12-05-2019, 07:31 PM | #1 |
47
Rep 67
Drives: M5 competition
Check engine light after catless primary downpipes
I had the dealership put catless primary down pipes yesterday on my M5 Competition. Next morning I had check engine light on. Took it back next day to BMW dealership. Mechanic said to get rid of the check engine light i needed a stage 2 tune. He recommended tune from DME. My question is, what if I do not want a tune? Check engine light a bad thing? Any harm to the engine, performance or anything? DME tune is $2400 stage two. That is steep. Any suggestions?
12-05-2019, 07:35 PM | #2 | |
4051
Rep 5,228
FSociety3810.00 |
12-05-2019, 08:11 PM | #3 |
46
Rep 94
I'm currently running KP primary/secondary combo, never had CEL after the install since I used a set of these O2 defoulers.
Since you've already had the downpipes installed, to avoid a trip back to the dealer you can easily install these yourself. Have a look at this thread to get a closer look at where they're supposed to go (2nd last pic). Basically just unscrew both your post cat sensors, plug these in and install the sensors back on top. This can be done from the engine bay with the car on the ground, it's not a guaranteed fix but it did work for me and many others. Hope this helps and good luck! |
FSociety3810.00 |
12-09-2019, 10:30 AM | #4 | |
116
Rep 226
a BMW dealership installed catless DP'd for you? that's impressive in itself! |
12-09-2019, 10:46 AM | #5 | |
Joint Chiefs of Staff
23797
Rep 190,164
12-09-2019, 06:37 PM | #6 | ||
Out in the middle of the sea
231
Rep 471
12-13-2019, 06:43 AM | #7 |
441
Rep 891
You can get a tune without getting a tune just deleting the o2 sensors in the new flash.
Puting o2 spacers is not a good choice as the engines ecu reads false readings from post cat o2 sensors and may do unwanted corrections. |
12-13-2019, 09:49 AM | #8 |
116
Rep 226
12-23-2019, 01:10 PM | #9 | |
348
Rep 1,221
full catless for 4,000 miles now, still no CEL. only jb4. no flash or stacks
12-23-2019, 01:11 PM | #10 | ||
348
Rep 1,221
