!!! Need Winter Driving Tips With a RWD !!!
12-06-2010, 09:43 AM | #1 |
102
Rep 2,299
So this is my first winter with a RWD!! I'm pretty nervous cause I've gotten stuck in snow before with my previous car which was FWD. Also my 335 is a daily driver. I got my self some 17" 157s with Blizzaks LM-22.
So for my E90ers that drive with a RWD..... Please Give me some advice on how to properly driving in snow in Tri state area!---> from 2cm to 1 ft of snow on the ground. Thanks people!!
12-06-2010, 09:56 AM | #2 |
509
Rep 1,345
Drives: 04 Z4, 18 X3 M40i
Congratulations on the 335!
You have made the right move in getting the snow tires. First thing I like to do every winter is to find an empty parking lot that has no big obstructions and a few inches of snow. Then it is safe to get a feel for the car. The best thing is that you can control the natural oversteer with the throttle. With DSC in its default mode you will go where you point the car, it may not be fast but it goes where you point it. In very heavy snow you may have to turn it off but that will be very infrequent. If you do skid - turn in the direction of the skid so that the wheels start to get some grip. Like any car in snow - drive smoothly. Most importantly, have fun! Especially when you see the FWD cars with "no-season" tires get stuck! |
12-06-2010, 10:14 AM | #4 |
8
Rep 265
He already said he got winters...
With the Blizzaks you should be able to go just about anywhere, just don't go to fast, and leave the DSC on unless you get stuck. Defiantly go to an empty parking lot and mucking around during the first snow. Just be careful of large amounts of snow, particularly in the center of the car. Just because your tires won't lose traction, if the snow is higher than your bumper you're gonna get stuck. |
12-06-2010, 10:18 AM | #5 | |
102
Rep 2,299
12-06-2010, 11:38 AM | #6 |
jr
22
Rep 555
dont drive the car, buy a beater! last year was the last year i tried that! i went full side ways drift on the highway, b4 i managed to control it. this year 99 4wd rav4 here i come
12-06-2010, 11:50 AM | #7 |
I do my crosswords in pen.
17
Rep 751
Winter tires was your first correct move. Good job on that.
Also, getting going is never the problem, it's stopping, make sure you give yourself plenty of distance, and engine brake if you can. I usually try to roll slowly up on my stop and hit the brakes as few times as possible to avoid sliding/abs. And yea, a nice smooth empty parking lot will give you a great idea of how the car is going to behave under diress. Good luck and enjoy it. I'd rather have a RWD in the snow any day. (much more fun when you know what you're doing.)
GRUPPE TITAN Midwest
12-06-2010, 12:14 PM | #8 |
148
Rep 2,932
Not much to add to what has already been said. What I did was go to an empty parking lot, and I tried the car with all the different traction control modes: normal, dsc limited, and dsc fully off(holding the button for an extended length). It's really amazing how well DSC controls the car with snow tires.
12-06-2010, 03:51 PM | #9 |
1625
Rep 2,162
when there is snow on the ground i hit the DSC button 1x
leaving traction control on can sometimes prevent the car from moving because it detects slippage and cuts you off. last season i had the chance to take my 330i through some really intense snow and ice with 18" blizzak lm22's and it took it all in stride. i did get stuck going uphill though but the road was unplowed and there were over 8" of heavy snow so no surprise there. after my friends pushed me to the top i kept on going no problem. i even tried to do some handling/braking tests on solid ice in a parking lot and it did pretty well. take your time, be cautious, and don't get overconfident once you realize that you have traction. it's all about the tires and the driver in those conditions so practice whenever you get the chance. i took my car out in a horrible snow storm last January in VA when everyone else was stuck...i got back home no problem but ground clearance is probably your biggest limiting factor. |
12-06-2010, 05:53 PM | #10 |
FREE DREAMK
162
Rep 9,321
Drives: the shiiit!
Turn off DSC ( press and hold the DTC button for 5 secs) drive like you stole it.
12-06-2010, 05:57 PM | #11 |
735
Rep 10,105
You took the correct first step and bought snow tires. These are 80% of the equation. The other 20% is your skills (10% driving and 10% aiming lol).
Be careful and just keep an eye out for morons without snow tires FWIW I drove my 335 (slammed) on blizzaks thru 6" of snow no problems. You'll be a-ok |
12-06-2010, 06:38 PM | #14 |
185
Rep 7,269
Drives: 2009 335i X-Drive
12-06-2010, 07:09 PM | #16 |
102
Rep 2,299
Lol. Yea I got an oem set with blizzak. Good luck man. Thanks again
12-06-2010, 07:10 PM | #17 |
Corporate Hack
Rep 288
I agree with your first move and what people have said so far. The keys to driving a RWD car in the winter are winter tires, experience (learning in an empty snow filled parking lot is a great idea), the last bit of advice I give is slow and steady. You want to be slow and steady with all driving inputs. Easy on the clutch (if you have one), the throttle, the brakes and steering inputs. Also, give yourself plenty of room between you and cars around you. If you are having issues getting traction, consider beig gentler on the throttle and putting a few 50 lb bags of sand or kitty litter in your trunk. It adds weights over the rear wheels and if you get stuck on ice, it can be poured under the wheels the help get some traction.
New Car: 2008 335xi Coupe
Earlier Car: 2004 STi (got stolen) Earlier Earlier Car: 1995 Mustang GT (416 whp and a blown engine) Really Much Earlier Car: 1988 Mazda 626 TURBO |
12-06-2010, 08:52 PM | #21 |
148
Rep 2,932
Try to be very smooth as well, no abrupt braking, always loook ahead. Abrupt actions are what cause you to slide and lose control (dropping the clutch, aggressive shifting, etc.). Keep a good distance, drive with caution and you'll be fine. What I used to like to do is go out at night and drive around. Roads usually are a mess and barely plowed, and virtually no one is on the road so you can get a good feel for it. Nothing beats experience.
12-06-2010, 09:03 PM | #22 | |
302
Rep 4,126
