05-05-2024, 09:22 PM | #2 |
1209
Rep 506
Yes, swapped a ProRam filter with velocity stack on my 2023. I tried to upload a photo of the set up but it says invalid file.
2023 X3 M40i @b58x3
2020 M2 Competition @s55m2 |
05-05-2024, 09:25 PM | #3 |
58
Rep 110
05-06-2024, 12:31 AM | #4 |
1209
Rep 506
90mm outside diameter with medium cone filter. The lid will not fit unless you modify it, I left it without the lid for now.
2023 X3 M40i @b58x3
euroshowoff57.50 |
05-06-2024, 09:28 AM | #5 |
58
Rep 110
thanks - i found an earlier post from you, noticed you had a tbolt clamp. did that come with the filter, or does a normal worm clamp come and you upgraded?
05-07-2024, 02:08 AM | #6 |
1209
Rep 506
I purchased a silicone coupler and it came with the T-Bolt clamps.
2023 X3 M40i @b58x3
euroshowoff57.50 |
05-09-2024, 09:19 AM | #8 |
58
Rep 110
deviation01126.00 |
05-09-2024, 08:49 PM | #9 |
126
Rep 222
05-10-2024, 04:27 AM | #10 |
112
Rep 55
... sorry sorry, i may got lost somewhere... mst 3.5" filter replaced with 90mm, that right?... same same but different somewhere?
05-10-2024, 06:41 AM | #11 |
58
Rep 110
It’s the filter with included velocity stack.
05-10-2024, 09:29 AM | #13 |
58
Rep 110
deviation01126.00 |
05-10-2024, 09:44 AM | #14 |
126
Rep 222
euroshowoff57.50 |
05-10-2024, 10:32 AM | #15 | |
Your Average B58'er
307
Rep 253
I can say that it did not make a difference in regards to IATs going from enclosed to open top. Same temps over ambient. With these OTS tunes, our stock intake manifold are pretty efficient still.
2019 X3 M40i - MHD STG2 HPFP E40ish | MHD FlexFuel Kit | TU HPFP | xHP stg 3 | VRSF catless downpipe | MST intake | BMS occ | Verus turbo heat shield | P3 V3 gauge w/ P3 ESVA | FTP Charge Pipe | RossRacing PCV v1 VTA | MSS Springs | RES Exhaust w/o valves | Vossen HF-5 21x9.5/10.5 265/295 PS4S | Yellow DRLs | Paragon Rotors w/P3 pads |
deviation01126.00 |
05-10-2024, 11:14 AM | #16 |
126
Rep 222
That is good info right here. At this point I am sure its mostly based on looks/sound preference.
