piece of black tape over the sensor
      04-30-2024, 01:34 PM   #6
ResIpsaLoquitur
4143
Drives: 2022 M5C
I remember seeing you mention that before. Why not just turn it off in iDrive?
      04-30-2024, 06:24 PM   #7
pbonsalb
5267
I may not have known at the time. There is much the car can do that I have not learned. I spend more time driving and modding and maintaining than cleaning and figuring out all the features. I have used the adaptive cruise control before and that is sort of interesting — the car can follow another car to some degree. Have never tried the self park feature. I grew up in Washington, DC and learned how to parallel park.
      04-30-2024, 07:48 PM   #8
mm5300
26
Drives: M5C
So apparently the gesture control does work, but it seems like the update might have made it more sensitive or something. The way it worked before doesn't but now, but if I'm more deliberate and exact with the motion it works. I don't use it very often and it can be a pain, but I'm kinda OCD about my car and don't like when things don't work when they should.
