BMW Z4 Forums (G29) BMW Z4 (G29) General Forum Cerium Grey Wheels
      04-17-2024, 06:23 PM   #1
Docray1
32
Drives: 2024 BMW Z4
Cerium Grey Wheels
Is there any consensus on the best product(s) to use for cleaning and protecting the Cerium grey wheels? Brake dust seems to glue itself to the matte finish areas and all the creases in the wheel design makes it even harder! Thanks in advance!
      04-17-2024, 08:20 PM   #2
GerryC
GerryC's Avatar
1715
Drives: BMW Z4 M40i, BMW X5x40i
Any good ceramic coating on the wheels will help make them easier to clean. I use Griots Heavy Duty Wheel Cleaner. A good spray-let them soak a bit then use a flexible wheel brush to break it all loose. A rinse with the hose followed by a wipe down with a microfiber towel. It's not hard but it takes time. Cleaning the wheels takes longer than the rest of the car.
2023 Z4 ///M40i Thundernight Metallic/Cognac Vernasca/Moonlight/Shadowline/19" Black 799M/PP/DAP/ACC/HK
2022 X5 xDrive40i Phytonic Blue/Cognac Vernasca/DAPP/LSP/PP/CCP/PAP/20" Style 738/Spare Tire/Trailer Hitch
Appreciate 3
      04-17-2024, 08:26 PM   #3
Top Gon
Bashar
Top Gon's Avatar
Drives: 2023 BMW Z4 M40i
I ceramic coated mine. Still have some staining from brake dust/dirt
      04-17-2024, 08:47 PM   #4
tracer bullet
tracer bullet's Avatar
Drives: '11 135i , '15 X3 35i
Agreed on coating them of course. As for products I've researched a little bit and I'll say that they're all about the same to be honest. All are similar in formula with similar results.
The Turtle Wax "Hybrid Hyper Foam" is probably among the best values, getting more for the dollar. Adam's products are great, as are those from Sonax, in my experience. I'm certain Griots and others are good as well. A couple dedicated brushes designed for the job help a lot as well. Some long fuzzy ones to get between spokes and into the barrels, something soft and with a huge face to clean the surfaces. Something slightly stiffer for the tires too if you don't mind starting a small collection. It can all fit in a small bucket you just grab and haul out when it's wash day, move it form one wheel to the next as you go along.
There's a specific section of the forum dedicated to detailing, you may want to browse around there. Any good answer found there will apply.
StanDiego6298.00
      04-18-2024, 06:03 AM   #5
stlcdr
stlcdr's Avatar
1025
Drives: 2022 Z4 M40i
I agree with ceramic coat. It doesn’t diminish the amount of dust, but it makes it very easy to clean.
2022 BMW Z4 M40i | 2021 HD Road Glide Limited | 2019 Ford Expedition XLT MAX | Subaru Outback 2019 | Subaru Outback 2024
      04-19-2024, 12:01 PM   #6
BmwIowa
54
Drives: 2023 X3 M40i
I too use Griots HD Wheel Cleaner, rinse and then re-coat with Griots 3-in-1 Ceramic spray..
      04-24-2024, 07:02 AM   #7
misterturbo
Drives: G29 Z4
I've had good luck with Sonax wheel cleaner. Works pretty well. I'm always on the lookout for a cheaper alternative, because it's quite EXPENSIVE.
I haven't found a wheel protectant that works as well as the claims. Especially against BMW OEM pad dust.
      04-24-2024, 07:48 AM   #8
tracer bullet
Same and agreed. I've read and seen a number of reviews and starting to feel like all the cleaners are nearly identical. I'll be trying this next:
https://www.amazon.com/gp/product/B0...KIKX0DER&psc=1
Rcasa20207.50
      04-25-2024, 07:36 AM   #9
misterturbo
Drives: G29 Z4
I just ordered some of this up to test it out. If it's 80% of Sonax I'd consider that a win.
      04-26-2024, 01:58 PM   #10
Docray1
32
Drives: 2024 BMW Z4
Please update once you try it! And thanks to all for the comments and suggestions!
bmw
