10-19-2022, 07:18 PM | #23 |
292
Rep 605
If anyone needs the part numbers or PDFs for the transfer case fluid change, and/or the front and rear diffs, I have them. I was shocked how many metal filings we're in my transmission fluid pan after only 30k miles. Glad I changed it, and will be changing all of these fluids every 30k miles. So economical doing it yourself.
EPTXM579.00 hunter879395.00 |
10-26-2022, 10:04 PM | #24 | ||
4146
Rep 7,163
Drives: F90 M5 / F15 50i
'07 Yamaha R1 (sold)
10-26-2022, 10:36 PM | #25 | |
1839
Rep 1,328
But, I agree with you, that those fluids aren't "lifetime" in any way. But I'm not sure BMW makes financial decisions to NOT recommend fluid replacements on those. Seems to me, they would make a lot more money making us change them at 75,000. Just my $0.02 Shawn |
10-26-2022, 10:38 PM | #26 | |
1839
Rep 1,328
Shawn |
10-27-2022, 12:02 PM | #27 |
133
Rep 393
Drives: 2021 M5C
10-27-2022, 01:31 PM | #28 |
5266
Rep 10,652
shawnhayes1838.50 hunter879395.00 |
10-28-2022, 06:50 AM | #29 | ||
983
Rep 1,801
10-28-2022, 07:22 AM | #30 |
5266
Rep 10,652
This will help. Might be a plastic pan like BMW uses on some models but the ZF 8 speed is widely used — in many cars and trucks from many brands — and the process is similar for all. We have finned aluminum pans with drain plugs, which is nice.
https://blog.fcpeuro.com/how-to-chan...on?hs_amp=true |
10-28-2022, 07:34 AM | #31 | |
983
Rep 1,801
10-28-2022, 09:29 AM | #32 |
5266
Rep 10,652
It seems hard to find a really capable one that does not have a subscription requirement to keep the features and those subscriptions are hundreds of dollars a year. I have a Launch x431 PAD V, but it is more than you need for this.
I’d look into what the $400 Autel MX808 can do ($100 per year subscription). I used one briefly and then changed to the much more capable $1200 MS906BT that requires an annual subscription that costs as much as the MX808 alone, and then changed to the $2400 Launch x431 PAD V. The cheapest option that may have the potential is the Foxwell NT510/520/530 with the BMW specific module that you can choose and download for free when registering the product. I have had an NT510 for years and used it when changing diffs and transfer and trans fluids in my E61 535xi but am not sure whether it can do what would be needed on the F90. I have the fluids for the diffs and transfer case but have not changed them yet so I have just been gathering info on the jobs. I’ll do the trans fluid after I do those. |
shawnhayes1838.50 |
10-28-2022, 11:30 AM | #33 | |
1839
Rep 1,328
Shawn |
10-31-2022, 12:46 PM | #34 |
IG: @M5RCY_
365
Rep 317
PRO TIP!
I HIGHLY suggest you all add a magnetic drain plug to your diff cases!!! Troy Jeup made an IG post on his IG page about this. He shows HOW MUCH shavings can collect in there in such a short time! Protect your self and your car. add magnetic drain plugs
Autotecknic.com - code: M5RCY for 12% off
Project Gamma - code: M5RCY for 5% off Dura-Coating - code: M5RCY for 20% off |
11-08-2022, 08:33 PM | #35 |
4146
Rep 7,163
Don't recommend. Or at least Be careful. They can also be too long and make contact with the gears inside. Saw this issue on the X5M side of the house.
shawnhayes1838.50 |
11-14-2022, 11:44 AM | #37 | |
IG: @M5RCY_
365
Rep 317
11-15-2022, 07:24 AM | #38 |
4146
Rep 7,163
What size is the drain plug? I'm no where close to needing this service yet but like compiling data in my service logs I build.
11-15-2022, 08:01 AM | #39 |
5266
Rep 10,652
Rear diff is M22x1.5 PN 33117525064. Not sure about front diff and transfer case. I’d probably buy magnet plugs just for the drains and not for the fills.
11-22-2022, 01:38 AM | #40 |
62
Rep 240
iv'e just had mine in for the following at 36k Miles.
Transfer Box Service Front Axle Service Rear axle Service Engine Oil and Microfilter The Rear Axle oil looked like it was tired so i'm glad i did the full service. Not a cheap service but worth it |
11-23-2022, 07:55 AM | #41 |
4146
Rep 7,163
Front/Rear Diff & Transfer Case Oil Change Advice
They should all be the same. Thanks.
12-14-2022, 07:37 PM | #43 | |
4146
Rep 7,163
https://ind-distribution.com/collect...l-plug-m22x1-5
03-16-2023, 08:37 PM | #44 | |
IG: @M5RCY_
365
Rep 317
