03-09-2024, 12:46 AM | #1 |
Rep 45
noise coming from front left suspension.
Hi guys. I have a 2015 bmw m235i xdrive. The car makes a noise like I’m driving on fresh fallen snow. Especially when I’m turning the wheel to the left, backing out of a parking lot, or driving into one. Does anybody know what could cause this issue? I have already changed the strut mount bearing and tightened the pinch bolt(as some people suggested). The car only makes the noise when it’s loaded( wheel on the ground). When I lift the car, the noise goes away. Would appreciate any advice.
Thanks. |
03-09-2024, 11:17 AM | #2 |
3085
Rep 1,830
Sounds like the same issue as https://www.2addicts.com/forums/show....php?t=2088215 on the front page.
03-09-2024, 12:30 PM | #3 |
Rep 45
My symptoms are a little different than his. Mine still makes that noise in park, whereas his makes it only in drive or reverse. I also had someone turn the wheel while I held the cv axle to feel for the clunking, but I didn’t feel anything. You can’t hear the noise at all from outside, but you can hear it inside the car. Also you can feel it through the stearing wheel
03-21-2024, 03:55 PM | #5 |
Rep 45
Figured it out. It ended up being the plate under the motor(mounts to subframe) that wasn’t as tight as it could have been. There are about 8 bolts. Make sure they are all tight. Hopefully this will help someone.
