BMW M5 F90 (2018+) General Forums Cosmetic Modifications    DIY: F90 / G30 LCI Tail Lights Retrofit
      09-25-2022, 01:40 PM   #639
Evil Derboy
Evil Derboy's Avatar
271
Drives: E92 M3
Originally Posted by Mike Suomis View Post
Hello, I'm new here, I have Euro car and Euro lights. I'm about to install lci taillights, I'm doing everything according to the BMW schematic, I'm running the wires to BDC, repining, this part is clear. What is not clear is whether I will be able to code everything with the full version of Bimmercode? My BMW software is up to date.
So if I miss :
2) Add HELC to HO-WORT 3) Code BDC module
and Just doing this in bimmercode:
BL_L_CCM: ccm_346 [01 5A]
BL_L_IS_LED: nicht_aktiv, default [00]
BL_L_MIN_PWM: 5% [05]
BL_L_WARMUEBERWACHUNG: nicht_aktiv [00]
BL_R_CCM: ccm_345 [01 59]
BL_R_IS_LED: nicht_aktiv, default [00]
BL_R_MIN_PWM: 5% [05]
BL_R_WARMUEBERWACHUNG: nicht_aktiv [00]
Can someone confirm who did this?
Sorry, but I've never coded, but it doesn't seem like a very complicated process. Just need to understand everything��
Just do it and worst case scenario is that you can reverse your coding changes. The coding is only for the boot/trunk lid lights anyway, so even if it doesn't work you can still use your car till you get it figured out.
      09-25-2022, 01:45 PM   #640
Evil Derboy
271
Drives: E92 M3
Just a word of caution for those using the Chinese knock-off lights. A guy on the UK FB group used these and one failed. The issue caused the BDCs circuit protection to kick in on the circuit for the failed lights, meaning that when he re-installed his original lights, the same lighting functions wouldn't work.
The BDC Module controls all lighting in the car, each individual light is called a slave. If the BDC detects an issue with an individual slave on a certain number of start-ups, it will permanently disable the circuit for that slave, until a reset procedure is carried out using an ISTA function or manual coding using other workshop level tools. I had this issue with a failed headrest light and it took 4 trips to the dealer until they finally twigged that they needed to reset the lighting slave on the BCM before the replacement component would work.
If a another threshold is passed the BDC permanently locks out the circuit using a non-replaceable fuse on the BDC and the wire for that circuit has to be allocated and programmed to a spare pin on the board.
The OEM lights aren't that much more expensive than the knock-offs (in the UK anyway) and remote coding costs around £100. I can understand the appeal of the AliExpress versions but the complications around the BDC module if one malfunctions and the relative parity on cost make the OEM versions the better option IMHO.
Joe-BMW337178.50
      09-25-2022, 07:25 PM   #641
mfolife
Drives: BMW F90 m5
Well now I have a question. I bought what I believe are BMW lights from Abdul for my 18 F90 and had Vic at Bimmercode program. Every so often (more times than I care to mention)the left and/or right outer tail lights stop working. Using my scan tool it tells me its detecting an intermittent or permanent short circuit and the BDC has to be reset by Vic. Very frustrating as I have to bother Vic for reprogramming each time. Doesn't happen right away and until it does the lights work fine.
Is it possible the lights are in fact knock-offs with bmw logo? The wiring has been verified correct to the inner lights and the rest are plug and play-as per the multiple instructions here and likeI stated they work for a while then all of a sudden poof. I have the NA spec LCI lights. Sorry if I missed a post where this was brought up.
      09-26-2022, 01:30 AM   #642
Evil Derboy
271
Drives: E92 M3
Highly doubtful. More likely faulty genuine lights or you’ve got a wiring or coding issue that’s unrelated to the light clusters themselves. Only way to know for sure is to swap back and see if the same issue occurs.
If I were in your shoes I’d swap out the outers for the pre LCIs and see if the same thing happens.
Joe-BMW337178.50
      09-26-2022, 10:33 AM   #643
Maverik259
Maverik259's Avatar
Drives: F90 M5 / F15 50i
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
probably faulty lights. Ask for a replacement. I had my driver side fail and was replaced under warranty and is a known issue on early sets. this is why i buy from bmw when ever able.
'07 Yamaha R1 (sold)
'06 C55 AMG (sold)
‘?20 M5, MP Carbon Pro Spoiler, MP Carbon Diffuser, MP Black grille and gills, MP Carbon Mirrors, CF side sills, 789M w/ Ti studs, eventuri, Dinan X pipe
'14 X5 50i (wife’s now)
BOOF-M34450.00
      09-28-2022, 02:51 PM   #644
mfolife
Drives: BMW F90 m5
Thanks Moon and Mav. I have a suspicion the lights are the problem too and changing the outers back and trouble shooting makes sense.
      09-28-2022, 04:22 PM   #645
Evil Derboy
271
Drives: E92 M3
No worries. Good luck with it. Hope you get it sorted out.
