02-15-2020, 01:27 PM | #111 | ||||
294
Rep 456
2018 BMW M5
2018 Porsche GT3 2023 Porsche Macan S 2023 Porsche 911 Turbo S |
02-15-2020, 09:25 PM | #114 |
107
Rep 411
About 36 hours after ECU flash .. and less than 24 since calibration =
Slowness I didn't log 60ft meh 1/4 garbage for 22psi 0-60 pathetic Trap ok for Florida .. maybe ? But should be north of 130. No How many days do you have to wait for these ecus to adapt |
02-15-2020, 10:34 PM | #116 |
107
Rep 411
I didn't do a 1/4 mile run with JB4 only
Not yet .. I will Mo @ DME suggested I wait a little before changing To let adaptation finish Random fuel question: How safe is adding: E30 ; E85 ; or Boostane To 93 pump in our cars ? Any risks? Special considerations ? Also, what about filling the whole tank with e30 or e85? Just curious what's safe? |
02-15-2020, 10:39 PM | #117 | ||
107
Rep 411
After turning with DMEs ECU Tune this QS3 shifting feels like it is no longer present .. could be in my head Where can I read up about this system ? |
02-15-2020, 11:14 PM | #118 | |
294
Rep 456
Boostane, I would stay away from. I ran it for a while and had some performance issues after a bottle of it. My spark plugs were coated with MMT (what boostane uses to increase octane). Some octane boosters seem to be safe though.
2018 BMW M5
02-15-2020, 11:18 PM | #119 | |||
4425
Rep 4,109
The snaps/pops are the real giveaway. I'd guess an M5 is down almost a full 1/3 second—perhaps a bit more—without it even on a 0-60 pull. |
02-15-2020, 11:19 PM | #120 | ||
4425
Rep 4,109
PS: can you quantify a 'while' for me, please. |
02-15-2020, 11:38 PM | #121 | |
294
Rep 456
Not sure exactly how long it was. Maybe 4-6 weeks of use. I was mixing enough with E30 to get up to 98-100 octane. If you're just mixing to get to 93-94 maybe it wont be as bad.
2018 BMW M5
limeypride4425.00 |
02-16-2020, 07:28 AM | #122 |
107
Rep 411
I continue to experience some strange issues
So I went to test the DME this morning to see if there was any improvement (yesterday was raining most of the day). 0-60s continue to get noticeably worse. All runs were north of 3.5sec. I am noticing that in first gear car feels very slow. Almost like a semi-limp mode on reduced power / boost / acceleration . I was able to get a log of one of the weird runs that exhibits this issue of reduced power. To be clear: launch control was engaged, there was no noticeable wheel slippage, so those are not explanations What I did experience was a 3.94 0-60 .. (wtf?).. and acceleration in first gear was noticeable very very slow. Dragy indicates that I barely broke 0.5gs when normally this is closer to 1g The log shows a very weird boost curve .. with virtually not boost until car shifts into 2nd |
02-16-2020, 08:54 AM | #125 | ||
Grand Duke
1540
Rep 1,114
Drives: 2023 M4CSL
2023 M4CSL
2005 Lotus Elise |
02-16-2020, 11:41 AM | #126 |
294
Rep 456
I don't think anything can cause the gap to increase once they are installed. You have to pull on those things pretty hard with pliers to open it up at all. Yeah, I don't have any proof it was Boostane. But after paying $550 to get new plugs and seeing the performance come back immediately, I'm done with it.
2018 BMW M5
02-16-2020, 11:48 AM | #127 |
294
Rep 456
Yeah something's wrong with that. I ran Map 4 (valet mode), without launch control, once for fun and got high 3's 0-60. Timing is low again. Are you running Map 6 to add boost to the DME tune? Please get some better gas today! A few gallons of E85 or 260GT.
2018 BMW M5
02-16-2020, 12:10 PM | #128 | |
3619
Rep 4,532
This last log he posted is wacked everywhere . As you noted timing is dropping to the basement again up top. Launch RPM is too low. Throttle opening is compromised down low. Boost command is wayyyyy low at the launch...partially due to a partially closed Throttle. After he releases the brake, the Boost should hit FAST....but it slow slopes due to everything... I still wonder if JB4 is incorrectly installed and causing conflicts... |
Hockeytyme575.00 |
02-16-2020, 12:54 PM | #129 |
107
Rep 411
It's DME with Map 3 but Mo made some temporary adjustments in the universal settings while the car adapts (see pic below)
He said boost is low because he purposefully made it that way as car adapts While it's possible something is installed improperly w JB4 I think I would have throw an error I'll have a shop look Plus car is pulling strong on highway Raced a ZL1 LE today on highway and (in wrong gear 6th vs 5th) I was riding with him and once shifted into correct gear pulling on him |
02-16-2020, 01:01 PM | #130 | ||
107
Rep 411
Do you have a comp? |
02-16-2020, 01:11 PM | #131 |
294
Rep 456
Why are you running map 3 and a DME tune? Map 2 alone seemed like it was making too much boost for pump gas. I've never heard of running a map, other than 0, with a tune. It does look like it's taking a long time to build boost. Not sure why that would be. I feel like you're changing too many things too fast. I'd go with just the DME tune and get better gas for a week and see what happens.
2018 BMW M5
02-16-2020, 01:23 PM | #132 | |
3619
Rep 4,532
