09-30-2020, 04:54 AM | #1 |
539
Rep 1,463
Do piggyback tunes get flagged like flash tunes?
Since 2020/2021 models have some new ECU's that aren't cracked yet, it seems I have to piggyback a tune like JB4 instead anyways (not going to bench flash). Does JB4 get flagged using their new flagging methods (such as flash tunes getting noticed at service intervals)?
09-30-2020, 06:47 AM | #2 |
In the Details
1809
Rep 866
Drives: Yes
Garage List 2020 AMG GTR [0.00]
2022 R8 Quattro Spyder [0.00] 2023 X5M50 [0.00] 2023 718 Spyder [0.00] 2024 Silverado [0.00] 2024 Civic Type R [0.00] |
The piggyback itself would not be flagged by the computer system but could be flagged visually by a technician if you left it on.
The issue is at the time of failure, if something happens and you then remove the piggyback then it won't matter. BMW can see engine parameters up to and at the point of failure, which means if you're running a piggyback, the parameters won't be within stock ranges and they will know. |
09-30-2020, 09:25 AM | #3 |
Joint Chiefs of Staff
24133
Rep 190,687
Its a lot harder to be caught with a piggy than flash
with that being said in 99.99% of the case you are safe with either one
09-30-2020, 10:00 AM | #4 | |
55
Rep 107
Any tune can be discovered if the dealer/manufacturer wants to look into it. Any major issue with the transmission/engine most likely will be looked into and the warranty will most likely be voided if they find a tune. Do you think manufacturers have people monitoring these forums? Answer: yes. Have a friend that is a shop Forman for a Porsche dealership. Says it takes minutes to find out if any kind of tune was used if they want to. |
TrevorM33321.50 |
09-30-2020, 02:21 PM | #5 |
539
Rep 1,463
I'm not worried about the tune per se, just the fact that I think I can't tune my car with a flash tune. Don't want to "bench" tune. Don't wanna buy one and then realize it won't work hence why I asked if JB4's will work.
Sort of dual ended question as I was curious. I've ran JB4 for years on my other cars. |
10-01-2020, 12:44 AM | #6 |
12953
Rep 18,703
If you are doing JB4, don't use the EWG connectors.
With those plugged in, you are adding more data that is being altered which will shows in the DME logs. Without those plugged in, it is pretty much acting like BMS Stage 1 or RaceChip GTS Black. Just a simple 2 boost sensors that need to be tapped into.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
Maverik2594140.00 Hockeytyme575.00 |
10-03-2020, 12:17 PM | #7 |
143
Rep 309
You are defo "safer" with the piggy, as the BMW techs will need to suspect something, then perform some analytics on the engine data to then refuse the warranty work. With a remap, they can see instantly it has been altered.
2020 C8 RS6
2019 F90 M5 2017 C7 RS6 2016 F10 M5 2010 C6 RS6 |
10-06-2020, 07:47 PM | #8 |
4140
Rep 7,160
Drives: F90 M5 / F15 50i
I've heard their new set up can detect if the turbos have simply been run outside their operating parameters and it'll flag. But not sure myself. But if true then I would suspect both can be detected. 😕
'07 Yamaha R1 (sold)
10-06-2020, 08:04 PM | #9 |
3322
Rep 8,083
it's very simple, if you blow a motor BMW will bring out a regional tech to look at the car. At that point, you're done.
So the question should be, "if i tune, what are my chances my engine blows" becuase if it does, get your checkbook out. |
Longboarder3429.50 |
10-07-2020, 12:12 PM | #11 |
285
Rep 504
A good piggyback is a lot more difficult to detect. The new BMW software now auto detects and auto flags flashed cars even if the dealership or service advisor is "cool" so the gig is sort of up on that front. It's like Audi now unfortunately.
10-07-2020, 03:08 PM | #12 |
366
Rep 804
A lot of misinformation all up in here. Yes BMW will now know if you have a flash tune or ever flash tuned even if you bring it in for an oil change with their new auto detect software, like Audi. If you run a piggyback and it is not in the car it's your word against theirs and a multi billion dollar company is not going to fight with a customer unless they have concrete evidence. Just the facts of life.
10-07-2020, 06:28 PM | #13 | |
3322
Rep 8,083
what? You think if you blow a motor BMW's gonna just shell out 50k for a new one w/o first investigating? Things aren't like that anymore, like 3-4 years ago. It seems YOU are misinformed, or i should say flash tuned... |
10-07-2020, 06:37 PM | #14 |
366
Rep 804
I think lay off the sauce dude, i don't know what you're saying. We're talking piggies here not flashes, my M6 was flashed, my M5 is not cause i kept my ear to the street and knew this auto detect crap was coming over a year ago. To answer your question, yes they will shell out $50k because motors blow bro, it happens tuned or not, mods or stock so they investigate but if the car was never flash tuned there's not much they can come up with. Piggies don't leave a signature once removed, it's called an interceptor for a reason if you do some research.
kingmonkeyjr454.50 |
10-07-2020, 08:17 PM | #15 | |
4065
Rep 5,231
This is not speculation but factual as I have seen it firsthand. A buddy of mine bent a rod on an F10 M5, removed the piggy and was denied warranty coverage for this very reason. ... BMW regional rep came out and that was that .. you're not winning this battle against BMW. With that said, I ran piggys for almost 6 years on two F10 M5's with zero issues .... kept my current F90 stock to avoid the entire headache.
GranitM5366.00 BMWDriverX365.50 |
10-07-2020, 09:32 PM | #16 | |
366
Rep 804
josec704065.00 kingmonkeyjr454.50 |
10-07-2020, 10:03 PM | #17 | ||
4065
Rep 5,231
While we may disagree on whether it can be detected or not, what BMW will do is not a slam dunk and that is a risk .. I've seen them act like dicks and you say they won't. Owners can do whatever they want; I'm just putting on the table the real possibility that they deny coverage and a misinformed owner is stuck with a bill. I have enough headaches in my life to deal with another one, especially this year LOL!!! Stay safe brother!!
BMWDriverX365.50 |
10-07-2020, 10:24 PM | #18 | |
366
Rep 804
josec704065.00 |
10-07-2020, 11:01 PM | #19 | |
539
Rep 1,463
It really does crazy justice to the F9x platform (M8 comp here) that it's within spitting distance 60-130mph stock while weighing so much more. A piggyback and I can tell it'll pull harder through 3rd than my EVO. The EVO has insane pickup and go, but it does fall flat (although it's still super fast) around 3-4th gear (where power figures matter more than power/weight). Amazing platform honestly. |
BMWDriverX365.50 |
10-08-2020, 09:32 AM | #20 | |
24133
Rep 190,687
Unless you are bringing your car for warranty work, the dealership does not care.
BMWDriverX365.50 |
10-22-2020, 08:15 AM | #21 |
1082
Rep 949
Fellas, you tune you car and blow the motor or tranny YOU ARE FUCKED. They can read almost everything the car has done. It's not just boost pressure, even though that's one of the first things they see. Yeah, boost peaks at diff temps and situations but not up to what the tune will be at. I posted awhile back in the M4 section about this. I blew mt GTR tranny and brought it to the dealer. They gave my the info on the black box and I was Floored how much info was on it. Torque peeks, engine and tranny high temps. Top speed and RPM. This was 9 years ago, LOL. So if you think Nissan knows all that in 2011, BMW will know whats up and they will give you a big DICK, not a new engine. Tune at you own risk. Believe what you want. Just be ready to pay up if it happens
10-22-2020, 09:42 PM | #22 | |
366
Rep 804
