01-17-2020, 09:52 PM | #67 | |
1160
Rep 1,152
01-19-2020, 04:04 AM | #68 | |
163
Rep 321
I did find this YouTube video where someone coded HU_NBT2 along with KAFAS4 and BDC_BODY2. Wonder if HU_NBT2 requires coding to ECE too? |
01-19-2020, 10:26 AM | #69 | |
1160
Rep 1,152
In that video, they are doing the removal of 5AP, but aren’t changing the country code. The change that makes in the headunit is that the owners manual and animated video will show the NGHB video/info, instead of the basic on/off functionality. Although, I notice they didn’t code the FLM modules... I believe like you said that there is very likely a hardware difference. Almarettos coding with the changes he makes might overcome some of those differences that simple VO coding doesn’t correct, but without an actual comparison, there’s no way to know for sure. There’s always the option of getting a pair of used euro lights, which can be had for around $1800, but if I was going to spend that much, I’d wait for a pair of the euro M550i laserlights that we don’t get in the US |
05-18-2020, 12:24 AM | #70 | |
Rep 1
05-18-2020, 12:11 PM | #71 |
1160
Rep 1,152
05-18-2020, 06:28 PM | #72 |
163
Rep 321
Btw, roxxor, did you every get proper shadow-boxing for GFHB/NGHB to work properly on your G30?
Right now my conclusion is either: 1.) Missing LED diodes (or other HW) 2.) Requires manual FDL coding of FLM, KAFAS or BDC
2018 G30 540i xDrive M Sport | Carbon Black Metallic | KW V3 Coilovers | F90 Suspension | F90 Brakes | 20" HRE FF10 Liquid Black Wheels | Michelin Pilot Sport 4S Tires | Ivory White Dakota Leather | Carbon Fiber Trim | Executive Package | Bowers & Wilkins Diamond Surround Sound System | JL Audio 12W6v3 and XD600/1v2 | Ceramic Controls | BM3 Stage 2+ E50 ECU Tune | xHP Stage 3 TCU Tune | Dorch Stage 2 HPFP | MST Cold Air Intake | FTP Chargepipe | AA Catted Downpipe | Remus Catback Exhaust
05-18-2020, 06:41 PM | #73 |
1160
Rep 1,152
No I have not. The removing of the decoding options works ok-ish, but definitely not the correct tunnels. I tried yesterday coding the FLM to euro-spec, and it actually made the glare on the high beams worse than using just the US coding.
I’m torn between 3 options at the moment: 1 - Pay for the proper coding and see how much of a difference that makes 2 - Order a set of used Euro Adaptive LED for around $1100 (price has come down recently) to get the right hardware 3 (and my ideal choice) - Order a set of Euro Laser Lights and retrofit those, but the killer here is the price tag of around $6k From what I’ve heard though the US lights are most likely missing hardware unfortunately. Last edited by roxxor; 05-18-2020 at 06:47 PM.. |
05-19-2020, 12:17 AM | #74 | |
163
Rep 321
So, you are saying removing 5AP from VO and then coding BDC, KAFAS and FLM WITHOUT ECE coding the FLM yielded GFHB/NGHB better functionality versus doing the above, but ECE coding the FLMs? Hmm...I haven't tried that combination yet. Also, do you know of any coders that guarantee GFHB/NGHB functionality? If they charge ~$100 to perform it, it might be worthwhile just to bury the hatchet on whether we are missing HW or not!
05-19-2020, 08:12 AM | #75 | |
1160
Rep 1,152
And oddly enough, I did a before and after comparison of all modules when removing 5AP and 8S4, and the FLMs did not change at all, meaning there were no coding changes related to the decoding in those modules. So in essence, all that needed to be done was to remove those 2 options and VO code the KAFAS and BDC. And yes, the function seemed to work better with US coding in the FLM modules. It gave more of the /\___/\ tunnel than with the ECE coding in the FLM, which I noticed caused a lot more glare on the back of the car in front of me. With the US coding, there was very minimal glare. |
05-19-2020, 04:59 PM | #76 | |
163
Rep 321
05-27-2020, 08:47 PM | #77 |
14
Rep 49
Hi, did it work? I just took delivery of my 2020 G30 M550i and I noticed that in addition to 5AP and 8S4 I have 8TR "DECODING_ADDITIONAL_FUNC" Does that need to be VO coded out as well? Up to now I was on my F10 and using E-SysX to do all of my own codes. Unfortunately the G30 is totally different even down to the naming of ECU's. I feel like a newb all over again
05-28-2020, 03:08 AM | #78 | |
163
Rep 321
VO coding is pretty easy using vanilla E-Sys 3.33.4. No need for FDL coding and Launcher Pro or Esysx.
05-28-2020, 03:41 PM | #79 | |
14
Rep 49
BTW has anyone successfully coded Assisted Driving View on a G30? Mine does not have the instrument cluster mounted Camera or the MODE button on the steering wheel? Are those hard requirements? |
05-29-2020, 08:12 AM | #80 |
Rep 2
05-29-2020, 03:07 PM | #81 |
1160
Rep 1,152
05-29-2020, 03:09 PM | #82 |
1160
Rep 1,152
Unfortunately no. I tried all the coding I found for the G05/G20 to get it to work, the options showed up in the Settings, but the center of the cluster would just be blank whenever it was turned on. I think it has to do with those models having the updated BDC_Body and Kafas modules that we don't get, even though we have the newer headunit and instrument cluster.
05-29-2020, 03:12 PM | #83 | |
1160
Rep 1,152
The best part is my wife was riding with me, and despite her lack of interest in cars or knowing anything about what I was trying to explain, even she was commenting on the amount of light leaking on the bumper of the car in front of us lol. |
05-29-2020, 04:05 PM | #84 | |
14
Rep 49
Thanks. |
