E91 Leonia
10-17-2020, 02:57 PM | #1 |
198
Rep 264
E91 Leonia
Hi Everyone!
I decided to make a build thread for this E91 I purchased. I bought the car site unseen from Ottawa-Canada, whereas I am located in Vancouver Canada (4362 kilometers away) - with the intention of enjoying a COVID-19 *within country borders* cross country trip. I am calling her Leonia - for the province of Leonie in Bavaria. Tacky I know but my girlfriend says I have no imagination. I don't think I'll do too much with it but I think there is a bunch of interesting things that I can do while I revamp the vehicle. This is the original for sale ad. On-going work links: Hella Water Pump & Thermostat Replacement: https://www.e90post.com/forums/showp...7&postcount=50 Vanis Solenoid Replacement: https://www.e90post.com/forums/showp...0&postcount=69 F10 Steering Wheel Modification: First test-fit https://www.e90post.com/forums/showp...&postcount=123 Hella Horn Upgrade https://www.e90post.com/forums/showp...&postcount=117 Headlight Restoration https://www.e90post.com/forums/showp...&postcount=121 https://www.e90post.com/forums/showp...&postcount=122 Clear Bra Removal https://www.e90post.com/forums/showp...&postcount=162 Last edited by bshambam; 04-01-2022 at 12:11 PM.. Reason: Update 02 |
10-17-2020, 03:02 PM | #2 |
198
Rep 264
This is how she looked like when I picked her up.
Some of the parts that needed to be replaced by the dealership were as follows: Oil Pan Gasket Tires front and rear Brake Pads & Rotors front and rear Front and rear Window Washer Fluid Pumps The car was on the lift as they had forgotten to replace the front Window Washer Pump, so one of the owners of the Dealership took one off of is own X3. Last edited by bshambam; 09-22-2021 at 01:11 PM.. |
10-17-2020, 03:07 PM | #3 |
198
Rep 264
Update 2021-09-16, approximately 1-year & 1 month after the initial purchase. The car is on the road.
The following parts were replaced at 197,025 kilometers. Engine: Modified 2-Gauge Main Engine Ground Strap Modified Belt Guard @ Front Main Seal Modified ATI Fluid Damper Pulley Modified Coolant Neck @ Upper Radiator Hose Modified Fuel Pump 400 LPH Walboro Replacement Coolant Return Hose (Aftermarket) Bosch Front & Rear x 2 Oxygen Sensors Bosch Ignition Coils Bosch Spark Plugs Bosch Starter Motor HELLA/oem water pump BMW Left & Right Front Engine Motor Mounts BMW Vanos Solenoids BMW Vanos Solenoid Filters BMW Belt Tensioner, Slave Pulley VDO Replacement Fuel Pick-up system Gaskets: Oil Filter Housing Gasket Valve Cover Gasket Valvetronic Motor Gasket ESS Sensor Gasket Coolant Neck to Short Block Gasket Front Engine Seal Rear Engine Seal Intake Manifold Gasket inclusive of PCV system hoses *all flex hoses* Exhaust Manifold Gaskets + Hardware Exhaust Manifold to Exhaust Runner Gasket Transmission: Clutch Flywheel Shifter Fork Stop Pin Shifter Fork & release bearing Shifter Linkage Pins x2 Fluids Change: Power Steering Fluid Flushed with new CH Brake System Flush with Motul Fluid Clutch System Flush with Motul Fluids Engine Oil Replacement with Motul 8100 + New Oil Filter Transfer Case Flush with Motul Gear 300 Front & Rear differential Flush with Motul Gear 300 Radiator Flush with BMW fluid @ 50/50 mix ratio Exterior Lighting: LED Angel Eye H8 Bulbs LED Fog Light Bulbs LED Front Headlight Bulbs LED Rear Signal Lights LED Rear Brake Lights Maintenance: Total interior detail Total Engine bay detail inclusive of front clip disassembly Complete under-tray detail inclusive of replacement hardware for rusty bolts/washers Ceramic Coat/Seal all supporting black Plastics Silicone Additive for all door seals Panoramic Sunroof Drainage Hose Flush New OEM Cabin Air Charcoal filter Misc Changes: Interior: F10 Msport Steering Wheel + Canbus Module Eonon Headunit w 7" LCD Display Replacement of Drivers Side Handle with Glasses Holder Leather Covered 6-Speed shifter cover Red colored Start Button 35% Ceramic Window tint from Passenger Rear doors and beyond Replacement Rear Right Window Guide Replacement Rear Right Window *car was broken into 2020-12* Replacement Rear Tailgate Door Latch Cover Replacement Rear interior Screw Covers Yellow Top Optima Deep Cycle Battery Exterior: New Hella Fog Light Housing Restored OEM Front Headlights Replacement Clear Front Bumper Reflectors Thule Flush-fit Roof Rack 25mm Rear Wheel Spacers Bosch Front & Rear Oem Windshield Wipers Last edited by bshambam; 09-25-2021 at 07:34 PM.. |
xlr88r290.50 |
10-19-2020, 05:12 PM | #6 |
198
Rep 264
One of the first things I needed to do to the car is to install a hitch. Time was of the essence so I found a Curt hitch on amazon and quickly installed it.
