BMW M5 F90 (2018+) General Forums Engine, Exhaust, Drivetrain, Tuning Modifications    Worlds first M5 F90 Stage 1 ECU tune
Closed Thread
      06-30-2018, 03:59 AM   #23
Halim@HCP
Denmark
721
Drives: BMW F80 M3
Originally Posted by maciejm View Post
By the way:
+ 147 HP + 125 Nm ->
https://www.chiptuning.shop/en/bmw/5...441kw-4395ccm/
maybe this should have its own topic?
Please don't compare a piggyback flash to a flash tune. The flash tune is extraordinary and impossible for everyone else to do. This is what WE do.
The piggyback systems will run a lambda close to 1 (AFR high 14) and the engine will blow over a fraction of time.
FSociety3812.50
      06-30-2018, 10:18 AM   #24
onfireX5
3619
Drives: F90M5,F85X5M
Flash > Piggy. Agreed. But my piggy on my X5M keeps my AFR at Factory specs as long as I don’t exceed the factory mapping. Wideband corrects based on my logs. 3psi max over Factory works well for it.
Wont the M5 DME do the same ?
      06-30-2018, 06:10 PM   #25
Halim@HCP
Denmark
721
Drives: BMW F80 M3
The fuel tables are setup in a way so if you add a piggyback tune, AFR will go lean
      06-30-2018, 06:54 PM   #26
onfireX5
3619
Interesting. BMW set up a different logic structure to estimate Mass Air Flow since they deleted the MAF sensors. Did not know the fuel tables were inverted at a certain level. Very surprised BMW did that with the faster Widebands they added to the F90. Especially with torque based modeling, atmospheric deltas, etc. Risky.
So, for conversation, without you revealing anything proprietary, at what boost level does the table command a leaner than safe AFR ?
      07-02-2018, 11:58 AM   #27
Halim@HCP
Denmark
721
Drives: BMW F80 M3
Basically the AFR is set to 1 across!
But it's a target and will never go there. It's between 0.82-0.85 but if you add a piggy it goes to 1 and you have issues
      07-02-2018, 01:42 PM   #28
onfireX5
3619
.82 to .85 lambda is very reasonable for DI. I use .82 for my TT427 car that is PFI at 1500hp. Very safe for many years.
1 is going to cause failures quickly.
      07-02-2018, 08:49 PM   #29
DKCGT05
Drives: 2018 M5
Is this tune available? And if so, how much is it?
      07-03-2018, 06:39 PM   #30
Halim@HCP
Denmark
721
Drives: BMW F80 M3
Today we tested 100-200km/h stock and with the stage 1 tune
Stock with a passenger, tuned was alone.
Appreciate 2
jalkster220.00
FSociety3812.50
      07-03-2018, 08:46 PM   #31
felixleasing
Drives: 2018 M5
How much will the tune cost?
      07-04-2018, 07:38 AM   #32
maciejm
Drives: BMW M5 F90
is there any way to prevent losing warranty with this tune?
      07-04-2018, 08:08 AM   #33
onfireX5
3619
No
Closed Thread
