09-29-2020, 12:14 PM | #1 |
1976
Rep 345
MHD Flasher FG Series (F9x) - discussion
MHD Flasher F+G-Series (N55/S55/B58/N13/S58/S63) The MHD Flasher F+G-Series is a complete flash tuning app for your BMW. Unlike a piggyback module, it is capable of complete DME remapping while retaining all OEM safety mechanisms. This allows for maximum performance,maximum safety, and unrivaled drivability. Several thousand customers worldwide have been enjoying the number one flash tuning tool for the E series N54 and N55 platforms (MHD Flasher N54 / N55 E-series) since 2015 and F/G-Series (N55,S55,N13,B58,S58,S63) since 2018. Product details: Full OBD Flashing: You can install MHD right at home and start tuning immediately! Simply download the MHD Flasher F+G-Series app that connects via our MHD WIFI Adapter to your Android device and your vehicle’s OBD-II port, start the app, and within 5 minutes the initial installation is complete. Further map changes are much faster - only 20 seconds! You can revert your vehicle to the factory OEM flash at any point, and no initial backup is necessary. Stage 1, Stage 2 und E85 OTS (Off The Shelf) Maps by PureBoost: We offer a wide selection of OTS maps for the N55 PWG, N55 EWG, S55, B58, N13, S58 and S63 engines suitable for many different vehicle modifications and octane levels. They have been extensively road and dyno tested, just flash and go!: S63 F9x
B58
N55 EWG* (Vehicles built after 07/2013 with electronic wastegate):
N55 PWG* (pneumatic wastegate):
S55 (BMW M2C, M3 / M4 F8x):
N13
Topspeed limiter removed on all OTS maps. As an alternative to built-in maps, many local and remote tuners can provide advanced custom mapping for those who have more extensive modifications or unique performance / customization needs. Monitoring and Logging Module: Monitor your engine behavior to make sure it is running perfectly using a configurable and very responsive gauge layout. 50+ engine parameters are available at a glance! Activate the logging mode to save the data to a standard CSV file for later analysis using the built in log viewer. Additionally, we will happily provide free logs analysis. These are some of the available monitors:
Flash-time Options:: These flash options can be applied to any map directly through the app!: S63 features available:
B58 features available:
N55/S55 features:
Read DME Codes:: Track issues by reading the error codes and delete them once resolved. Resetting adaptions is also possible (AFR, VANOS, Throttle, Load Control, Idle, Fuel and many more)! New features and updates:: The MHD Flasher F-series will continue to evolve after the release, which means many exciting new features and map updates will be coming in the future. What you need:
Supported vehicles: MHD Flasher FG Series S63:
MHD Flasher F-Series B58:
MHD Flasher F-Series N55:
MHD Flasher F-Series S55:
MHD Flasher F-Series N13:
Pricing (In-App purchases): The (competitive) prices list will be posted once our vendor account is validated in the vendor sub forum. for now see the f30post thread here http://f30.bimmerpost.com/forums/sho...php?p=22562277 *The Stage 1 map pack contains Stage 1 and Stage 1+ maps with all available octane variants.The Stage 2 map pack contains Stage 2 and Stage 2+ maps with all available octane variants. FAQ: Q: Can I test the connection before making a purchase? A: Yes, simply tap the MHD Store button. The ECU connection is checked before displaying available purchases. Q: Can I tune different cars with one license? A:Each vehicle has its own unique license (VIN and google account locked), tuning a different car requires purchasing a new license. Q: Can I tune multiple cars with one google play account? A: Yes, you can purchase multiple licenses with one google play account. Q: Can I transfer my licenses? A: Licenses are personal and stored by google along the account used at purchase time. The purchases are tied by google to the first account and can’t be transferred to a new google account. Q: Does my Android device need to be permanently plugged to the OBD port? A: No. Once a flash is performed you can unplug your device. Q: Do I need to purchase a new license each time I flash a map? A: No, you can reflash as many times as needed. MHD maps updates are free. Q: Is a battery charger required? A: It is highly recommended for long flashes (install, uninstall). A healthy battery will handle short flashes (map changes) fine but the use of a battery charger remains recommended. Q: How do I take good data logs? A: Press the Monitor (auto log) button, stabilize around 2500 rpm / 3rd gear (4th on 8 speed AT) with DSC fully off. Mash the pedal, shift at 6500 and 2-3s after the shift into 4 release the throttle. Slow down, stop the monitor. If you want us to review your log, then upload the log to www.datazap.me and send us the link. This Product is for Competition/Racing/Off-Road Use Only. |
10-07-2020, 03:05 PM | #3 |
26
Rep 142
10-25-2020, 11:07 AM | #5 |
26
Rep 142
What were the numbers for each stage? And is it crank or whp? Thanks!
11-24-2020, 05:13 AM | #6 |
1976
Rep 345
MHD BLACK FRIDAY SALE 2020
15% off on all MHD tunes / licenses from our Webshop. Visit: https://mhdtuning.com/collections |
Seba77W363.50 |