While the bumper was off, I also did some house cleaning. The car is 10 years old after all, and I am a clean freak - so I did what was natural to me. Cleaned* I chose a Euro style ball mount, although... I'm not too sure what other options were available. Last edited by bshambam; 09-22-2021 at 01:10 PM.. |
cbryant5143.00 lab_rat394.50 |
10-21-2020, 01:00 PM | #7 |
198
Rep 264
After the hitch was wired and installed, i moved onto the engine bay to update some essentials.
Ignition Coils & Spark Plugs These are the old guys w/ 192 k kilometers I used a proper Spark Plug Gapping tool. It's a bit extra but you learn from other peoples mistake, and there are stories online if Spark Plug Tabs snapping and destroying engines. However.... it is extremely rare. Prep to install the new ignition coils w/ Dielectric Grease on the Boots Last edited by bshambam; 09-22-2021 at 01:13 PM.. |
10-24-2020, 03:32 PM | #8 |
198
Rep 264
I put the ignition coils in but Cylinders 3, 4, & 5 had misfires. I didn't know it at the time but there were several oil leaks with the Valve Cover Gasket, Valvetronic Motor Gasket, as well as the Eccentric Shaft Sensor Gasket.
The oil leaks caused a grounding issue with the coils. I have no idea how the original coils managed to function when the grounds were soaked with oil, but they did. I ended up putting the original ignition coils back into the car without realizing what the true problem was.
William Mackenzie
IG: Shambam_makes Twitter: B_Shambam |
10-24-2020, 03:33 PM | #9 |
198
Rep 264
I installed a new serpentine belt after understanding the whole
'belts getting eaten' paranoia scenario. I also installed a new tension-er and bolt.
William Mackenzie
10-25-2020, 09:21 PM | #11 |
198
Rep 264
Thanks for the comment! It is very much needed maintenance. Nothing exciting really, as mentioned in the first post haha
I did a coolant flush and it was really, really bad. I used a filler gauge to get the absolute correct size for the lower radiator plug. Metal on plastic has always been a nightmare for me. It's 10 year old plastic that has seen a lot of heat.... not a great idea to use a lot of torque on it. Nasty fluid. I'm pretty sure it hasn't been changed since new.
William Mackenzie
10-26-2020, 08:04 AM | #12 |
2136
Rep 1,509
That and brake fluid the two most overlooked maintenance things out there.
11-04-2020, 11:34 AM | #14 |
198
Rep 264
Not much going on at the moment.... I've been waiting for OEM parts from Germany since October 21st...
William Mackenzie
IG: Shambam_makes Twitter: B_Shambam Last edited by bshambam; 03-17-2022 at 02:14 PM.. |
11-07-2020, 01:45 PM | #15 |
198
Rep 264
I'm am going to consolidate some of the posts I made into this thread.
https://www.e90post.com/forums/showthread.php?t=1758602 I started to tear down the intake manifold as I suspected I would need to overhaul the CCV/PCV system. Uninstalled and cleaned the entire Intake Manifold Cleaned and installed new Intake Runner Gaskets Installed a new Sensor Cleaned the old Map Sensor with Sensor Cleaner and a wipe down Installed a New Hose that connects to the Valve Cover
William Mackenzie
lab_rat394.50 |
11-09-2020, 10:38 AM | #16 |
198
Rep 264
Another consolidation post.
This thread is dead I supposed due to the image host expiring the images? https://www.e90post.com/forums/showthread.php?t=1758575 With the intake manifold removed, there was a discovery that the hose leading to the vacuum pump had a leak.
William Mackenzie
11-09-2020, 10:41 AM | #17 |
198
Rep 264
After replacing a bunch of these parts, I noticed a bit of white smoke from the exhaust AFTER the car had warmed up.
So next up I replaced the Oil Filter Housing Gasket. I am guessing that a slow leak in the gasket was causing the coolant and oil to mix. I went ahead and flushed both fluids and the leak doesn't look as bad, but it does explain why the coolant was brown with the first flush.
William Mackenzie
11-11-2020, 10:51 AM | #18 |
198
Rep 264
After completing all of those maintenance items, I bought a set of Thule Crossbars and a 460L Roof Box.
William Mackenzie
11-11-2020, 08:50 PM | #19 |
198
Rep 264
Last check before leaving for Vancouver!
So much wheel gap... and then about...3000 kilometers afterwards, there is no wheel gap in the back haha especially with upwards of 2,000lb in the back.
William Mackenzie
CDirks135.00 |
11-12-2020, 03:15 PM | #21 | |
198
Rep 264
I used the following formula of chemical solutions to clean the manifold. Pressure Wash - Dishsoap to tackle the first layer of Grease - Rinse - Trisodium T.S.P. to degrease and surface prep - Scrub - Pressure Wash - Rinse - Chemical Brothers VRP on the outside for protection. Sensors that were re-used were subject to MAP sensor cleaner - a blow-out with a Dewalt Cordless Blower - WD-40 to remove remaining traces of water.
William Mackenzie
lab_rat394.50 |
