12-11-2019, 10:19 PM | #1 |
Rep 12
Odometer Accuracy
Guys, have any of you noticed or suspected that your odometer reading is incorrect? I have had my M5C since March 2019 and I'm regularly baffled by how many miles I have - or it appears that I have - put on the car. My commute to work is less than 10 miles each way. I do drive it plenty on the weekends. I have often wondered if something was off. Today I am almost certain that the odometer leaped 10 miles in less than a mile. Have any of you wondered/experienced the same?
12-12-2019, 07:59 AM | #2 |
92
Rep 281
Mine is at 2800 miles in less than 2 month. I kept pleading to my wife for being innocent but she thinks I'm sneaking out in the night just to have fun. I'll have to show this thread as proof.
On a serious note, I feel the same but didn't dig much into it. I'll start taking notes to check for accuracies. |
12-12-2019, 09:50 AM | #3 |
M5 F90 '19
50
Rep 85
Drives: M5 F90 Azurite black 2019
I was thinking the same thing a few days ago. Would there be anyway to prove that the odometer jumps?
12-14-2019, 02:07 AM | #4 |
304
Rep 351
So on the last several BMW's I have owned I have noticed that the speedometer is 3-4 mph off your actual speed. i.e. if the speedometer reads 65 you are actually going 62 (confirmed via GPS speed). Not sure if that translates directly to the odometer, but if it does it would translate to about a 5% overage so for every 10,000 miles you actually drove the odometer would read 10,500 miles.
Once again I am not sure if the odometer and speedometer are directly linked but I would confirm whether or not your speedometer is off with a GPS app on your phone or an old school vehicle GPS. |
12-14-2019, 05:32 AM | #5 |
369
Rep 1,887
Drives: '20 M5C, '09 M3 DCT Coupe
Odometers are accurate. They are required by federal regulations to be accurate. Speedometers are allowed to read over but not under. If speedometers read under, car manufacturers would get sued out of existence every time there was a speed related accident. It is common for speedometers to read 2 or 3%, or more, over the real speed. That's how they calibrate them. Odometers though, generally are very accurate, as long as you have OEM sized tires.
M5C 20% tint, Xpel full front, partial sides and rear. Spacers, 15mm front, 12mm rear. Turner Motorsport Oil Cooler Guard.
M3: Active Autowerke filter, Dinan underdrive pulley, Dinan full exhaust and software, 3.45 Differential, Springs, Brakes, Dinan/HRE wheels, 275/30-19 w/10mm spacer, 295/30-19 w/3mm spacer, painted front reflectors, 30% tint, Escort 8500i & Lidar Jammer, LUX H8 V5 halos, Euro rear foglights, 3M ClearBra. |
M135iXdriver200.00 |
