Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > DIY: Changing The Manual Trans Fluid In The 335
      03-16-2011, 01:34 AM   #45
mirbahabmw
mirbahabmw's Avatar
Drives: 2009 BMW 328xi
can someone please let me know with certainty what REDLINE fluid (D4 ATF or D6 ATF) do I put into my 2009 328xi 6MT??? I really really need to know this. Thanks.
      03-17-2011, 04:39 PM   #46
Analog
Analog's Avatar
Drives: 12 F10 535 xdrive
I have 06 330, is the Redline D4 okay for my car as well? and is the procedure same as 335? thanks
      03-17-2011, 04:45 PM   #47
BKV122
BKV122's Avatar
Drives: E90
2006 330xi  [9.50]
I put Redline D6ATF into my MT. If you read redline's website about our car i think the D4 is a older type and D6 replaced it, so both would do fine. But double check redline's site
Monaco Blue 330xi - Terra Interior/6-MT/Sport/Premium/Cold/CSL's/M3 Spoiler Lip/Black Kidney's
      03-17-2011, 05:53 PM   #48
AlanAZ
AlanAZ's Avatar
40
Drives: E90 325i sport manual
With certainty, it is D6 ATF, for all E90s.
I spoke with Redline's Tech Support as I was having a shifting problem and there was conflicting information on their website. However, D4 is only 10% more viscous, not much difference, and for a few situations (very hot climate, race track use) may be more appropriate.
Update: now that I've experienced a couple 100F days, D4 was the right choice for me. Shifting is perfect, and I would not want to be running any thinner than this.
      03-17-2011, 06:56 PM   #49
bumere90
Grozniy
Drives: Carless
Will be doing that in a month. Has anyone tried using Pentosin fluid?
-fatman
      03-19-2011, 04:02 PM   #50
Analog
Analog's Avatar
sorry for the noob question. How do i pump the fluid into the fill hole? assume I use the Redline (not the RP bottle). what kinda pump do i need? thanks a bunch
      03-19-2011, 04:16 PM   #51
bumere90
Grozniy
Drives: Carless
walmart has universal pumps for 5 bucks
-fatman
      04-05-2011, 02:53 AM   #52
Analog
Analog's Avatar
Just did the transmission fluid change tonight. (used Redline D6) N to 1st, and 1st to 2nd require much less effort than before. thanks for this DIY!!
      04-05-2011, 07:59 PM   #53
AlanAZ
AlanAZ's Avatar
40
I wish I had seen this earlier (before I tried Sychromax),
http://www.royalpurple.com/transmission-chart.html
according to RP's website, Synchromax is compatible with MTF-LT-1, but not MTF-LT-2 & 3, which is what E90 transmissions use.
      09-21-2011, 12:13 PM   #54
LocDawgg
68
Drives: AW e90
im assuming you would screw back in the drain plug before pumping new fluid in via fill-plug LOL i didnt see it in the DIY
      09-26-2011, 01:11 PM   #55
witeagle
7
Drives: 14 BMW Z4 2.8i * 10 BMW X3
It's there:
"Once it's drained enough then put the plug back in and tighten it."
'08 335i Coupe / 6MT / Sport / Premium / Nav / Cold Weather Pkg / Space Gray / Black Dakota Leather & Aluminum Trim
'10 X3 SAV / Premium / Nav / Cold Weather Pkg / Alpine White / Sand Biege Nevada Leather / SAV Pkg
      10-28-2011, 09:24 PM   #56
DaanBMW
DaanBMW's Avatar
Romania
84
Drives: 2007 328i coupe
Sooo... what do you meand by this exactly ? Above I think I read D4 ATF is the proper oil for e9x manual trannys. The list you point to on RP's site indicate non-ATF fluids: Max-Gear or Synchromax.
      11-03-2011, 05:41 PM   #57
AlanAZ
AlanAZ's Avatar
40
The list I point to is RP's Cross Reference Chart for Manual Transmissions. They do not list an oil (ATF or not), that can replace the oil (MTF-LT-2 or 3) used in our gearboxes.
RedLine recommends D6 ATF for use our gearboxes (for most applications.)
      11-27-2011, 06:53 PM   #58
JoosyJoos
JoosyJoos's Avatar
Drives: 2011 335d
2008 BMW 335i  [0.00]
Does anyone know if the drain plug uses an O-ring or a washer? I don't wanna risk replacing the fluid and having it seep around a crush washer. I would assume I could reuse an O-ring without problems.
feedback...?
