05-10-2023, 05:28 PM | #1 |
176
Rep 152
Drives: '22 Dark Graphite M5C
Reduced redline
Well this was a new one. About 30 mins into my 35 min commute home and my redline dropped to 4000. I’ve had BMWs go into limp mode before, but there’s usually an associated message. Nothing here and super weird. I only noticed because it was sluggish accelerating during stop and go traffic. Got it in the garage, shut it off and restarted. Redline back to normal. Anyone else have this before?
05-10-2023, 07:05 PM | #2 |
176
Rep 152
Just did it again with the family in the car on our way back from a ceremony. It’s not super hot outside. Not sure what’s going on. 🤬
05-10-2023, 08:08 PM | #3 | |
4094
Rep 3,673
Drives: 2022 M5C
What happens when you try to go WOT? Does it go to 4000 and not further, but still accelerate sluggishly?
Not a BMW guy...but certainly an M5 guy.
05-10-2023, 08:20 PM | #4 | |
176
Rep 152
It was actually gutless under 4k and kind of reminded me of Eco mode in my previous 550. |
05-10-2023, 09:04 PM | #5 |
170
Rep 221
When my 18 had a rock damage one of the radiators (not the main engine one), it didn't throw any codes but would essentially not build boost due to the intake temps. The redline did not change on mine, but they could have changed it for the LCI. Just a thought.
05-10-2023, 09:25 PM | #6 |
4094
Rep 3,673
Drives: 2022 M5C
Damn, that’s right. I totally forgot about your motor replacement until you mentioned it here. Given that, I would get this into service immediately. This might have been less of a concern for someone else, but due to the history, I’d want this dealership diagnosed ASAP. Even if the car isn’t throwing codes now, it’s possible there will be stored codes related to the issue.
05-11-2023, 07:59 AM | #9 | |
176
Rep 152
Smack dab in the middle of the gauge, just like normal.
I actually wonder if it was a fuel pump issue starting to rear it’s ugly head since I was less than a quarter tank of gas at the time. Not sure if it would reduce RPMs in that scenario to not allow for high RPM usage and avoid cavitating the pump if it is starting to go. Filled it up last night, so I’ll see what happens today. |
05-11-2023, 09:30 AM | #10 |
316
Rep 396
Drives: 23 M5C, 19 X5
I would have thought BMW finally figured out how to make a good HPFP after 16 years. My wife's N54 needed 2 before they finally had an improved one that lasted at least 100k miles until we sold the car. I wonder if other brands with DI engines have problems with their high pressure pumps too.
Based on the comments on this forum I'm consistent about never letting my car get below 1/4 tank to protect the low pressure pump. That still gives me less frequent fill-ups than my old car since the mileage is better and the tank is bigger. |
05-12-2023, 09:13 AM | #12 | |
1540
Rep 2,008
DGM M5C176.00 |
05-12-2023, 09:55 AM | #13 | |
176
Rep 152
micvite1540.00 |
05-12-2023, 10:20 AM | #14 |
5234
Rep 10,616
You can get a scan tool sophisticated enough to see shadow codes for $200. Well worth the investment if you want to know more than the idrive screen telling you there is a malfunction and people giving you a list of malfunctions they have experienced. Maybe you do have a bad HPFP or a failing injector from a leaking coolant tank or maybe both or maybe neither and it is something else.
05-12-2023, 10:27 AM | #15 |
176
Rep 152
I can't believe I asked a car forum if anyone had experienced a very specific scenario of redline getting reduced to 4k with no service messages. What was I thinking? GFY |
05-12-2023, 10:53 AM | #16 |
5234
Rep 10,616
Someone is frustrated ….
Jakerx701.00 Maverik2594140.00 |
05-12-2023, 04:35 PM | #17 |
176
Rep 152
Just got done with the dealer. No stored codes or anything. They went through the logs and looked at the specific times the events occurred and they can see where it happened, but nothing that caught their eye.
They asked if I drive it hard and I said yup, not a problem there. They said that’s good, the car needs to be driven hard. 😂 Asked the service manager today and he said they didn’t ever hear anything. |
Patton2502939.50 |
05-12-2023, 07:57 PM | #18 |
4094
Rep 3,673
Drives: 2022 M5C
Not bad news all things considered. Hopefully (and sounds like) just a one off. Wishing you good drives ahead!
DGM M5C176.00 |
05-14-2023, 07:10 AM | #19 |
701
Rep 778
Not the best attitude to have when asking for help on a forum. The person who posted above you was merely suggesting you buy a scan tool to give you better data. I understand you’re frustrated but no need to be a dick.
12-29-2023, 08:20 AM | #20 |
178
Rep 176
Did you ever figure this one out?
I have a similar issue on my m8, been posting about it for a few months now. Just like you, Dealer couldn't find anything wrong with mine either. Have you discovered anything since? |
12-31-2023, 03:52 AM | #21 |
1540
Rep 2,008
Your issue is most likely intercooler coolant is low/leaking and causing your IATs or charfed air temps to go through the roof. Codes don't stick around after car is shut off so you have to scan it after it messes up before shutting car off.
12-31-2023, 12:24 PM | #22 |
775
Rep 569
Drives: 2019 M5 Competition
I had this happen twice on my m5c, out was vanos solenoids. Ill double check but I know it was something to do with vanos system, not a major issue, and was covered under warranty, but even if it hadn't been covered, I dont remember it being too expensive.
Would go into like 1/2 limp mode, no check engine lights, but would drop the redline like that. the replaced one, then the other months later. no issues since replacements. |
Holset274.00 |
