02-20-2016, 10:10 AM | #23 | ||
217
Rep 341
Drives: G01 M40i
A month back I coded FEM body to separate ambient lighting from gauge cluster dimmer switch (ambient_nachfuehrung). Even after that I have never noticed my ambient/interior light pulse. I reckon that might have something to do with that. I'm going to code that back to factory and report back.
2021 G01 M40i Glacier Silver
2020 G05 4.0 Phytonic Blue (Wife's) Retired: '15 F80 DCT (ED), '10 X5 3.0, '07 328i E92 |
02-22-2016, 03:40 PM | #25 |
749
Rep 2,108
So what the consensus on coding ASD_SOUND_OFF? I gather that it doesn't completely turn off ASD compared to changing the Model Range F20 in the ASD module, but how much quieter is it compared to stock?
I actually like ASD, but wouldn't mind if it was a bit less amplified to allow me to hear more of the true exhaust sound coming from the outside.
2015 BMW F80 M3: Tractive EDC Suspension / Dinan Anti-Roll Bars / GC Camber Plates / KMP Dual Diff Mount / Girodisc Rotors / GT4 Brake Cooling Kit / PTF Flash Tune / Eisenmann Downpipes / CSF Heat Exchanger / BMS Charge Pipes
2007 BMW E92 335i (SOLD): BMS JB4 / Quaife LSD / Riss Racing DPs / Helix Intercooler / BMS Intake / STETT Charge Pipe / Forge DVs |
02-22-2016, 04:40 PM | #26 |
Christmas Poo
1029
Rep 1,180
My estimate is that it's about or just about above half. It's almost like there are 2 places the active sound gets amplified - between the ASD module and the main amp as well as in the head unit. If you turn off in the head unit it still seems to be sending signal to the amp. Perhaps one is the "brain" that ties into RPM range, while the other is baseline noise...but I'm not that smart. All I know is the sound is still there and a little quieter. Just coming from the wrong place (IMO) from a "soundstage" perspective.
Read...no drive, the manual. |
06-11-2016, 10:00 AM | #27 | |
349
Rep 3,022
Help pls guys!
In the F87 M2 - so doing no.3 and coding ASD Module : 3000 "Model Range" to F20/21. Yet, when i log back in, the ASD Module : 3000 "Model Range" is being set back to F87. Any ideas what is resetting this? Thanks Quote:
M2 Arrived!
Family 5er |
06-11-2016, 10:34 AM | #28 |
1593
Rep 3,945
Drives: 2015 M4 MG/SO
Are you sure you saved the changes before you FDL coded? one way to know is when you read ECU after connecting to car, check the value. If it somehow magically resets, try setting it to any other value F01, the value doesn't matter as long it's different than you car model.
06-11-2016, 01:10 PM | #29 | |
349
Rep 3,022
M2 Arrived!
Family 5er |
06-12-2016, 02:43 PM | #30 | |
349
Rep 3,022
Much improved. I turned off both 2) NBT and 3) ASD just to make sure
M2 Arrived!
Family 5er |
07-18-2016, 05:16 PM | #31 |
66
Rep 248
Hi
I previously disconnect my ASD, but recently plugged it back in to carry out the full I-Step update. Unfortunately, the ASD ECU won't update any longer. Any ideas? It's the last ECU to do. I assume it's due to being previously unplugged? Thanks. |
07-19-2016, 05:12 AM | #32 | |
1593
Rep 3,945
07-19-2016, 07:38 AM | #34 | |
1593
Rep 3,945
07-19-2016, 08:17 AM | #35 |
66
Rep 248
Let me pull the screenshot and get back to you. My issues seem to wider than just the ASD coding. Angel eyes and key fob window functionality are gone following Update also.
07-19-2016, 02:57 PM | #36 |
1593
Rep 3,945
If you or someone has flashed your car, aka updated the I-step, then you would loose most coding.
07-19-2016, 03:22 PM | #37 |
66
Rep 248
It's the factory defaults I seem to have lost though. There was no aftermarket coding on the car. Sidelights/DRLs and remote window control is all that's impacted as far as I can see.
Hopefully we'll rectify tomorrow. |
10-19-2016, 08:12 AM | #38 | |
589
Rep 1,094
Thanks. Going to try #3. If I left #2 alone, I assume it won't cancel/interfere with each other? It's easy enough to change #2 back, but was just curious what would happen, haha.
05-16-2017, 07:15 AM | #39 |
11
Rep 34
i coded mine out and would do it again.
does anyone know if second parameter is necessary? 3000à Model Range set to: F021 3000à Engine Type set to: N20B20 i did it both ways and can't tell difference between just doing F021 by itself and F021 and also setting engine to N20B20. |
06-22-2017, 06:50 PM | #40 |
Rep 12
I am new to coding and have hard time to find ASD 3000 'Model Range'. When I looked at the ASD modules, I think 'Model Range' is 'Baureihe'?
See the attachment. Can some one confirm? Thanks! |
03-31-2022, 01:39 PM | #42 | |
19
Rep 93
In nbt, there is no" asd sound off" Please 🙏 help. Regards |
04-02-2022, 02:36 PM | #43 |
Christmas Poo
1029
Rep 1,180
Likely different version of the software than from when I programmed this. Best way then is to unplug the active sound module in the trunk.
