06-24-2019, 01:57 PM | #1 |
56
Rep 300
Taking apart Front grill
Hey guys,
I'm trying to separate the inner grille from the surround. I got the two side tabs and bottom 4 out easily. The top 3 slide out but the grille won't detach and I don't wanna keep pulling and break something. Do you have any tips? |
06-24-2019, 02:07 PM | #2 |
4074
Rep 5,233
On the F10 M5 platform it was a straight pull out; I did this several times and recall having to pull really hard. I didn't need to do this on the F90 (M5C) so I can't speak for certain on this.
I would check with IND and see if they've done a DIY for this yet.
av078956.00 |
06-25-2019, 11:42 AM | #3 |
47
Rep 113
I used a plastic pry tool and slowly worked my way around pulling the pieces apart as i went around. The first one took a little time but the second went much quicker. Hope that helps.. Not sure what you are doing but i replaced my black surrounds with Carbon.
av078956.00 |
12-26-2020, 05:52 PM | #6 |
41
Rep 109
This was horrific. There are 3 little clips sort of hidden below the large black clips. Wish I knew that, would had saved tons of time. Anyway, just did it, so if anyone wants to give it a shot, I can probably answer questions.
Jamesmick131.00 |
