08-24-2020, 11:29 PM | #23 | ||
12971
Rep 18,716
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
09-01-2020, 10:17 AM | #24 |
723
Rep 704
Do you have to drive a little immediately after installing the front links, or can you just install all four corners then drive for auto-leveling?
09-01-2020, 11:11 AM | #25 | |
1346
Rep 1,241
It is necessary, to make sure that the electrical connections are disconnected while doing any changes, adjustments, etc. Don't plug the connectors back in until the links are set. If they need to be adjusted, disconnect before making any adjustments. |
bforbrian722.50 |
09-03-2020, 06:42 AM | #27 |
1346
Rep 1,241
Won't be a problem. My new wheels don't have spacers, but the offset is equivalent to running stock 21s or 22s..... with a 35mm and 40mm spacer.
Which...... no one should do btw... lol I was running 15 and 20mm spacers on my 21s, and even with my new 22s, no rubbing over bumps, full-back turn... nada. My drop however, is moderate. I may go a few mm lower, but I'm getting a feel for the new wheels & tires first. Last edited by Ninefourteener; 09-04-2020 at 04:38 AM.. |
Mr.Pringle195.50 |
09-05-2020, 03:59 PM | #28 | |
124
Rep 572
Are there any differences between the BBM and RGSport links? Reading this thread it looks like configuration is specific to link set? |
r33_RGSport12971.00 |
09-06-2020, 03:20 AM | #29 | |
1346
Rep 1,241
My measurements, were based on the overall length of the links themselves, whereas 4GSport's directions apply to only their specific product. My measurements, will work on any aftermarket droplink set. However, I would recommend RGSport's links more than the BBM.... if for no other reason than their quality instructions. BBM instructions are in German, and they have no customer support whatsoever. Last edited by Ninefourteener; 09-06-2020 at 03:28 AM.. |
09-07-2020, 04:53 AM | #30 |
647
Rep 442
Yes I'm running 15/25 with lowering links no problem purchased both from r33_RGSport
r33_RGSport12971.00 bmwsone0242.50 |
01-26-2021, 01:45 PM | #31 |
196
Rep 152
Awesome info thanks a lot for this!
01-27-2021, 09:14 PM | #32 |
26
Rep 136
Pardon me if I sound like an idiot.. What does this mean exactly in other terms?
** IMPORTANT: Recommended to code the car's default start at "Eco Individual", "Comfort Individual", or "Sport Individual" where you can set the suspension to start at Sport, otherwise you will go too low when you go into Sport mode with the link adjusted too low at Comfort mode. Is this just for installation or for long term? From RG Sport website. |
01-28-2021, 03:16 AM | #33 | |
1346
Rep 1,241
When you install droplinks, your car will be X amount lower in EVERY setting. You can set it to be a few mm lower, or you can set it to be 2 inches lower.... and everything inbetween. Whatever you choose (let's say you go exactly 1 inch lower).... then all 5 settings will be exactly 1 inch lower. It doesn't really matter if you code your car to start in Sport, or just maintain the factory Comfort setting. All 5 settings will be 1 inch lower. If the setting is too low.... and your suspension bottoms out (you'll know, trust me. The car will ride horribly).... then you can just raise them up a bit. NBD. I "think" what RG is saying, is that if you "dump" the suspension so that it rides very low in Comfort mode.... then if you ever drop it into Sport, it will bottom out the suspension. Just make sure that the "lowest" you want to go... is set in sport mode... so your car won't go lower than expected.
2020 X5 M50i, Alpine, B&W, Air Susp, anthracite, coffee, **CD player**:
15+ PAGE BUILD THREAD:https://g05.bimmerpost.com/forums/sh....php?t=1694019 690HP / 928nM Dynotune:https://g05.bimmerpost.com/forums/sh....php?t=1729813 6-Piston/4-piston BBK:https://g05.bimmerpost.com/forums/sh....php?t=2097342 |
01-28-2021, 08:47 AM | #34 | |
12971
Rep 18,716
But, the long version is this. Whenever you put your car into Sport driving mode, it will lower about 0.75" than Comfort. So, if you use the lowering link to lower 1.5" under comfort driving mode, when you switch to sport driving mode, it will go to 2.25" drop. Which at that amount, you will rub and may lock up the rear tire and cause damage or even accident. What I noticed with my 2021, Comfort mode remembers last driving height. It didn't reset to middle. Only if I switched driving mode, that's when it will reset to middle.
02-04-2021, 09:55 AM | #35 | |
135
Rep 200
I trying to order but want to see if it gets rust due to road salt or not. Thanks. |
02-04-2021, 10:55 AM | #36 | |
12971
Rep 18,716
If you want to be safer, once you are set on the height, you can spray them with paint or plasti-dip to create some more coating on it.
02-05-2021, 09:55 AM | #37 |
135
Rep 200
02-07-2021, 03:43 PM | #38 |
196
Rep 152
How do the rears look with 25mm have you go any more shots? From this pic it looks awesome! Just wondering wether to go 20's or 25's on the rear!
02-09-2021, 03:54 AM | #39 | |
1346
Rep 1,241
My 22s are considerably wider and more aggressive, and are the "equivalent" of running 35mm and 40mm spacers. PLEASE do not attempt to actually run 35 and 40mm spacers - LOL In both cases... I like the look.
02-09-2021, 03:38 PM | #40 |
89
Rep 101
Hey I ordered lowering links at a shop called eumd that did my powder coating for my wheels. Anyways they are charging me $300 for installation saying they have to program the car after installing. Like I know that's not correct and needs no programming. But I just want to confirm from you
02-09-2021, 03:40 PM | #41 | |
210
Rep 275
02-10-2021, 03:49 AM | #42 | |
1346
Rep 1,241
For "Installing the wheels on to the car, and coding"??? No... that is BS. The car will automatically recognize the TPM sensors. You don't need to code anything.
03-28-2021, 12:13 AM | #43 |
32
Rep 42
Does anyone have any know of an easy way to pop out the original links? I tried it with the heat gun, and also the "socket trick" but none of them worked and I ended up breaking the ball socket piece that connects the link to the car. Please help, as I'm almost tempted to not go through with it anymore. Thanks in advance!
03-28-2021, 06:07 AM | #44 | |
210
Rep 275