1997 M3 Coupe - BMWCCA I-Prepared #22
2006 M Roadster - 23,000 miles and slowly counting
      11-27-2011, 09:32 PM   #59
AlanAZ
AlanAZ's Avatar
40
No crush washer, the drain and fill plugs (same plug) have a built-in o-ring. I replaced my drain plug both times I changed the fluid. You may want to consider a magnetic plug to help keep particles out of the fluid. Gold plug makes them. Turner or Bavauto may have them also.
      02-04-2012, 10:54 AM   #60
LocDawgg
68
Drives: AW e90
Where is the drain plug located as oppose to the fill plug
      07-04-2012, 06:47 PM   #61
iverson3yoo
If you ain't first you're last
iverson3yoo's Avatar
Drives: e90 M3
2008 BMW M3  [0.00]
Changed my trans fluid today. Followed this DIY to the letter. Real easy. Get a pump from advance auto parts for $8
      12-08-2012, 05:44 PM   #62
left123
left123's Avatar
56
Drives: TiAg 330i 6MT ZSP
This DYI worked great for my 06 e90 330i. The only addition is I removed an additional bracket adjacent to the bracket mentioned in this procedure. Very simple, just a socket (14mm I believe).
I used Redline MTL per Mike Miller's "old school maintenance" write-up.
Also, I used a Pittsburgh Automotive pump here:
http://www.amazon.com/Pittsburgh-Aut.../dp/B006ZB8PDM
Worked flawlessly.
      12-14-2012, 12:02 PM   #63
cbad335
cbad335's Avatar
Drives: '09 E92 335i
Just did this, along with diff fluid. A little messy but that was my fault, hahaha. Certainly saved a few hundy doing it myself. I went with OEM fluids and had the dealer fill some bottles from their drums. I also used one of those transfer pumps, which I purchased from Harbor Freight. My '09 only had 4600k on it when I obtained it but had sat for most of the last 3.5 years. I wanted to do a late, "break-in" fluid change. Fluids were pretty mirky looking, especially the diff, so I'm glad I did it. Will do again in 30k.
| 6MT | ZSP | ZPP |
      01-16-2013, 08:33 PM   #64
S62PWR
BMW CCA# 90345
Drives: 08 335i Cpe 6 speed
Smile Red Line MTL
Just bought an '08 335i Coupe w/ 33K miles. Hated the way it shifted, my 13th BMW with a manual gearbox, including 4 ///M cars. I swapped the FF Magic Permanent Gear Oil for Redline MTL today (like I do w ALL my BMW's) and viola! So much better, particularly when up to tempature. I was considering selling the car I really disliked how it shifted relative to my E36 ///M3. My ///M3 has 93K miles on the odo and has had 3 gear oil changes with Red Line, many track days and shifts like a dream. Anyway, short shift kit arrived today from Turner, so it should get even better next week. The final act will be replacing the Clutch Delay Valve w/ a modified one. Searching for that DIY next! BTW, my tranny had the blue MTL-LL3 tag on the side which read "Do Not Change Gear Oil". Sorry, eat me. The fill plugs seemed like they shouldn't be reused really. I'll watch if it leaks and I'll purchase a new set the next change at 60K. Seems like it should be magnetic to collect metal bits, no? Used fluid didn't look bad to me, just really didn't care for the feel. Some may wonder why I used RL MTL when the spec calls for D4 or D6-ATF. Frankly, the differences are slight when you're talking about Red Line, which is some of the greatest stuff out there. I think the ATF is a bit more slippery/easy to shift when cold. I just like the feel of the MTL better. There are no worries about wear with either product from RL. I've also used the RP Sychromesh. Its really slick, maybe a little too slick for me. Anyway, my 25 years experience points me to Red Line MTL every 30K, more often if I track the car.
      01-23-2013, 08:48 PM   #65
axeswingingflannelwearer
Drives: 2007 328xi Black on Black
Thanks!
      04-22-2013, 02:08 PM   #66
DaanBMW
DaanBMW's Avatar
Romania
84
Are you still happy with the MTL in your tranny ? Still trying to figure out if I'll go D4 ATF or D6 ATF or MTL...
328i Sports Pkg, Michelin PSS on Staggered 18" OZ Ultraleggeras
. BMS Powerbox. Cyba scoops + Rev motoring intake hose + charcoal delete. Wavetrac LSD
. M3: subframe bushings + sways + control arms (fr & rr). Meyle rear toe arms. M3 diff fr bushings
. BMW Perf: v2 springs + v1 dampers. Valeo SMFW+clutch. 034 MotorSport engine mounts
. Short Shifter + Turner PU bearing + ZHP M weighted shift knob. CDV delete
