BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > Blinking Brake Force Display??
      05-04-2016, 12:37 PM   #177
pak1s0ul
Drives: 2011 BMW M3 E93
hello i was wondering if its possible to code NFRM i have 2011 M3 LIC thanks
      05-04-2016, 04:26 PM   #178
dsjr2006
Drives: '01 E39 540iA, '09 E90 M3
2010 BMW 335i  [0.00]
2001 BMW 540i  [0.00]
Yea. Try using the "search this thread" link.
E90 M3 DCT LCI | E90 LCI N54 M-Sport(retired) | E90 Technical Docs download: http://j.mp/bmwe90docs *good read, very detailed.
      09-29-2016, 06:45 AM   #179
tony13849
New Zealand
Drives: Pre-LCI E90 335i
Does the High Positioned Rear Brake Lights flash with this code?
      10-04-2016, 10:33 AM   #180
sono0312
sono0312's Avatar
12
Drives: E90 325i 2005
it is possible to enable third light (top) to brink when BFD for FRM1. that was what i confirmed by coding my colleague's car which had FRM1. my car has been changed to FRM2. then i am not able to make this happen as it has different behaver.
      10-14-2016, 12:10 AM   #181
tony13849
New Zealand
All right, do you still keep the code for FRM1?~~ I want to enable the break and third light blink as Break Force Display~~ Thanks~~
      10-22-2017, 03:05 PM   #182
Frigenchigen
Drives: E90 328i 2011
FRM3?
Wondering if I could get all three brake lights to flash or anything for that matter. Here is a copy of my MAN file from NFRM module (FRM3 LED XE). Furthermore, would it be necessary to add a line to my VO (vehicle order)? Here are the immediate lines in question. As you can see BFD_1_algorithmus is activated however BFD2_Aktiv is not activated.
/BFD_1:
BFD_1_ALGORITHMUS
aktiv
BFD_1_BLINK_FREQ_AUS
wert_01
BFD_1_BLINK_FREQ_EIN
wert_01
BFD_1_ENTPRELL_ABS
wert_01
BFD_1_ENTPRELL_AX
wert_01
BFD_1_MIN_GESCHW
wert_01
BFD_1_STUFE_DELAY
wert_01
BFD_1_THERM_TIMEOUT
wert_02
BFD_1_WEGFALL
nicht_aktiv
BFD_1_WERT_AX_EIN
wert_02
BFD_1_WERT_AX_RUCK
wert_01
/BFD2:
BFD2_A_LOE
wert_02
BFD2_A_MIN
wert_01
BFD2_AKTIV
nicht_aktiv
BFD2_BFD
nicht_aktiv
BFD2_BL
nicht_aktiv
BFD2_BL_M
blinkend
BFD2_BLINKEN
3_hz
BFD2_ESS_ANZEIGE
nicht_aktiv
BFD2_ESS_ENABLE
nicht_aktiv
BFD2_NSL
nicht_aktiv
BFD2_T_ABS
wert_01
BFD2_V_MIN
wert_01
      10-28-2019, 03:30 PM   #183
edgaryo
Drives: BMW E90 318i
Originally Posted by DESI4life10 View Post
I was able to get this to work on FRM 1 modules (coded it on mines and a few others).
However, for FRM2 and FRM 3 modules, I am trying to figure it out. I upgraded my FRM 1 with the NFRM (FRM2) module. Fore those with frm 1 here are the values.
BFD_1_RL_BL_ERSCH_BILD = brake light
wert_03 = flashing
BFD_1_BL_M_ERSCH_BILD = 3rd Brake light
wert_03 = flashing
BFD_1_RL_BL_1_ERSCH_BILD = brake light 1
wert_03 = flashing
BFD_1_RL_BL_2_ERSCH_BILD = brake light 2
wert_03 = flashing
BFD_1_NSL_ERSCH_BILD = rear fog lamp
wert_03 = flashing
I just did the flashing on my rear fog lamps as I don't like the look of all the rear lights flashing (too slow with halogen bulbs).
Hey , i want to code my car , i want to BLINK only the 3RD brake light , not all ,like your post . I wonder what parameter i need to change to get that . I think only :
"BFD_1_BL_M_ERSCH_BILD = 3rd Brake light
wert_03 = flashing"
or i need :
"BFD_1_RL_BL_ERSCH_BILD = brake light
wert_03 = flashing
wert_03 = flashing"
Thank you !!!
      10-30-2019, 03:30 PM   #184
edgaryo
Hey.. Nobody know? Please.. I have a E90 318i from 2005, so frm1...
      11-01-2019, 08:59 AM   #185
evominati
evominati's Avatar
Bulgaria
21
Drives: E91 320D
edgaryo if you can post your FSW_PSW file I can edit it for you
Regards
      06-26-2021, 02:42 AM   #186
Mr-Green
Drives: BMW 3 Series E90 LCi
i just made a comparison table as attached using trc file between one from cuco and the another from myself (sono). i do not know if those are the ones i need to change. but anyway i will try according to this.
these are not all delta but i picked up ones that should be something related to bfd...
would you please give me a feedback if there is something missing?
[updated]
i added some missing values that could be needed to the attached table.
Hi. Have you tested this? & see if it works? Also will this work on a E90 318i 2008
Tags
bfd, brake force display
