For those of you that have replaced the Valve Cover Gasket... |
12-25-2019, 07:52 PM | #1 |
221
Rep 445
How was it? Did you find keeping the new gasket in place and mounting it on the block difficult? Its really up against the firewall on our cars. Any helpful tips? I plan to do this in one upcoming weekend.
Thanks!! |
12-29-2019, 10:35 PM | #4 |
221
Rep 445
I have a few tips as of right now from researching and asking around FWIW
-remove the oil cap and use that hole to gain leverage to remove the valve cover. -use a spray adhesive to tack the gasket down so it won't move when installing. I'm just using some light loctite general spray adhesive. Something that doesn't clump and is thin, just mask the channel and spray inside. I don't plan on spraying the entire thing, just the 4 corners of the big gasket. -when removing the two middle strut bolts, pull toward you so you don't smash your windshield with whatever tool you use. |
01-04-2020, 02:40 PM | #5 |
221
Rep 445
This wasn't that fun of a job, very annoying at times, but I got it done in 4.5 hours. There's a few things us 2 series owners will want/need to move in addition to guides you'll see elsewhere. Getting the valve cover back on was surprisingly easy, the adhesive made the gasket stay on just fine and I checked it with a mirror and all looks good.
About 30 mins driving and the mating surfaces look clean so I think the leak is solved, still some residual oil burning off that I couldn't wipe up that I'll have to deal with, and a little fuel smell, but that's probably residual as nothing seems to be leaking from the lines and considering the pressure they are under I think I would notice it! Feel free to ask me any questions or for any advice! |
02-19-2021, 11:23 PM | #6 |
Thaumaturge
181
Rep 211
When I start mine up, 2014 M235i, I get a slight whiff of oil. Like a drop and the smell goes away quickly. Can't actually see any leak and at 6000 miles after the last change the oil still reads totally full.
So, where do they usually leak and I hear some of the valve covers actually warp. How common is that as if I start the job with just the gasket, I really don't want to have to wait for a valve cover if I could actually see if it is warped. Any advice appreciated. ///Rich |
02-20-2021, 06:20 AM | #7 | |
106
Rep 198
12-14-2022, 06:01 PM | #8 | |
Rep 1
12-22-2022, 09:52 PM | #9 |
18
Rep 44
Drives: X4 M40i / M235i
What is your guys year and mileage for this?
Would be helpful to know when to expect these leaks... |
12-23-2022, 08:44 AM | #10 | |
106
Rep 225
Job is a bit of a PIA. Not super hard, but there is a lot of stuff to remove. I didn't use any kind of spray adhesive but others have and if (or when) it is time to do this again I'll give it a try. Definitely use a mirror to check to make sure that the gasket is in place properly before tightening it down.
16 M235 Cabrio - BM3, ER CP, Wagner DP & IC, Dinan Intake, MPE, Torqbyte CM5
18 340i F30 mostly stock |
2500AB18.00 |
03-21-2024, 01:23 PM | #11 |
'14 M235I
Rep 11
Mine was at 64,000m 2014 M235I. I did the repair but there is still a lot of oil smell coming from the engine compatment. I am hoping it's just residual burning off.
