03-29-2022, 02:36 PM | #1 |
automotive enthusiast
32
Rep 43
Drives: G20 M340i 2021
2 ohm subwoofer upgrade in G20 HK
Hi, I am about to change the stock HK subwoofer in my G20, with Audison APBMW S8-2 model. The installer recommended the 2 ohm which was available, but i saw that Audison recomends the 4 ohm.
My question is, will there be some issues with the amplifier, being requested more power to the subwoofer? The Data sheet from the subwoofer shown 150W rms continuous and 300 w peak power. Thank you |
03-29-2022, 03:22 PM | #2 |
1134
Rep 2,248
Well the stock Hk ones are 8 ohms, so 2 ohm ones would be basically trying to pull 4x the power.
Probably a bad idea if you aren't changing the amp. |
alizandru31.50 dhock_holiday215.00 |
03-29-2022, 04:52 PM | #3 | |
199
Rep 1,009
alizandru check out my post on upgrading your stock system (note: this is for the HiFi version of the stock system, look on the web site for HK-compatible equivalent) https://g20.bimmerpost.com/forums/sh...67&postcount=4
alizandru31.50 |
03-30-2022, 10:53 AM | #4 | |
2307
Rep 13,011
There will be issues with the Booster when it tries to be stable at 2ohms when it is designed to drive 8ohms. |
alizandru31.50 |
03-31-2022, 04:30 AM | #5 |
32
Rep 43
Thank you for the info, and already sorted out with the installer.
03-31-2022, 12:58 PM | #6 |
3851
Rep 4,181
also i heard you need to code ASD to OFF as the fake engine sound drives massive amount of bass to the point of risking blowing your sub or amp
06-07-2022, 08:04 AM | #7 | |
344
Rep 906
2016 X3 35i M-Sport
2019 440i Coupe M-Sport - Retired 2018 330i Sedan M-Sport - Retired 2015 428i Gran Coupe M-Sport - Retired |
06-07-2022, 05:02 PM | #8 |
199
Rep 1,009
Still in the process of purchasing it & getting it installed but I budgeted $3K to get everything done, based on my conversation with the dealer/installer. It will be a much superior system to the HK.
07-29-2023, 12:32 PM | #9 | |
110
Rep 314
04-14-2024, 01:28 PM | #14 |
32
Rep 43
It works well. The bump is not substantial, but the bass is cleaner. Audison recommended the 4 ohm because i was going to use the built in HK amplifier. The 2 ohm setup requierea more power and a amplifier upgrade.
