07-01-2022, 12:12 PM | #1 |
17
Rep 93
FS: 2009 Jet black M-Package Reliable & Clean
Hello all, finally listing my daily, 2009 Jet black 135i. This car has never let me down and has been nothing but reliable. Text me anytime, 718-473-5758, i wont be super active on here, probably will check it every other day. This is being listed as FS but there is no rush on the time frame, the car is at 120k miles. The car has been well maintained with a lot of the commonly failed parts replaced. Also, this car has lots of goodies you wont find in a normal 09' 135i. Such as: - Bavgruppe headlight conversion with carbon fiber lid as well as turn lights changing amber - Bluetooth, Car play LCD/Touch screen head unit(Joying) - Reverse camera hooked up to the headunit - Carbon fiber diffuser - OEM 1M Mats - M4 Kidney grill - M4 Spoiler - Blacklines - Smoked LED turn signals - Performance pedals - M4 style shifter Turbos replaced at 85k, vaccume lines at 85k, Walnut blast 85k, Coils/plugs/injectors at 85k, from previous owner. Waterpump around 90k, brakes rotors at 90k, Oil filter housing gasket 90k, after I purchased the car. Odds and ends that broke were also replaced such as OBD2 pins, Hood latch, Diversity antenna, coolant pipes etc. Overall this car is and has been my daily for commuting on highways since I purchased it in 2018. Please see some pictures i've taken, this is how the car is on the daily so it would look way better with a proper clean & detail! Also check my youtube for how the headunit works with car play as well as the reverse camera functionality. Reverse camera and Car play: https://www.youtube.com/shorts/Tc5N7njGl_Y Blinker amber functionality: https://www.youtube.com/shorts/it3mEJsU4w8 Update: 5/4/2023 Replaced some coolant hoses New valve cover and valve cover gasket New spark plugs Oil change Update: 6/23/2024 Replaced TMAP sensor New High Pressure Fuel Pump Spoiler has some pretty bad paint deterioration needs repainting or new New Rear/front tire Last edited by jamespaoli; 05-23-2024 at 12:42 AM.. Reason: New maintenance and price adjustment |
05-24-2023, 04:06 PM | #8 |
24
Rep 43
Nice looking car, good luck with sell.
Mind if I ask about that screen you have in it? I am purchasing a 2012 BMW 128i but the lack of even bluetooth calling kills me a little. That screen looks very nice and I haven't seen it in any car in all the research I've been doing / cars I've seen. |
04-19-2024, 08:12 PM | #9 | |
17
Rep 93
There is a DIY post here by stubbiblue I believe. Search for joying DIY install. This LCD is not only awesome but it’s got WiFi Bluetooth CarPlay etc it’s awesome. I also installed a reverse cam |
