12-20-2007, 11:19 AM | #45 | |
2751
Rep 6,759
I guess BMW raised my expectations, huh?
2018 F80 Santorini 2019 Z4 3.0i 2022 X2 M35i |
12-20-2007, 12:45 PM | #46 |
1er
73
Rep 1,205
If only BMW would copy that transmission... best shift feel of any car I've driven (the S2000). The worst has to be the rubber 1997 328i tranny I drove last week.
12-20-2007, 12:49 PM | #48 | |
2751
Rep 6,759
But rest assured the transmission feels very very good - it does not bear comparison to any E36 transmission. All I had to do on the 335 is install a BMW short shift knob - the 135 already has it.
12-20-2007, 12:51 PM | #49 | |
1er
73
Rep 1,205
Yeah, I meant the feel not unnecessarily the actual schematic. All of my past cars have been honda/acuras, too bad they refuse to put a bigger engine in the S2000, would have been on my short list. Still a great car. |
12-20-2007, 12:56 PM | #50 |
2751
Rep 6,759
That's exactly what I meant too - you will like the feel of the 135 tranny, it's very mechanical with very well defined gates - and within 200 yeards of driving you will understand why it has to feel beefier than the S2k tranny.
01-25-2008, 02:12 PM | #51 | |
22
Rep 253
Drives: 335 cab,C-6 08, 73 911E 59 D,
135 here in Germany today, and the performance was amazing really amazing. The DSC was going nuts until I turned it off You will love this car ! I owned 2 S-2000s that were track bitches and had 3 trannies let loose, 2nd gear syncros twice, the whole box once The 135 is a great ride, You will love this on a track. It drifts very nicely ! |
01-27-2008, 09:05 AM | #53 |
22
Rep 253
Thanks for the welcome
I have driven the 135 and can tell you, its more fun that anything
I have driven in a long long time It is a real pocket rocke. I am taking it out for an overnighter. The Braakes are pretty amazing, actually I would compare it to the world of Evos, STI or even the Cayman S or Boxster S It will be an expensive car to insure as the car is that scary fast I would peg the 0-60 in the 4.6 range with race tires and some break-in Cheers from Germany |
01-27-2008, 10:48 AM | #54 |
2148
Rep 10,176
Welcome Gmund1948! By any chance are you in Gemunden (and hence your screen name)? I have been there many, many times while visiting relatives in Eussenheim.
01-27-2008, 10:49 AM | #55 | |
Freude am Fahren
17
Rep 388
"Oversteer is best because you don't see the tree that kills you" -- Richard Hammond |
01-27-2008, 11:23 AM | #56 | |
59
Rep 765
01-27-2008, 01:35 PM | #57 |
22
Rep 253
Screen Name
Actually Gmund1948 is derived from a small town in Austria
"Gmund "where the Porsche family moved to during the war and in 1948, Ferry Porsche built the first car with their name the number 1, a midengined car based on the volkswagen that his father designed. The first Porsche was built in a converted sawmill I was lucky enough to go there for the 50th aniversary of this event. I own several Porsches from 1957-1996 and a 335 /e93 6 Mn convertable, and a 08 C-6 Corvette with the Z-51 suspension. I will now order a 135 as a daily driver, be warned it doesnt have the smooth lines of the 3 coupe, and the back seats are really small and the trunk very large. I will order sport, metallic and heated seats, the car is really equipped well and will blow you away The Europeans pay 46 K Euro for the 135 equipped like we get it so check out the exchange rate and dont complain from Germany |
02-16-2008, 06:26 PM | #58 | |
Rep 79
Link to Dave Coleman Article on SCC The N54 is an evolution of the N52 engine. The N family was not designed from the ground up for FI. Many of the old school 'legendary' Japanese turbo engines (2JZ, SR20, RB26) *were* engineered from the ground up for FI; They were designed with oil squirters (keep down oil temps), forged pistons (better withstand detonation), beefier rods (ditto) and low compression ratios (ditto) -- all notables that are lacking in the N54. Had BMW followed these best practices, the N54 would be significantly more expensive and a bit rougher around the edges. It would also probably be capable of a Supra-like 800hp... So many damn pros and cons! That said, BMW NA *can* overcome the high oil temp problem simply by adding a gigantic oil cooler. Here's a great shot of the Porsche design that Mike Miller alludes to (Ernie Jakubowski's Targa Newfoundland 2006 Entry -- Cayman S): Sorry for thread resurrection. |
02-16-2008, 07:54 PM | #59 |
2148
Rep 10,176
Other than it being an inline 6 BMW engine produced around the same time as the N52, they are very different motors. The N52 has a magnesium/aluminum composite block, where the N54 has an solid aluminum block, with cast iron cylinders. They have different internals as well. This was done so it CAN handle the extra stress from the turbos. The magnesium block was deemed unfit for the extra stress and heat. The N54 is also about 75lbs heavier than the N52, because of these differences...
Again, other than being a BMW inline 6, they are extremely different motors. I do think that they are onto something by saying it needs a biiig oil cooler to push more power, just as any turbo car can benefit from. |
02-16-2008, 07:57 PM | #60 |
No longer moderate
325
Rep 4,401
02-16-2008, 08:04 PM | #61 |
2148
Rep 10,176
Could very well be, Hugo. the motor is within the wheelbase though, so 75lbs there is not as balance changing as 75lbs on the rear bumper, beyond the wheelbase.
You could probably eliminate the forward weight addition of the N54, with half the weight beyond the wheelbase. Good thinking though... that may very well be the case. I wonder if the N52 powered 128i has the ballast? |
02-16-2008, 08:12 PM | #62 |
No longer moderate
325
Rep 4,401
Cylinders 1-3 are in front of the front axle, add the weight of the intercooler and viola, you have an approximation of the trim weight. The battery ought to be the same 128i/135i so that weight should already have been accounted for.
Now I remember why I like the Cayman so much - weight inside the axles. |
02-17-2008, 02:27 PM | #64 |
13
Rep 610
You two brothers..? sciamop, The N54 was designed from the ground up as a directed injected, forced induced engine. Don't let the fact that BMW continued use of previous award winning design fool you. They just incorporated the use of their past engineering accolades into the making of this engine. Hollowed camshafts and forged cranks, there is a lot of new and expensive technology that makes this engine what it is. All your "notables" are surpassed in the N54. Some reading may be required on your part. |
02-19-2008, 10:48 AM | #65 |
2751
Rep 6,759
My understanding is that the N54 is an evolution of the M54 engine from the E46 cars. The magnesium/aluminum N52 block was considered unproven as far as strength so they went back to the aluminum M54 design.
I think I've read this from a believable source, but as so many of these internet rumors, it could be wrong.
02-19-2008, 12:05 PM | #66 |
13
Rep 150
In another thread we were talking about if you get the sports pkg, you get dual oil-coolers. And the over heating issues only happened to the first few 335i, BMW has since then addresses the issue and the problem should be fixed.
