03-01-2013, 01:01 AM | #23 |
Supreme Allied Commander
3886
Rep 54,500
Drives: F80 M3
03-05-2013, 10:53 AM | #24 | |
37
Rep 499
Very Nice, did you have to get custom Seat Base Adapter? |
03-05-2013, 06:20 PM | #25 |
11
Rep 77
03-05-2013, 08:09 PM | #26 |
37
Rep 499
01-31-2014, 06:44 AM | #28 | |
2298
Rep 12,569
Drives: Z4 M, X5, GX460
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.24] |
Btw I know this thread is pretty old but to OP or anyone else wondering, if you wanted something similar to PP's but with higher harness holes, you should take a look at Recaro SPG, I believe they are essentially same width as PP but meant for taller people. Last edited by 3002 tii; 01-31-2014 at 09:29 AM.. |
02-01-2014, 11:21 PM | #29 | |
461
Rep 4,531
Per SCCA Rules, I need seats + mounts to weigh over 25 lbs, so weight reductions could be huge. (Manual seats with heat) I need to still test fit some seats, but I was thinking I can go a permanent mount on driver side and do slide mount on the passenger. I like sitting low, and these seats are just frustrating. |
02-02-2014, 08:49 AM | #30 | |
2298
Rep 12,569
02-02-2014, 09:25 AM | #31 | |
85
Rep 2,438
02-02-2014, 09:34 AM | #32 | |
2298
Rep 12,569
http://www.1addicts.com/forums/showp...9&postcount=20 http://www.1addicts.com/forums/showthread.php?t=887003 http://www.1addicts.com/forums/showthread.php?t=217396 Try giving OGRacing a call, they carry Sparco seats at competitive prices and offer free shipping, but they might be able to confirm fitment for you. |
02-02-2014, 09:58 AM | #33 | |
85
Rep 2,438
By chance are you driving buckets for daily? And damn... Can somebody teach me again how to PM in this forum... REally I can't find that option pressing on nickname wtf? Last edited by RimasRS; 02-02-2014 at 10:10 AM.. |
02-02-2014, 10:17 AM | #34 | |
2298
Rep 12,569
I never daily'd the car but there was a time I took it out often and I didn't mind it one bit. I found race seats to be more supportive, only getting in and out was a slight pain but I quickly found the best "way". My wife has no problems jumping in and out anymore. The only real issue is how you mount the factory belts. Most run the receptacle outside of the seat where the lap belt has to go over the (high) side bolsters. What happens then is when you brake, the belts tighten up but the lap belts only tighten arojnd the seat, not the driver. What I did was buy a belt extender and snaked it through the side hole of the race seat. Not ideal but better than 'submarining.' The reason you can't put the factory receptacle through the side hole is because it's so rigid, no flexibility whatsoever. I ran this setup for a year before putting in harnesses. |
02-02-2014, 10:46 AM | #35 | |
461
Rep 4,531
I already have Schroth Quick-Fit Pro ordered, because I can add a sub-belt if/when I get the seat (at least for driver. Passenger can stick with a 3-point because I'm too cheap right now, lol. Sending you a PM...damn you |
02-02-2014, 11:23 AM | #36 | |
2298
Rep 12,569
02-02-2014, 03:54 PM | #38 |
2298
Rep 12,569
02-03-2014, 11:36 AM | #39 |
85
Rep 2,438
About seat height... The biggest reason why I want to sit lower (although I'm not tall guy 1.80m) is because when I wear helmet I touch with it roof handle I dont understand how others drive e82 on track with helmet. And side support is also important + weight saving. Last edited by RimasRS; 02-03-2014 at 11:41 AM.. |
02-03-2014, 12:11 PM | #40 | |
2298
Rep 12,569
There are some tricks to getting around the height issue, some of it is how you angle the seat. The side mounts will have different holes for front and rear of seat, and angling the rear lower helps (and it makes driving more comfortable). Also, some seats have LESS cushion on the bottom so more the reason you want to actually try out different seats in person. But yea, I would get 1 slider first and mess around with the settings to see what works. |
08-15-2014, 09:16 AM | #41 | |
827
Rep 3,856
08-15-2014, 09:52 AM | #42 |
2298
Rep 12,569
Yes cushion is removable but don't think Recaro provides a thinner substitute cushion. Without slider and seat set on the lowest setting on side mount, you'll probably gain a good 3".
08-15-2014, 10:24 AM | #43 |
827
Rep 3,856
08-15-2014, 01:42 PM | #44 |
52
Rep 589
Drives: BMW 1M
With my setup VAC floor mounts and sliders I think I am sitting higher than the stock sport seat at the lowest setting. Maybe I should have listened to your brother and not put in the sliders.
#446 of 740
