06-29-2016, 03:51 PM | #67 |
298
Rep 353
Drives: 2016 BMW M3 ZCP. 2020 BMW X3M
Is there any chance to weigh a '16 ZCP with similar options? The only info I was able to find was 1595 kg (3516 lbs) on a UK site for the M3.
07-26-2016, 10:39 AM | #68 |
175
Rep 153
AWE exhausts can be added to the OP:
"The non-res version weighs just a hair more than stock at 76lbs, and resonated version at 79 given the resonators, among other aspects like larger diameter/thicker tubing, muffler internals, etc." |
09-17-2016, 04:29 PM | #69 |
157
Rep 1,046
Has anyone compared cloth and leather seats/upholstery for any weight differences?
'17 M3 Imola Red/Carbonstructure Cloth, Competition, Lighting, 6MT
Retired: '93 325i |'99 Jeep Wrangler Sport |'06 330i Sport |'08 335i Sport |'08 328i Sport |'09 335d Sport |
11-03-2016, 04:39 PM | #70 |
BimmerPost Supporting Vendor
8288
Rep 18,862
Drives: BMW
Doing some suspension work on a local GTS M4 and wanted to start publishing some weights:
Style 681M Carbon Compound GTS Wheels Front - 19x9.5, Michelin Sport Cup 2 Tires, 265/35ZR19: 44.7 lbs (combined wheel/tire) TireRack Listed SC2 265/35ZR19:Weight: 25 lbs, Subtracted wheel weight: 19.7lbs ea. Rear - 20x10.5, Michelin Sport Cup 2 Tires, 285/30ZR20: 51.55 lbs (combined wheel/tire) TireRack Listed SC2 285/30ZR20Weight: 27 lbs, Subtracted wheel weight: 24.55lbs ea.
11-06-2016, 01:25 PM | #71 | |
21132
Rep 20,742
Drives: 2021 911 turbo
BTW, the 265/35R19 PSC2 from the GTS are listed at 24lbs on the TireRack site. Further, the tire weights on TireRack are rounded to the nearest lb, maybe the fronts weigh 24.4lbs while the rears weigh 27.35lbs .
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 11-06-2016 at 01:33 PM.. |
12-05-2016, 07:49 PM | #72 |
Rep 46
Hi all,
First of all, great thread: super useful information here, thank you everybody! Another interesting parameter that would be great to know about the F80/F82 is the position of the center of gravity. I was looking for this information on the internet without success, and I stumbled on this page: https://robrobinette.com/cg_height_calc.htm It describes a method to estimate the position of the CoG using two scales and lifting two of the four wheels. The higher the wheels are lifted up, the better estimate is possible to calculate for the CoG. Now, I would love to calculate this and contribute it to this thread myself, but I don't have the required scales to perform the measurements. I'm wondering whether Accel Junkie would have some time to try this out! |
12-30-2016, 02:00 PM | #74 |
496
Rep 1,342
Thinking of doing a swap of the rear bumper to an e60 front aluminum bumper.
M4 OEM rear bumper is about 20 lbs. (would save 5+ lbs.)
04-13-2017, 01:46 PM | #75 |
736
Rep 4,635
My M4 (Before Corner balance) Carbon Roof OEM 18s DCT Half Tank of gas TC Kline DA Coilovers RPI full Exhaust Completely gutted trunk Removed rear seat Lower Portion Sparco Ergo II Seats, Driver and passenger I wish it was lighter but its a good set up. My before weight was 3574 but i dont remember how much fuel was in the car so its not helpful.
Follow my BMW instagram @CARMODIFICATION Let me know you are from bimmerpost and i'll follow back
TractionControlDelete4602.50 |
05-04-2017, 03:41 PM | #76 |
316
Rep 408
MSI 75 mm wheel studs and Turner 17mm nuts: 1.90kg for a set of 20
Stock lug bolts: 1.25kg for 20 Ground Control Camber Plates: 2.80kg for pair Fall Line Front Sway Bar End Links: 0.70kg for pair Fall Line Rear Sway Bar End Links: 0.50kg for pair Fall Line Rear upper control arm bearings: 1.05kg for all 4 bearings Dinan Strut Ball Joint Kit: 1.65kg for pair of bearings SPL Front Tie Rod ends: 1.25kg for pair SPL front lower control arms: 2.50kg for pair SPL rear upper control arms: 3.05kg for 4 arms (entire kit) SPL rear toe arms: 1.50 kg for pair These were weighed on scale that has +/- 50 gram (0.05kg) sensitivity. I should get some weights of OEM components and a few other aftermarket parts after I get my car back tomorrow. |
05-10-2017, 03:08 PM | #77 |
496
Rep 1,342
The bumper swap did work. e60 front Alum. bumper for M4 rear steel. There is a little bit of work involved, but at $100 for the e60 front bumper and a savings of about 7 pounds, I like it. More pics on my race build thread. You do need to get an older tow hook for the older tow hook threads, but the hole lines up perfectly.
dim635csi203.00 |
02-11-2018, 02:28 PM | #78 |
21132
Rep 20,742
A few more data points on wheel dimensions and weights:
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
05-29-2019, 11:40 AM | #79 |
606
Rep 648
I weighted my GTS seats. Weight is 6,5 kilos each or about 14 lbs, plus undercarriage. I will install them in a week or two hopefully.
05-29-2019, 04:26 PM | #80 | ||
ECUTek Master Tuner
10447
Rep 1,735
Drives: F80 M3 YMB
02-07-2021, 01:52 AM | #82 | |
707
Rep 886
Looking at e90 weights, our oem outer door panels alone would each weigh around 40-45lbs, we would get around a 30-35lb weight savings per cf door... 120-140 lbs saved!
2015 M3 - AW 6Spd w/ CCB
MCS 2WR Dampers, Spec Twin Disk Clutch, MaxPSI CH, F80Paul Ethanol Tune, 3.5in DPs |
oacaM3M2.00 |
06-05-2021, 04:21 PM | #83 |
606
Rep 648
M4 comp. Fully loaded with all options except CD changer plus full M performance equipment inside and outside, 6-speed, GTS-seats and hood, PS4S tires, titanium stud &nuts, spacers, Öhlins road&track suspension.
1578 kg, s with 20 liters of fuel, or 3471 lbs. Last edited by M 4 FUN; 09-19-2023 at 04:59 AM.. |
chetrickerman10446.50 horsepower_and_hounds1837.00 swagon13572.00 TractionControlDelete4602.50 Unheardmyth21.00 |
06-29-2021, 09:06 AM | #84 |
13572
Rep 8,189
Love it; CSL-like with the GTS and M Performance parts. Now get some lighter wheels.
10-03-2021, 10:42 AM | #86 |
606
Rep 648
Lighter wheels are on the way.
10-06-2021, 12:28 PM | #88 |
606
Rep 648
RSXDC5707.00 Unheardmyth21.00 |
Tags |
curb, f80, reduction, weigh, weight |
