12-27-2021, 09:20 AM | #1 |
Rep 27
Dreaded Drivetrain malfunction Real Bad!
Good morning
I rarely post as my 2018 base F90 has been trouble free until now. I use the beast as my daily driver and made it to work with no problems. (About 40 miles each way at 55+mph) However on startup I got the "drivetrain malfunction /vehicle can be driven/contact service" message. The car was running HORRIBLE! Driving down the road you immediately feel and hear the sputtering, rough running and significantly reduced power(couldn't overtake a 98 Camry at 40 mph). The smell of raw and partially burnt fuel in the cabin was unbearable. Bad pops and bangs, I can literally see the fuel level dropping-what happened to my baby?? Limped her home and I noticed the tail pipes on the left side are spewing smoke whereas the right side seem to be exhausting normal which leads me to believe the issue is on the cylinders #5-8 side but who knows. No obvious oil or coolant leaks under the hood either. I Hooked up my simple OBD code reader and only got the following: -Charging Pressure Control: Switch-off As Consequence-P1260 Just under 20K miles on the clock-to the dealer she goes Stay tuned |
12-27-2021, 09:59 AM | #2 |
767
Rep 1,683
Could be coils
Tuned?
22 M4 Competition xdrive
19 M5 Competition sold 16 F-Type S AWD sold 11 Audi RS5 Misano Red--sold 08 E92 M3 Jerez Black 6MT--sold 08 E92 335i 6MT traded in for M3 |
12-27-2021, 10:31 AM | #4 |
Rep 27
12-27-2021, 01:13 PM | #6 |
129
Rep 214
You have bad engine coils and or spark plugs. Same thing happened to my wifes X5 (has the twin turbo 4.4 liter motor) got same message and check engine light at 35,000 miles.
A basic scan tool will confirm fault codes. In our case it was cylinder 6 but replaced all of them at a cost of $1700 for all 8 coils and 8 new spark plugs. |
12-27-2021, 02:37 PM | #7 |
1654
Rep 1,536
12-27-2021, 02:54 PM | #8 |
1395
Rep 529
Ahh gotcha just a thought
12-28-2021, 02:15 PM | #9 | |
549
Rep 545
Moving forward I will more then likely keep my M5 (2018) for the foreseeable future. I started pricing out coils and sparkplugs and I will do the maintenance myself. Two different web sites for the same parts come in at $434.24 (coils and plugs) and $632.80 (coils and plugs). My wife's 2012 VW GTI that she can not separate with had 2 of the 4 ignition coils fail as just over 39k miles. I now carry a complete set of coils in the rear hatch area and instructed her how they are changed out if I am not around the area. Unlike the M5 the GTI's are easy to access at the top portion of the engine. Last edited by Egrunt; 12-30-2021 at 09:34 AM.. |
12-29-2021, 05:32 AM | #10 |
1749
Rep 3,477
I had this on my F90 after a pinhole size coolant bottle leak. (The seam around the bottle failed and the bottle had to be replaced.)
Some coolant went over the coils causing them to rust. New set of coils, injectors and plugs under warranty and problem sorted. |
zdbmw46.00 |
12-29-2021, 07:14 AM | #11 | ||
123
Rep 339
2018 Alpine White ///M5
12-30-2021, 06:29 PM | #14 | |
2267
Rep 3,281
Mike
12-31-2021, 04:14 AM | #15 |
1749
Rep 3,477
Because my service advisor is da man!
No seriously though, he did not want to take any chances and BMW authorised the injectors as part of the repair so he changed them anyway. He said in his (and the techs) opinion only two injectors actually needed to be changed but because they had all been authorised he did the whole lot. Even with the coils, it was only the side of the engine closest to the coolant bottle that needed to be changed but they did the whole lot anyway. |
12-31-2021, 11:09 AM | #16 |
4052
Rep 4,976
That sounds like it could be more than coils and plugs, but not sure what…
Anyways, let us know how it goes with the dealer!
<b>2023 M5C SRG|Aragon || 2018 Macan GTS</b>
2019 F90 Comp MBB|Black (sold) 2018 F80 ZCP TB|SS (sold) 2015 F30 335 AW|CR (sold) 2015 F31 MG|CR (sold) 2011 E90 JB|Oyster (sold) |
12-31-2021, 12:43 PM | #17 |
Rep 27
I appreciate the responses. Actually passed on to my SA. It's day 4 and though they confirm the misfiring, they have not identified the root cause as yet. I'll update again.
12-31-2021, 01:26 PM | #18 |
4051
Rep 5,228
I had a DTML Wednesday and had a plug and injector replaced under warranty.
I got the car back today and no issues at all … felt great on several spirited runs just now on the way home. See work order ..
12-31-2021, 04:51 PM | #19 |
129
Rep 214
If dealer had car for 4 days and they cant figure out problem they don’t know what they are doing. I would look to another shop.
01-01-2022, 07:20 AM | #20 | |
2267
Rep 3,281
Mike
01-01-2022, 10:02 AM | #21 | |
Rep 27
01-01-2022, 10:06 AM | #22 |
Rep 27
Hey 70-were the symptoms as bad as I described? Did the dealer say what caused the failure in the parts at all? Thanks
