M2 Technical Topics > Suspension | Brakes | Chassis > M2 incoming but coilovers arrived
      05-04-2016, 06:46 PM   #23
M+M
M+M's Avatar
New Zealand
227
Drives: M2 DCT MPerformance coilovers
So here is the MP suspension installed at about 12mm lower ride height vs standard. The recommendation is for front to be 5mm lower than rear. We measured the standard as delivered (shipping blocks removed) and that was equal ride height all around. The dealer sat my car next to the MG demo car yesterday and said the lower ride height is very noticeable when cars are adjacent. Unfortunately it was raining today so we couldn't do the same for this pic. I still haven't driven my car only the standard suspension car yesterday. Today they will put the plates on and do wheel alignment. We will check ride heights at 2000km service and see if it has settled a bit lower - still only 8km on the odo
      05-04-2016, 06:47 PM   #24
confusion
confusion's Avatar
Drives: 2016 M2
That setup looks so awesome!
      05-04-2016, 06:51 PM   #25
M+M
M+M's Avatar
New Zealand
227
forgot to say that I will be attending a BMW trackday driving factory M cars including M2 on 8 June - will report after. Will have a few kms on my car by then so will have familiarized
      05-07-2016, 12:48 AM   #26
M+M
M+M's Avatar
New Zealand
227
So picked up car today and drove back to the same road I covered with the standard suspension dealer demo car. My initial impression was that over speed bumps and roadside kerb entry and exits the MP kit feels stiffer - quite a bit more - and exiting the dealer after pick up I was thinking I might have done the wrong thing. After all this for me is primarily a DD. A track day is a possibility but I have other cars for that so that will be occasional only. But the ride does smooth out and after a few miles I was thinking that at 100kph/60mph ride felt very similar to standard. Both are a bit fidgety but over bumps and pot hole covers there is no thump felt back through either the steering or chassis and not much impact noise either over motorway expansion joints.
I am happy with the recommended set up for bump and rebound but I can imagine that some might think that a click or 2 less aggressive might be fine too around town but dialed firmer for track - good to have the choice.
As I said above the ride height is a bit above that recommended (higher) I will measure again at the first service to see the cars drops a bit when everything settles.
      05-08-2016, 04:25 PM   #27
JOEsEYE
Drives: M2
Originally Posted by metrickid View Post
Here is mine at the BMW recommended height provided in the install instructions.
Attachment 1406634
AWESOME
      05-09-2016, 03:34 PM   #28
M+M
M+M's Avatar
New Zealand
227
Attachment 1406634
Nice look on yours Metric, a bit lower than mine. So far I have not had any scrapes into my daily car parking building, into or out of driveways or over speed bumps so pretty happy
      05-09-2016, 09:51 PM   #29
metrickid
Dinosaur supervisor
metrickid's Avatar
Netherlands
3030
Drives: E91 318d
Hmm, should be the same if we both used the same recommendation. I measured it to be 595 mm up front and 600 mm in the rear when I collected the car but it might have settled a bit. I will measure it again and see. The measurement should be made with 2x 75kg in the car according to BMW so that might be a reason for it to be different depending on if the installer did that or not.
      05-10-2016, 12:36 PM   #30
Rempt
23
Drives: 2016 BS M4 Coupe
They make these for the M4?
      05-10-2016, 01:15 PM   #31
fourscore
44
Drives: M2
Looks fantastic..
My question for me is; is having the better, lower look in contrast to (or a trade off with) the firm/hard ride around town or is it simply an acceptable compromise in your opinion?
Many thanks
      05-10-2016, 01:21 PM   #32
metrickid
Dinosaur supervisor
metrickid's Avatar
Netherlands
3030
Drives: E91 318d
Originally Posted by fourscore View Post
Looks fantastic..
Many thanks
It works just fine! Over hard bumps, like tram tracks or other bumps it is a bit rough but once up to speed as the OP said it is just great. I have no problem what so ever using it as a daily.
      05-10-2016, 01:22 PM   #33
fourscore
44
Drives: M2
Looks fantastic..
Many thanks
Thanks (I was really hoping you were going to say that!)
Cheers
      05-10-2016, 02:27 PM   #34
Bosozoku
Almost completely sane
Bosozoku's Avatar
Drives: '17 M2, '00 S2000
... forgot to say the ends of the spring sit on standard rubber bushing at the top but bushing is deleted at the bottom. So less rubber in the system with the MP set up ...
Good to know that. Better feel, more immediate response.
... I am happy with the recommended set up for bump and rebound but I can imagine that some might think that a click or 2 less aggressive might be fine too around town but dialed firmer for track - good to have the choice. ...
Fantastic review! And good on you for not lowering the car all the way.
It's an M car. Not a low-rider.
'17 BMW M2 (BSM 6MT Exec CarPlay, TechnicPnP ASD bypass, IND M Perf shift knob + keyhole cover, Pedal Haus pedals + heel plate, 3M CR90 tint, BavSound Ghost woofers, Racing Dynamics strut tower brace, Dinan midpipe, Turner intercooler)
'00 Honda S2000 (Silverstone Metallic, black leather, factory titanium shift knob + front lip + trunk spoiler, front shock tower brace, front subframe x-brace)
      05-10-2016, 02:40 PM   #35
tareemaa
Bimmer Fanatic
Drives: M3
Lowering this car makes it looks so much better!
      05-10-2016, 02:40 PM   #36
AndrewC1989
AndrewC1989's Avatar
Drives: 2015 328d xDrive
Attachment 1406634
Holy Shit this is PERFECT. Got any more shots? I'd like to see it from some more angles to see how far the wheels stick out
      05-10-2016, 02:44 PM   #37
metrickid
Dinosaur supervisor
metrickid's Avatar
Netherlands
3030
Drives: E91 318d
My Instagram has a bunch (link in signature) and I posted a separate thread with just my car in the photos section.
      05-10-2016, 03:29 PM   #38
John Tanglewood
Porn Star
John Tanglewood's Avatar
Jamaica
1316
Drives: E60 M5 | F95 X5M | F90 M5
More pics now that you have the ride height dialed in.
      05-10-2016, 03:30 PM   #39
raysspl
raysspl's Avatar
992
Drives: walking, bicycle, & bus
Interesting..... thank you for sharing your thoughts
re
      05-10-2016, 04:16 PM   #40
Fab_R
Australia
192
Drives: BMW M2 / Audi S3 8V Sedan
Perfect ride height!
      05-10-2016, 04:49 PM   #41
Desborough
Desborough's Avatar
Drives: 2008 335i Dinan
This looks so awesome with the M Performance coilovers. Makes me want to sell the E93 and look for an allocation. Fantastic
2008 SGM Dinan 335i vert
2015 White Diamond GMC Yukon Denali XL
      05-10-2016, 05:41 PM   #42
mhanism
mhanism's Avatar
Drives: 2020 M2C
Any need for spacers?
MY20 M2 Competition
MY16 M3 (Sold)
MY17 X3 35i M Sport
MY14 335i M Sport (Sold)
      05-10-2016, 05:46 PM   #43
mPlasticDesign
mPlasticDesign's Avatar
684
Drives: BMW 230i Msport w/LSD
Location: Astral Projecting: ∞ 23.516 -122 02.625 0242.101 ĕv'rē-hwâr'
The "recommended height" is perfect IMO!
      05-10-2016, 06:54 PM   #44
M3 Number 86
3221
Drives: black m3
Camber won't affect tire wear as toe would. Set the heights first then get it corner balanced. It'll probably only be one side you need to adjust. I would get some camber plates installed so you can dial some out of your want.
m2