      09-29-2022, 09:09 PM   #646
cadena
14
Drives: 21' BMW M550i
2021 BMW M550i  [0.00]
Does anyone have Abdul's contact info? I want to price out a set of these tailights
      09-30-2022, 02:56 AM   #647
Joe-BMW33
Joe-BMW33's Avatar
7179
Drives: '18 M550i|'21 X5|'03 540i
2013 VW Tiguan  [0.00]
2015 Infiniti QX60  [0.00]
2021 BMW X5  [0.00]
2003 BMW 540i  [0.00]
2018 BMW M550  [10.00]
Tried to PM you but you choose not to receive PM's
2018 M550ix|Carbon Black|Dinan Modifications|2003 540i|Jet Black|M-Sport|2021 X5 Mineral White
Prior BMW's: 1987 325e|1993 740i|1998 740il|2001 530i|2002 745li|2007 750li|2006 750li|2001 530i|2012 535xi|
      10-05-2022, 12:19 PM   #648
donpapa
Drives: m5 e60, m5 f90
Hello guys, i have USA spec M5 F90, 2019 preface.
I want to do the retrofit of the taillights from what i read the chinese ebay taillights are plug and play but have a lots of bugs.
So i will go with the OEM kit, my question is since i will drive my car in EU, should i buy the EU spec taillights or the USA spec i have great coder so coding will not be an issue.
      10-05-2022, 02:04 PM   #649
Joe-BMW33
Joe-BMW33's Avatar
7179
2021 BMW X5  [0.00]
You should buy the Euro tails no matter where you will be driving, including the US. They don't throw welcome light errors like the US lights and some would argue the amber strip blinkers are more appealing, myself included.
430Scud239.50
      10-05-2022, 03:12 PM   #650
pjacobs
Drives: E92 M3
Hey guys! Looks like Abdul and Euro Parts Palace have another group buy running for the Genuine BMW F90 / G30 Euro Spec Tail Lights. I just snagged a pair and if anyone else is interested the link is below.
https://eupartspalace.com/product/bm...-g30-5-series/
      10-05-2022, 05:37 PM   #651
donpapa
can anyone share the OEM part numbers for EU spec LCI taillights ?
      10-06-2022, 12:29 AM   #652
Joe-BMW33
Joe-BMW33's Avatar
7179
2021 BMW X5  [0.00]
They are literally in the link right above your post 😂.
Maverik2594137.50
      10-27-2022, 07:27 PM   #653
OnyxM5
Drives: 19 m5 f90
Just got my set delivered today from eupartspalace.com
Super fast shipping cant wait to get them put in after the car comes back from BWM
Abdul1036.50
      11-20-2022, 07:17 PM   #654
KmanM3
Drives: 2017 540i
If you are not thrilled about tapping into your factory wires like me you can use an OEM connector, part # 61115A3C023.
It has male and female plugs and can be plugged in between the factory wire and plug on the outer light. There is some kind of resistor wired into the connector so you will need to remove the harness tape and cut that out. I used the cut wires to tap the wire that goes to the inner taillights but you have to first move that wire to pin 1.
      11-20-2022, 07:27 PM   #655
KmanM3
Drives: 2017 540i
I also made a plug and play adapter so I did not need to re-pin the inner taillight plug.
The male plug was not easy to find so I found some male plugs with wires on EBay from another BMW. You need part number 63216909052 and if you search on EBay you can find used plugs/harnesses.
The female plug is here: https://www.te.com/usa-en/product-1703874-1.html.
Thanks to WayneM3 for letting me borrow the crimping tool to add the OEM pins for the connector!
Joe-BMW337178.50
      11-21-2022, 12:56 AM   #656
Joe-BMW33
Joe-BMW33's Avatar
7179
2021 BMW X5  [0.00]
Very creative solutions for the jump wire. I ran the extra wire from the BDC, so no splice or tapping. I also don't have an issue with the repinning, it's the way the pins are supposed to be and are on LCI's. Nice job on the adapters. I'm sure if you ever want to swap back in the old lights it will save you time.
      11-21-2022, 06:48 AM   #657
KmanM3
Drives: 2017 540i
Yes, the ease of swapping back was the main reason I did it. I actually have the fifth wire for rear fogs but once I saw how cramped the front part of the BDC was I gave up on switching pins there.
Joe-BMW337178.50
      11-21-2022, 06:52 AM   #658
Joe-BMW33
Joe-BMW33's Avatar
7179
2021 BMW X5  [0.00]
Plus, it's fun, for me anyway, creating electrical solutions!
Did you hook up the rear fob wire or leave it hanging? I hooked it up, bought a new switch with the button and coded it. I've never used the rear fogs! Had to do it though, something about having that wire and lights with the diode.
      11-21-2022, 03:55 PM   #659
KmanM3
Drives: 2017 540i
Yes, I hooked it up so if I elect to add that functionality in the future I can.
Joe-BMW337178.50
      12-04-2022, 01:19 AM   #660
patrickkc
28
Drives: E63S , C63 , Cayenne
how are you guys crimping the mqs socket? I tried install today, and realized my socket were incorrect while re-pinning. Had to put everything back and now wait to get the new correct sockets.
Even with the wrong sockets, I knew I probably butchered it crimping the socket to wiring. Just wondering how are you guys crimping the socket to new wire?
Search this Thread:
Advanced Search
