04-27-2022, 05:58 PM | #24 | |
26
Rep 40
Hi Shawn, can you share more of your experience about further differences between the M Compound steel brakes vs the CCB?
- you mentioned CCBs are less consistent than M compound brakes - how about braking power? - can you feel the decreased unsprung and rotational mass? - noise difference? I知 thinking of retrofitting a CCB kit, but it is very very costly. I do mostly hard/fast driving on mountain roads and will rarely intend to track my car. Quote:
04-27-2022, 06:53 PM | #25 | |
551
Rep 638
stick to the steels. No you wont notice the unsprung mass/weight. |
04-27-2022, 10:09 PM | #26 | |
1830
Rep 1,315
The braking power is high with the CCB's. Very high. The "inconsistency" that I mention above is contained within a zone that is braking harder than the metals. When the CCB's fade, they STILL stop as good as the metals at their BEST. So, they are very very good. Apologies to my other board member, but I DO feel the decreased mass. The M5 CS feels MUCH less ponderous than the 2018 M5. Are there too many other variables to consider? Maybe. Maybe the brakes are only ONE of the reasons the CS feels better on track. Doesn't matter. This is a brake system I "DID NOT" want, because of CCB's reputation on track of being expensive and problematic. So, the kudos I give it are not from a CCB fanboi I NEVER, and I really mean NEVER had a problem with the noise from the M compound brakes on the metals. Maybe that's because I beat the living shit out of them at track weekend after weekend and have a VERY good transfer layer on the disc that takes forever to remove with regular driving. The CCB's are just like this. For my break in, and track driving - perfection. No noise greater than the next door neighbors Kia on brake noise. They're awesome. If I were doing add-on CCB's to a M5 that didn't have them? No way I would have paid the extra cost. No way. The metals on the F90 M5 are awesome. And, by comparison to equal cars, CHEAP to replace wear items. There has been NO OTHER CAR I've ever owned that OEM pads lasted two track events. NONE. The stock pads are perfectly fine for track. One caveat of the metals on the 2018 - on my 2018 wore out the back pads very quickly. The "M Sport mode" still wears them out. "DSC totally off" makes the car a LITTLE BIT of a handful. The CCB's on the CS (has a really good track mode), the wear is perfect. Fronts need replacement after two great track weekends, and the rears are still fine, and will probably last three more. And the car is not a handful. Perhaps the differences in mode from 2018 to 2022? Maybe. CS vs standard M5? Maybe. I hope this helps. Shawn |
04-27-2022, 10:14 PM | #27 |
1830
Rep 1,315
ResIpsaLoquitur4068.00 |
04-28-2022, 05:55 AM | #28 |
26
Rep 40
Thank you very much Shawn and AJ_g80.
After taking your opinions and advice into account, I agree I should hold off the CCB upgrade and keep to the blue M compound brakes. I have yet to require even more braking power than what I have now with my steels, and I value consistency of pedal feel and bite because my country has plenty of rainfall and I need the brakes to bite consistently every time in wet highway traffic. |
shawnhayes1829.50 |
04-28-2022, 10:40 AM | #29 |
875
Rep 1,319
On my next outing in the car, i shall be concentrating on warming the CCBs properly, and testing them out again, will report back.
shawnhayes1829.50 |
04-28-2022, 06:25 PM | #30 | |
551
Rep 638
The CS suspension definitely feels a little sportier/lighter to me. I think thats what it is for sure, i can definitely agree to that. But if you hopped in an m5 with steel vs CCB, there's no way you can tell. Until maybe you mash on the brakes and your brain exits through the windshield |
04-30-2022, 09:47 AM | #31 | |
1830
Rep 1,315
Shawn |
05-01-2022, 10:42 AM | #32 |
875
Rep 1,319
This video is interesting. Listen to the noise from 2.51 minutes onwards, from his brakes, until he makes the right hand turn. This is also the noise i experienced from the brakes, when i had the lack of bite from the CCBs. This would have been his first big stop on that lap ?. Didnt really hear it again much on his lap afterwards ?.
05-01-2022, 08:14 PM | #33 | |
1830
Rep 1,315
Shawn |
05-01-2022, 09:28 PM | #34 |
551
Rep 638
Is this a repetitive issue? if it is, try bedding in your brakes. excellent info here.
https://www.mclarenlife.com/threads/...s-rotors.2073/ although i suspect you aren't driving hard enough on public roads to need to do this.. |
05-02-2022, 02:12 AM | #35 |
875
Rep 1,319
Although I have done around 2500 miles from new, in 12 months, I admit to not being very aggressive with the brakes on the car. I don稚 use it that often, and I suppose , if anything, I知 too soft with it. Will try and follow some of the bedding in procedures that are mentioned in this thread, and see what happens. Like I致e already mentioned, the initial application, is always on point, and feel awesomely strong, as if over servoed, but I知 wanting that sort of stopping power, and feel, at any speed , and throught brake application. Thanks for the info provided.
06-02-2022, 11:39 AM | #36 |
Rep 10
After reading this thread, I feel confident I made the right decision to NOT get the CCB's living in Minnesota.
Although, I would probably drive it less during the winter to save it from the horrors of the immense amount of salt they use on the roads here... I wouldn't fully trust the CCB's when temps started getting below freezing, and not at all when they get in that -10* to -30* range some days... (Or is it the CCB's are fine, its that I don't trust myself to remember to warm them up multiple times throughout a daily drive? ) Well, all of this is moot I guess, until I can finally put in an order for a 2023 M5 Comp. My dealer still doesn't have the ordering guide for the 2023 MY M5's. Anyway, great thread/discussion. Thanks all! |
