06-13-2019, 05:50 PM | #1 |
4424
Rep 4,109
The smears have been there since I bought the car but they're mostly invisible until the sun strikes them. Given where I live, that happened for the first time yesterday (I'm embellishing slightly). I've tried every form of perspex/glass/plastic cleaner known to man.... or at least to me and nothing works.
Any suggestions? |
06-13-2019, 05:54 PM | #2 |
BMW Client Advisor
3452
Rep 2,504
Drives: 2020 M340i
I use the same cleaner apple uses at their stores and it works like magic
https://www.amazon.com/WHOOSH-Award-...gateway&sr=8-1
Contact me for all your BMW needs in the New England area.
jpichardo@tulley.com Top M Client Advisor in New England. |
06-13-2019, 05:59 PM | #3 | |
4424
Rep 4,109
06-13-2019, 06:18 PM | #4 |
BMW Client Advisor
3452
Rep 2,504
Drives: 2020 M340i
Make sure to use microfiber they include
06-14-2019, 07:51 AM | #5 |
257
Rep 495
If you have an "e cloth" or basically a water application followed by a high quality micro fiber cloth and really ensure you get the moisture off that was the only thing that really worked for me. I also had some luck with sunglasses cleaner which is I think the same as apple cleaner so hopefully that works! Down with smudges!!
limeypride4423.50 |
06-14-2019, 10:16 AM | #6 |
22
Rep 46
the whoosh stuff works but make sure you are not soaking the entire cloth just a little spray and polish with a dry section afterwards
limeypride4423.50 808F901.50 |
06-14-2019, 10:56 AM | #7 |
57
Rep 47
Looks like residual from when the dealer preped the car. You can also give this a try. Used for removing all oils and waxes on paint prior to doing ceramic coating or wax but also works great on glass.
https://www.amazon.com/CarPro-Eraser...s%2C149&sr=8-5 Last edited by srttan; 06-14-2019 at 11:05 AM.. |
limeypride4423.50 themnmd1691.00 |
06-15-2019, 09:23 AM | #9 |
204
Rep 386
I use a dry ultrafine microfiber cloth and wipe down the instrument cluster in my previous G30 and current F90. No chemicals required. Does the job well. If alot of stains or oils, use a damp tissue to wipe over the areas and then use a dry ultrafine microfiber cloth to wipe over. Does the job all the time.
Using chemicals, wet cloth, etc makes it worse.
Born in M Town
06-15-2019, 01:38 PM | #10 |
101
Rep 238
use any LCD TV/Screen cleaner that work without leaving any streaks. Have to work at it to get into those small crevasses. Not too bad but I literally put a towel over the dash so car wash guys don't touch it, as they always leaves marks.
06-15-2019, 01:44 PM | #11 | |
4424
Rep 4,109
I've tried every standard product imaginable including monitor wipes, glasses wipes, these so called special TV wipes, Windex for screens, vinegar, newspaper... nada. I just tried Whoosh and it's done! Thanks for the suggestion. |
RoGo330i142.50 |
06-15-2019, 02:29 PM | #12 | ||
4424
Rep 4,109
06-15-2019, 02:31 PM | #13 | |||
4424
Rep 4,109
06-15-2019, 02:49 PM | #14 | ||||
4424
Rep 4,109
That'll do! |
06-15-2019, 03:44 PM | #15 |
101
Rep 238
Its definitely a PITA to clean and not leave any streaks. I also used SprayWay cleaner. You have to use it very little at a time and don't let the product dry. Also I was working with it in very small circles to get at the edges. Keep the micro fiber towel as dry as possible, once it gets damp it will leave the marks.
06-18-2019, 12:35 PM | #17 |
4424
Rep 4,109
Yeah, I tried all of these ideas but the only thing that's worked so far is the magic cleaner I mentioned below, smudging it was my finger and then using microfiber clothes--it's unconventional but I no longer have the problem.
06-18-2019, 02:56 PM | #18 |
57
Rep 47
That mr clean magic eraser is like sand paper. Trust me on this, use CarPro Eraser and it will be done with. I use to use SprayWay glass cleaner on all glass and plastics but now I only use Carpro eraser as it will leave absolutely no streaks and leaves antistatic finish.
RoGo330i142.50 |
06-18-2019, 03:05 PM | #19 | |
4424
Rep 4,109
06-18-2019, 03:07 PM | #20 |
94
Rep 419
Drives: 2019 F90 M5B, 2006 E60 550i
Yeah, I just got a bottle Whoosh and the directions do say to do “Finger Smudging” within the fine print at the bottom of the bottle!
limeypride4423.50 |
