01-28-2016, 07:59 PM | #221 |
Rep 2
Code
Hi Shawn, I got a code that I'm trying to clear out from the oil level sensor.
Can you please pm the link to download tool32 ediag or Esys? I'm also looking to download the maps for 2016. Thanks for all the help. 2015 F32 |
01-28-2016, 08:44 PM | #222 |
10445
Rep 40,786
Drives: 2018 Alpina B6 650ix GC
PM sent.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
02-06-2016, 04:14 AM | #223 |
Rep 10
Good morning Shawn,
Can you please send me the software for reading and clearing codes with the enet cable? Is this the same software for logging the car? Where could I find the logging software? Thank you very much. |
02-06-2016, 07:52 AM | #224 | |
10445
Rep 40,786
If you want meaningful interpretation of them, you need to get ISTA/D (Rheingold). I have no idea on Logging software.
03-08-2016, 04:12 PM | #225 |
Rep 5
shawnsheridan solved the runtime 933 error...thank you
tool 32 solved an error... ' Pedestrian Protection system ' all I had to do is: fs_lesen_funktional to read fault codes and then FS_LOESCHEN_FUNKTIONAL to delete errors. |
03-08-2016, 04:13 PM | #226 |
10445
Rep 40,786
03-10-2016, 06:58 PM | #228 |
10445
Rep 40,786
03-12-2016, 02:31 PM | #230 |
10445
Rep 40,786
PM sent.
04-09-2016, 09:13 PM | #233 |
10445
Rep 40,786
PM sent.
04-22-2016, 09:19 PM | #235 |
10445
Rep 40,786
PM senr.
04-29-2016, 08:35 PM | #236 |
22
Rep 88
Howdy shawnsheridan
I'd like to be able to read fault codes/CEL's from my F30, this requires ITSA/D (Rheingold) / INPA? If so, do you have a link that you could share? Thanks so much!
'22 M240i Portimao/Cognac
(Sold) '14 335i Estoril/BK • M Sport • Prem/Tech Pkg • M Perf INTR • VMR V710FF • Shifteck DP (Sold) '95 M3 Avus/Dove • PSS9 • Vorschlag Camber Plates • 3.46 Torsen Diff • etc. |
04-30-2016, 10:25 AM | #237 | |
10445
Rep 40,786
If you just want to clear the fault codes, as most times they are not persistent and thus need no interpretation, then you need only E-Sys:
05-02-2016, 10:53 PM | #238 |
Rep 9
Hello. I am trying to reset the frm of my f25 because after trying to change license plate light to a more powerful leds, the light stopped working. Now even with original leds I have no light on my plates. I read on this forum that the frm might closed the circuit and have to be reset. I have E-sys installed, can this be done with E-sys? If I need tool32 can you shawnsheridan give me the link for the latest version? Thanks. Regards.
05-03-2016, 04:05 AM | #239 | |
10445
Rep 40,786
05-03-2016, 05:01 AM | #240 |
Rep 9
No. I just installed E-sys and connected it to my f25 with enet cable. How can i reset the frm license plate error with E-sys? Can you give me some directions? I am new to bmw coding, don't understand much. Is it easier with Tool32?
05-03-2016, 05:03 AM | #241 | |
10445
Rep 40,786
VO Code: Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Right-Click on FRM (the ECU itself not the underlying CAFD) => Select CODE (not Code FDL).
05-03-2016, 08:15 AM | #242 |
Rep 9
Thanks Shawnsheridan, I will try that later. Hope I don't brick my car software. can you still send me the link for the latest tool32? I found a thread that teaches how to reset frm with that software. This way i could try it if with E-sys doesn't work. Thanks again for your help. I will post the outcome.
